Removing screen on intake install
Old Dec 12, 2005 | 07:36 AM
  #61
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
Originally Posted by BUCKSC6
If you take into consideration that the stock MAF with screen flows, over 850 CFM from the factory, you will see its a waste of time unless you have rebuilt your motor to race specs and added big heads and cam.
Just marketing hype! Ask any real F body racer!
AK
but.. but.. ah... ummm.... what is the configuration when they test it to find the 850 cfm numbers. is that with it installed and the measurement taken in the intake after the butterfly or it is measured on the bench and it's a measurement of the airflow through the maf just by itself ? although it may flow more than what is required to create 400 hp if the air does not get into the intake it doesn't do any good. with the maf diffusor and the throttle body butterfly aligned at 90 degrees odds it results in airflow passing the maf, hitting the butterfly and then being forced down and into the intake. with the maf diffusor set horizontal the airflow passes the maf and goes directly into the opening created as the butterfly opens. there is also a difference in the way the air is used when the butterfly goes from closed/partial open to open. by straightening the airflow, the transition from part throttle to open throttle results in air going directly into the intake instead of it being forced down and past the butterfly as it opens. with the maf diffusor in the stock alignment, air is directed into the post on the butterfly.
overlay the two alignments and find the useage area, which has more ?
Old Dec 12, 2005 | 07:42 AM
  #62
Zig's Avatar
Zig
Originally Posted by zo6vetteman2003
Removing the screen shouldn't throw a code. A loose intake will.
Old Dec 12, 2005 | 11:55 AM
  #63
KGB6's Avatar
KGB6
Default Rotate MAF 90 degrees.
Originally Posted by Zig
but, how has the temp. been around there lately ? has it been cooler ? could the responsiveness be attributed to a drop in temp . ?
Zig,
The car runs great. One of the reasons why I waited to comment was to factor the temps out. The temps dipped before I made the adjustment, but my car never ran like it's running now.
To me the engine feels like it has more torque overall but particularly in the low-end and midrange band. The power comes in much sooner in the rev band compared to before. I don't even apply full throttle in traffic (in low gear) anymore out of fear of getting sideways.
For those of you who read this: if you're interested in increased performance, if you don't at least try this mod you're nuts! There is nothing to lose.
Old Dec 12, 2005 | 12:04 PM
  #64
KGB6's Avatar
KGB6
If the point of removing the screen is to improve performance, why don't you just rotate the MAF 90 degrees instead of removing the screen? It's a lot less trouble and it's reversible. Rotating the MAF 90 degrees reduces turbulence and alters the MAf signal. My car is more of a brute now with the MAF rotated.
Old Dec 12, 2005 | 08:36 PM
  #65
Madd_Matt's Avatar
Madd_Matt
Is there a trick to rotating the MAF. The connection wires won't reach on mine when rotated - either direction. Any clues?
Old Dec 12, 2005 | 08:51 PM
  #66
KGB6's Avatar
KGB6
The connection wire is being held in place by a clip, you have to remove it in order to release the slack.
Old Dec 12, 2005 | 10:05 PM
  #67
zo6vetteman2003's Avatar
zo6vetteman2003
Originally Posted by KGB6
Zig,
I had to turn my MAF 90 degrees anyway so I could close my hood. I relocated my MAF it now backs up to my throttlebody. The reason was for an accurate read on the IAT.
Old Dec 13, 2005 | 06:32 AM
  #68
Zig's Avatar
Zig
if you look closely at this pic. you will see the position that my maf has been rotated too.
http://forums.corvetteforum.com/phot...cat/500/page/1
yes, the wire that connects to the maf has a clip on it that clips the wire in place (not the clip that connects thye wire to the maf but the clip that simply keeps the wire from flapping all over the place). you can just undo the clip and route the wire, no longer using the clip.
Old Dec 13, 2005 | 06:44 AM
  #69
Zig's Avatar
Zig
what ? would you mind sharing a pic of your intake ? I'd be interested in seeing your setup.
i don't know how well or if it even works on any other years.
i haven't looked at the the design of other year intakes.
this mod. is specific to the c6 air intake. i imagine it would work with any other year as long as the configuration (air flow pathway) is pretty much the same.
yes, i agree, imo the closer one can get the maf to the throttlebody the more accurate it's gonna be.
Old Dec 13, 2005 | 07:53 AM
  #70
jruss361's Avatar
jruss361
Originally Posted by par34n5
Lets get the voting out with the do's and don'ts. Mine is off with the Vortex ram other wise you lose what you are suppose to be gaining.
Ok shoot what are your opinions?
Nothing gained!
Old Dec 13, 2005 | 07:56 AM
  #71
Zig's Avatar
Zig
Originally Posted by jruss361
Nothing gained!
from simply removing the screen ???
Old Dec 13, 2005 | 10:20 AM
  #72
KGB6's Avatar
KGB6
[QUOTE=Zig]if you look closely at this pic. you will see the position that my maf has been rotated too.
QUOTE]
I rotated my MAF counter clockwise from the driver's seat perspective.
Old Dec 13, 2005 | 11:50 AM
  #73
Zig's Avatar
Zig
[QUOTE=KGB6]
QUOTE]
is that placing the Delphi module on the bottom ? I rotated mine so the module is on the top.
does this rotation place the two wire posts (inside the maf) on the bottom. inside the maf there is three posts. two on one side and one on the other. if i recall correctly, it uses the two sets to get comparision measurements.
it would be interesting to see if there is, and what type of, difference in the intake related numbers for the three maf alignment positions (stock, module on top, module on bottom).
airflow and map numbers would interesting, especially gathered during day-to-day as well as some spirited driving numbers.
Old Dec 13, 2005 | 01:08 PM
  #74
zo6vetteman2003
I'll have to take some pics and post them. I can look between the condenser and the nose (between the hood) and see my feet lol! Look under the nose you will meet my Vararam Widemouth face to face.
Old Dec 13, 2005 | 07:10 PM
  #75
aaaaa's Avatar
aaaaa
I don't pretent to know but it seems to me that some distance is needed to allow time for the CPU to react to the air flow. in the c5 the mAF was farther away than the C6. Is that because GM upgraded the CPU to run faster?
Old Dec 14, 2005 | 04:20 PM
  #76
aaaaa's Avatar
aaaaa
Not really what I wanted to say.
I don't pretend to know but it seems to me that some distance is needed between the maf and the TB to allow time for the air flow sensors to react. The C5 maf was further away than the C6. Did GM upgrade the CPU or the sensors to respond faster?
On older FI systems there were resistive wires in the TB that responded to temperature. These wires heated up and air flowing past them would cool them. The wires changed resistance with temperature and this resistance was read and used to adjust fuel flow. All of this took time and though I'm sure todays systems are much faster there would still be some delay. If the maf was too close to the TB could this affect response time and therefore mixture?
Old Dec 14, 2005 | 06:01 PM
  #77
zo6vetteman2003
The new MAT sensors are located within the newer style MAF's. (not like the older C5's and LT1's with a remote MAT sensor) The resistors still will heat the same regardless of location in the MAF sensor. The actual IAT to the throttlebody would differ more (in IAT degrees) if they were remote from each other. You can look at it both ways. If your MAF is remote and cold and the actual inlet air to the TB is warm, is that an accurate A/F mixture with less oxygen rich cold air than the MAF is reporting? If I am going to pick up engine heat to my TB, why not get an accurate reading on the temp.? When it comes down to it, any gains either way are most likely neglegible.
To Removing screen on intake install
Old Dec 15, 2005 | 07:37 PM
  #78
rulez's Avatar
rulez
I am going to rotate the MAF, ride for about a month and put it on the rollers Jan 14th. My car is stock, but has a tune. I'll post the results if anyone is interested.
Old Dec 19, 2005 | 08:33 AM
  #79
Zig's Avatar
Zig
did you notice any difference ? i, for one, would be interested in your results. i'm the one that originally discovered this mod and feel that there was a difference, but that could just be me.
Old Dec 19, 2005 | 09:35 AM
  #80
jruss361's Avatar
jruss361
Came on a few days later I would say I cycled it three or four times. I had it cleared and so far nothing yet? Vortex Owner
I installed my HallTech Stinger last week. Sunday afternoon I decided to tweak the installation a little and found several pieces of the black sealing material on the MAF screen. Several other pieces still in the air cleaner. I blew out the air cleaner and used a vacuum, hopefully I got all of it. Glad I had the screen!
