Important Question
Old Sep 14, 2006 | 05:59 PM
c6nut's Avatar
c6nut
Default Important Question
I have a question for you guys. I have an 06 A6 with a Procharger running 6psi. Currently you can not tune out the TQ Mgt from the transmission. (Please no debate on the TQ Mgt it exists) my delima is the slow 60' times (2.0 - 2.1 no wheel spin). If I was to spray a 50 dry shot would that help coming out of the hole since the computer can only pull so much timing?
Thank you in advance for your comments.
Ted
Old Sep 14, 2006 | 11:20 PM
shurite44's Avatar
shurite44
That amazes me that you are only running two second sixty's with a pro charger at 6 psi.
I am at least dipping into the 1.9's with my A6 with just bolt ons. There must be some serious TM pulling power on your car.
Sorry don't know much about nitrous, but there is a forced induction section for C6's.
Old Sep 14, 2006 | 11:23 PM
bojan's Avatar
bojan
off topic: what are your 1/4 mile times mph?
thanks
Old Sep 14, 2006 | 11:37 PM
shurite44's Avatar
shurite44
DA around 2K feet I think, ET 12.55 mph 114.97
That is about 3500 pounds with the driver.
Old Sep 15, 2006 | 12:04 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Ted
Call me crazy........ but if you used the spray to act as an chemical intercooler besides the air to air intercooler it might just work. The computer should see even cooler air and not pull timing. (I know chemical intercooling works as I used it on my Mustang...... just not too sure how the GM computer will react......TM ????? ) A denser charge would mean more power but maybe more TM ?. I haven't a clue
With regard to TM you might run your idea by Boosted Z06. (see TM thread)
Good luck
Old Sep 15, 2006 | 12:11 AM
c6nut's Avatar
c6nut
I know the car pulls 18 degrees of timiing between 1 and 2 and from a dead stop wot.
c6nut's Avatar
c6nut
thanks
I ran a 12.0 at 123.4 mph.
Old Sep 15, 2006 | 12:13 AM
LS1LT1's Avatar
LS1LT1
I've even hit 1.88 - 1.90 in stock trim in my A6.
Old Sep 15, 2006 | 01:00 AM
shurite44's Avatar
shurite44
Yes, you should be mid 11's with that MPH I think.
Old Sep 15, 2006 | 01:08 AM
c6nut's Avatar
c6nut
Yes, 11.2-11.4 I agree. For evey tenth off in teh 60' that accounts for 2 tenths in the 1/4.
Old Sep 15, 2006 | 01:11 AM
shurite44's Avatar
shurite44
2.0 sixty, 12 second ET, and 123 mph trap. I bet you fool some guys when you clip them at the end of the track, LOL.
Old Sep 15, 2006 | 01:33 AM
LS1LT1's Avatar
LS1LT1
Giving up a lot of ET with those TM limited sixty foots.
Old Sep 15, 2006 | 01:36 AM
c6nut's Avatar
c6nut
That is why I hope the N20 will help until HP completes the tune for Tq Mgt.
c6nut's Avatar
c6nut
It actually is pretty fun to run someone down.
Old Sep 15, 2006 | 10:33 AM
shurite44's Avatar
shurite44
I have beat so many guys because they let off at the end of the track not thinking I am going to catch them, LOL. The top end and slow start of the C6 makes for some great finishes in bracket racing.
Old Sep 16, 2006 | 02:37 PM
brokesupra's Avatar
brokesupra
Ted
Well...... if you pushed the little long skinny thing on the floor a little harder. you wouldnt need the nos out of the hole. lol
jv
Old Sep 16, 2006 | 06:10 PM
c6nut's Avatar
c6nut
jv
Thanks Jer.
Old Sep 17, 2006 | 08:23 AM
GMRULZ's Avatar
GMRULZ
Actually, through exhaustive research...Lol.., On my own car, and I have a couple of hundred slips, its right at 1.5 tenths in the quarter for every 1 tenth in 60 foot.
To Important Question
