Now taking orders for the LS2 Predator programmers!
Old Jul 18, 2005 | 03:16 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default Now taking orders for the LS2 Predator programmers!
TBYRNE Motorsports is now taking pre-orders for the LS2 Predator programmers. Diablo expects to have them ready to start shipping in a few weeks so this will allow you to receive one of the first that is released.
The Predator is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport’s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery.
This unit has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
A unique feature of the Predator is that is allows you, the user, to “fine tune” DiabloSports program. Since vehicles are located at different elevations or different weather climates, the way the vehicle responds to the DiabloSport program may vary (not all vehicles are exactly alike). Some vehicles will see better gains than others and some may see better (or worse) gains than advertised. This is due to the fact that not all vehicles respond exactly the same. Now, here’s the good news…If you're not totally satisfied with the way DiabloSport program performs, the Predator allows you to make your own adjustments to the program. For example: If you feel that the shift points are too firm, you can go into the program and lower the transmission line pressure (gas vehicles). If you feel that you can benefit from a higher shift point rpm, you can go into the program and raise shift points. If you feel that you will benefit from a few more degrees of ignition timing, you can go into the program and add some timing (gas vehicles). The Predator allows you to "fine tune" the DiabloSport program to meet your specific requirements.
The Predator has diagnostic abilities near identical to GM’s Tech2 software. The predator will allow you to read diagnostic trouble codes (DTC), erase DTC’s and perform live data monitoring. You can monitor your engine sensors while driving your vehicle and much more.
Part number and pricing is -
U7191 2005 C6 Predator programmer with overnight shipping $399.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Old Jul 18, 2005 | 03:42 PM
billywallstreet73's Avatar
billywallstreet73
It would be nice to see some results in hp from the predator. There was no mention of the torque management system.Im sure they had to of had a few cars to test it on.Lets hear some results.
Old Jul 18, 2005 | 04:20 PM
tbyrne's Avatar
tbyrne
A few details from Diablo -
The New #U7191 DiabloSport Predator for GM LS2 applications is currently in the tuning stage of development. All testing and development is being done exclusively at DiabloSport Performance Tuning, our Delray Beach, Florida facility.
Our newest Predator for GM will be a little different then past GM Predators.
Predator was the first stand alone hand held flash programmer for GM to offer end user adjustability, advanced diagnostics with read and erase fault code capability and live data monitoring.
The New #U7191 Predator will be the first to offer not just great dyno tested pre-programmed performance tunes, but the ability to hold multiple custom calibrations, and for the first time in the GM flash programmer market a stand alone flash programmer to allow end users to do real time data logging, through the Predator by itself, or through your PC or lap top with a free software download for the diablosport website.
Now with Predator you can flash your LS2 vehicle, make fine tuning adjustments, from real time data streamed from the vehicle, with out the need for a clumsy and expensive laptop. The ability to get custom calibrations from a nation wide network of DiabloSport CMR custom tuning dealers, done live on the dyno, or through simple E-mail. The DiabloSport dealer locator can help find a dealer near you.
http://www.diablosport.com/OurDealers.php
If the idea of having to learn to tune, buying an expensive full blown software program seems a little intimidating, we have the answer, and the adjustment to allow for a safe range of tuning changes to be made, along with speedo re-cal, extended limiters and all the other great features Predator is known for.
No need to send your valuable PCM out to have programs loaded, no down time on your vehicle, no paying all the freight and taking risks on lost or stolen parcels. With Predator in hand you always have the ability to restore your stock calibration for trips to your dealer for warranty work.
For the money DiabloSport offers a true “flash tool”, not just a flash.
Old Jul 18, 2005 | 06:28 PM
mikeyc6's Avatar
mikeyc6
I too would be interested in whether or not it (can) disable torque management. I will not buy one unless it can.
Mike
Old Jul 18, 2005 | 08:24 PM
Romeo90626's Avatar
Romeo90626
Default Tm
DITTO
It must disable or modify TM to be saleable
Old Jul 18, 2005 | 08:40 PM
billywallstreet73
nothing mentioned about the torque management.I am 10 minutes from your testing facility in delray.Feel free to use my car as a test if you guys are interested. You will need a few proven dyno results to get market share.PM me if your interested and I will post your results.My car is a 4k mile 6spd with bullets and stinger intake.
Old Jul 18, 2005 | 09:44 PM
tbyrne's Avatar
tbyrne
Will it eliminate or at least greatly reduce torque management? That is the big question. I'm going to try to get an answer tomorrow.
Old Jul 19, 2005 | 08:11 AM
6speedC6's Avatar
6speedC6
If it works as well as the one in my Cobra then I doubt if anyone will be disappointed.
Old Jul 19, 2005 | 01:13 PM
schwarzbart1's Avatar
schwarzbart1
It looks like that I can reprogram the PCM with your thing but what is with the BCM to change for example the radio region code, to disable CAGS or the daylight running lights?
Old Jul 19, 2005 | 01:14 PM
corvette05's Avatar
corvette05
Default predator tuner
what are the expected hp gains and torque on a stock z51 vette 6 spd
Old Jul 20, 2005 | 11:21 AM
VetteNo2's Avatar
VetteNo2
Is there any word on whether this device eliminates or reduces torque management?
Old Jul 20, 2005 | 11:28 AM
AceVentura's Avatar
AceVentura
AND allow you to turn the vette off in any gear without running the battery down. That's all I need right now!
Old Jul 20, 2005 | 12:18 PM
schwarzbart1
@tbyrne
What is the answer to my question?
Old Jul 20, 2005 | 01:15 PM
synthtk's Avatar
synthtk
Cant wait to hear the answer to this.
Old Jul 20, 2005 | 03:47 PM
Pio's Avatar
Pio
Old Jul 20, 2005 | 04:36 PM
AutoCutter's Avatar
AutoCutter
Ttt
Old Jul 22, 2005 | 09:33 AM
tbyrne's Avatar
tbyrne
This unit doesn't do anything with the BCM. We don't have any numbers for the LS2 yet but customers have reported gains in the 15-20hp range for other vehicles. No word on the TM yet and it won't do anything with what gear the car can be turned off in.
Think this covers everything
To Now taking orders for the LS2 Predator programmers!
Old Jul 25, 2005 | 04:17 AM
neko_cat's Avatar
neko_cat
Default The website does say it works on torque management
Predator handheld programmer
Lifetime Warranty!
Screen Size that is 300% larger than the competition
Quicker programming (takes approx. 2 min.)
Custom Files can be downloaded from internet which allows for future updates
and customized programming
OBD-II diagnostic software (includes live data monitoring of MPH, RPM, IAT, ECT, LTFT, STFT, O2 voltage, timing, knock retard detection, as well as many other sensors
Eliminates CAGS (Skip Shifting) on the 6-speed manual transmissions
Revised Torque Management Settings for optimum performance
User adjustability. the user can set their own parameters - Choose from DiabloSport's performance program, have a custom performance program made for you by a Diablo Tuner, or create your own:
a. Richen or lean fuel mixture
b. Advance or retard ignition timing
c. Raise and lower shift points in 10 RPM increments
d. Raise and lower rev limiter in 10 RPM increments
e. Reduce shift duration (time delay during gear change) (+/- 25% and anywhere in between)
f. Increase or decrease shift firmness (+/- 25% and anywhere in between)
g. Correct speedometer for gear changes and/or tire sizes
h. Turn on cooling fans at lower temps in incremental steps of 1 degrees (for vehicles w/ factory equipped electric fans)
i. Adjust top-speed limiters
The Predator allows the end user to adjust the following parameters:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
The Predator is the most advanced tuning programmer available today. It has taken the hand-held programmer to a new level. You will notice quicker acceleration and better throttle response. If you have an automatic transmission, the Predator will also give you a firmer, more responsive shift pattern (gas vehicles only at this time). The Predator will raise your rev limiter as well as it allows you to raise your top end speed limiter if you have installed high speed rated tires.
The Predator will save the original GM program so if at any time you want to go back to the original factory specifications, it will allow you to do so.
The LS2 version should start shipping the beginning of August. We are now taking pre-orders to provide you with one of the first that become available!
Overnight shipping offer in the continuous 48 states.
http://www.diablosport.com/GMappsPage.php
Also read on their site 10-20 RWHP gain in cars.
Note the data logging only seams available for Fords and is live with laptop only. It doesn't state that the predator stores info for download later.
1) Torque Management
PLEASE NOTE: Disabling torque management will put greater stress on your drive line.
TM Abuse Mode time limit= This is the time in abuse mode as a function of temperature. Turning it off in conjunction with Upshift Torque reduction and %Torque Reduction vs RPM will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
%Torque Reduction vs RPM= Torque reduction as a function of RPM, turning it off in conjunction with TM abuse mode time limit and upshift torque reduction will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
Upshift Torque reduction= Torque reduction control for each individual gear, turning it off in conjunction with TM abuse mode time limit and %Torque Reduction vs RPM will eliminate torque management. However we have noticed that the shift feel when disabling the upshift torque reduction in trucks and SUV's is reduced and therefore recommend leaving it ON for trucks and SUV's.
Old Aug 28, 2005 | 01:26 PM
tbyrne's Avatar
tbyrne
Soon... the LS2 programmer should be available very soon!
Old Aug 28, 2005 | 02:20 PM
natejohn's Avatar
natejohn
Sounds like "fun" but since I'm electronically challenged".......
HOWEVER, if "they" could add a program that would, er....disable the
tire pressure sensors so a "racer" could switch wheel/tire combinations without a lot of hassle, it would/could be a good selling point all on it's own.
