Lug Nut size??
Old Jan 5, 2006 | 08:24 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Originally Posted by xs650
3/4 inch = 19mm (0.7480) well within the manfacturing tolerances of sockets. They are probably forged on the same tooling with the only difference being the markings on the outside of the socket.
1/4 drive for lug nuts
No, they are different sizes...
Old Jan 5, 2006 | 09:54 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Go to Autozone. They should have black in the size you need and will be around $22 for all.
Cajun
Old Jan 5, 2006 | 11:44 PM
xs650's Avatar
xs650
0.002 inches different if they are both perfect, they aren't.
Old Jan 5, 2006 | 11:46 PM
C6400hp's Avatar
C6400hp
Old Jan 6, 2006 | 08:16 AM
AU N EGL's Avatar
AU N EGL
Yes they are very very close. and most lug nuts get slightly rounded anyway.
However, if you have a new 19mm nut without cap, and a 3/4 socket is put on that nut, the socket will wiggle.
I think a 3/4 socket will round new lug nuts over time especilly the C5 and C6 lug nuts with the aluminim beauty caps on.
Also use a 6 sided socket not a 12 sided socket for snug fit.
I use ARP studs and ARP lug nuts with an impect wrentch as my wheels are on and off all the time.
Old Jan 6, 2006 | 08:37 AM
05_C6Z51's Avatar
05_C6Z51
Originally Posted by Vettin Man
Stupid ?? I know but does anyone know what size the lug nut is on a stock C6 coupe, 1/2 inch or 7/16? Buying some new lug nuts and I wasn't sure. Thanks.
Did you find them in black? If so where, I'd like to order some as well.
Old Jan 7, 2006 | 01:21 AM
LS WON's Avatar
LS WON
19 Mm
Old Jan 7, 2006 | 02:18 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
Cajun
I tried Autozone and they said they couldn't get them. I found some at a local tire/wheel place for $20 but they are painted. Guess I'll try them once.
Do you know Chris Crain that works at USASOC? He ussed to have a Grand Sport. I have spent much time in Hope Mills myself, especially in Rockfish creek.
Old Jan 7, 2006 | 02:20 PM
Vettin Man's Avatar
Vettin Man
Cruise-In I Veteran
I found some at a local store, see above. Discount Tire Center. They may have one in your area. Also driverfx.com has the good ones, McGuard, black chrome, for around $55 for a set of 20. If I don't like the ones that come in to the other place I will order from there.
Old Jan 8, 2006 | 08:04 PM
abatewags's Avatar
abatewags
Coincidence... I ordered a set of these Lug Nut Impact Sockets just yesterday. A better deal and colors too:
http://www.harborfreight.com/cpi/cta...unction=Search
Oops that link doesn't look all there... try adding item # 40035 to the search.
Old Jan 28, 2006 | 11:24 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Curious, are you happy with these? I just got the same Harbor Freight set and the contact point between the nut and socket is not lined at all. The lining is external with just an insert. I need 13/16 for my lugs, but would prefer a set of truly lined lug sockets.
