Lug Nut size??
Old Dec 31, 2005 | 06:19 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
Default Lug Nut size??
Stupid ?? I know but does anyone know what size the lug nut is on a stock C6 coupe, 1/2 inch or 7/16? Buying some new lug nuts and I wasn't sure. Thanks.
Old Dec 31, 2005 | 06:26 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
Thread Size
M12 x 1.5
Hex Size
3/4
Old Dec 31, 2005 | 06:53 PM
AU N EGL's Avatar
AU N EGL
Corvettes are metric
19 mm nuts
and get a 6 sided deep socket 19mm with a 1/4" drive
Old Dec 31, 2005 | 06:58 PM
VET4LES's Avatar
VET4LES
19 mm nuts
A 1/2" drive might work better. A 3/4" or 19mm socket both work fine.
Old Dec 31, 2005 | 07:18 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
Thanks guys. I am trying to find a set of black ones that will work. I have Competition Gray wheels and think the chrome lug nuts look a little bit out of place. Since I have a black car I was thinking black lug nuts would look great on it. Any ideas??
Old Dec 31, 2005 | 07:24 PM
vetdude's Avatar
vetdude
Check with www.mallettcars.com. I bought a set of black chrome lug nuts for my Mallet 396 rims about a year ago for my C5. They're pricey (around $60/set) but they are top quality and look terrific!
Old Dec 31, 2005 | 07:28 PM
vetdude's Avatar
vetdude
Are these the same as the C5 lugnuts? I ask because I have a set of brand new wheel locks I never used on my C5 that I'd like to use on my C6. Especially since the polished wheels may become a "collector item."
Old Dec 31, 2005 | 07:30 PM
clambros's Avatar
clambros
I did the same thing for my comp gray wheels .. purchased McGuard black lug nuts from driverfx.com. Total price (with shipping) $52.55
Sorry I don't have a pic with the black lugs ...
Old Dec 31, 2005 | 07:40 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
19 mm nuts
I'd get a torque wrench too !!
Old Dec 31, 2005 | 07:41 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
I'm pretty sure they are the same.
Old Dec 31, 2005 | 07:42 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
Got a nice torque wrench last year. Good investment!!
Old Jan 1, 2006 | 09:46 AM
AU N EGL's Avatar
AU N EGL
DaH Yes I ment 1/2" drive
Old Jan 1, 2006 | 09:50 AM
AU N EGL's Avatar
AU N EGL
Slightly different style but yes they are interchangble between the two cars.
Diffenitly a good torque wrench, not the needle kind. Craftsman. Two major uses are wheels ( 100 ft lbs) and if you start doing brakes. The caliper mounting braket at 125 ft lbs.
Old Jan 1, 2006 | 12:17 PM
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
So The Spec On A Lug Nut is 100 ft Lbs?
Old Jan 1, 2006 | 03:12 PM
AU N EGL's Avatar
AU N EGL
Correct. tighten in a star pattern. No need to do the 50, 70, 100 ft lbs sequence.
Just put the nuts on a tighten with a deep socket 19 fairly tight, then crank them down with the sochet, then torque to 100 ft lbs.
I use an impact wrentch and it gets them 75-80 ft lbs, then the sochet wrench to about a 100 then torque to 100.
Old Jan 1, 2006 | 03:23 PM
BIGGGIE's Avatar
BIGGGIE
Old Jan 4, 2006 | 11:44 AM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Default Shameless Hijack :)
While we're on the subject of lug nuts , I've been trying to find a source for a 3/4" or 19mm socket which includes a soft insert (nylon? Al?) to protect against scratching/marring of my '04's chrome lug nuts. Any/all suggestions would be most appreciated!
To Lug Nut size??
Old Jan 5, 2006 | 02:24 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
Try this link: http://www.madvet.com/shop?frame=5650
If it doesn't work go to www.madvet.com and click on Wheels and Tires on the left. It's the only place I've seen them so far.
Old Jan 5, 2006 | 04:10 PM
mneblett's Avatar
mneblett
Perfect! Thanks!
Old Jan 5, 2006 | 04:25 PM
xs650's Avatar
xs650
19 mm nuts
3/4 inch = 19mm (0.7480) well within the manfacturing tolerances of sockets. They are probably forged on the same tooling with the only difference being the markings on the outside of the socket.
1/4 drive for lug nuts
