3rd gear issues
Old Oct 13, 2006 | 02:56 PM
  #61
C6RAPTOR's Avatar
C6RAPTOR
Originally Posted by Dgatto
But:
I also had the 2nd to 3rd gear problem and I agree that my problem was also in how I was shifting. The "but" is for what I just found as maybe a related cause, or not?
We found the shift control assembly that the shifter (Hurst) bolts to has a bent rod that clamps to the long shift rod. This was making the shift rod bind badly going into reverse . The tech was able to realign the shift control assemble to reduce the bonding and the transmission would then go into reverse . Parts are now on order to replace the shift control assembly. Has anyone ever seen this problem? I do not know how the short rod in the shift control assembly could have bent. Could it be that it was like that when my 05 C6 was built? I should get it back from the dealer today.
