Header install
Old Nov 24, 2005 | 09:17 PM
Perfomer's Avatar
Perfomer
Default Header install
Installing long tube headers and cats this week . Anyone have fix to hard spots and what to look out for . Going on a new Z06 not mine helping a club member on his Thanks
Old Nov 24, 2005 | 09:50 PM
1955 BelAir's Avatar
1955 BelAir
Eccentric Member
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07-'08-'09
Use a lift.
Old Nov 24, 2005 | 11:44 PM
Brett Hunter's Avatar
Brett Hunter
Originally Posted by 1955 BelAir
Use a lift.
I installed a set with the car on ramps only. While it is possible, I was pretty sore after crawling around under there.
Old Nov 25, 2005 | 02:05 AM
rmitchell242's Avatar
rmitchell242
check all your clearances to floor pan/tunnel ect.. under power everything moves and will rub! ANNOYING
Old Nov 25, 2005 | 08:55 AM
Miaugi's Avatar
Miaugi
Remove the spark plugs to avoid breaking any. Also, if there are any sensors in harms way, either remove them or temporarily install a header bolt to help protect it from getting whacked.
Old Nov 25, 2005 | 10:45 AM
haljensen's Avatar
haljensen
Spend lots of time routing wires and hoses, be very carefull with the clutch line from the master to the slave and where you route the O2 extensions.
Old Nov 25, 2005 | 10:49 AM
VET4LES's Avatar
VET4LES
Check for check engine light when your done.
Old Nov 25, 2005 | 11:57 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I installed Kooks headers myself on my C6. Biggest problem was the rear header bolt on the drivers side. The brake boster was in the way. Had to do that one from the bottom. I have a Kwicklift, which made it a lot easier. Took only 4 hours to install. I took off the spark plug wires, but didn't take the plugs out. If you are careful, you won't break any. Make sure you keep the 02 sensor wires away from the H pipe and headers. Good luck.
Old Nov 25, 2005 | 06:46 PM
Perfomer's Avatar
Perfomer
Thanks for all the info. I have a lift sothat will makeit a little easier .
Old Nov 26, 2005 | 11:58 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
I forgot to tell you that you should use GM manifold gaskets instead of the gaskets supplied with the headers. The gaskets supplied with the headers have a tendency to leak.
Old Nov 28, 2005 | 01:22 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WHAT BRAND DID YOU GO WITH??
bc
Old Nov 28, 2005 | 07:56 PM
Perfomer's Avatar
Perfomer
I believe they are from LG Motorsport . We are doing the install Wed. I will let you know how it goes.
To Header install
