Supercharged C6 Video
Old Oct 8, 2006 | 06:27 PM
SSJCreeper's Avatar
SSJCreeper
Originally Posted by TTRotary
Guys, I am seriously considering the maggie, but I'm concerned about the heat issue. Several vendors tell me heat soak is a problem. I hammer my car pretty hard so I need an honest opinion from you if it will hold up.
How are your cars in summer traffic with AC on etc. Thanks.
I have another thread in C6 general on this topic.
It has not been an issue for me, but I've had only a few drives out in the hot weather. From what I understand, the centrifugal superchargers are actually worse than the Maggie.
Old Oct 8, 2006 | 06:29 PM
TTRotary's Avatar
TTRotary
Yes, and centri is not for me. Too peaky...I would just do H&C +gears at that point. Have you taken your car to an HPDE?
Old Oct 8, 2006 | 06:33 PM
SSJCreeper's Avatar
SSJCreeper
Not sure I know what HPDE is.
Old Oct 8, 2006 | 06:39 PM
TTRotary's Avatar
TTRotary
High Performance Driving Event. Basically a track day (roadcourse).
Old Oct 8, 2006 | 06:45 PM
SSJCreeper's Avatar
SSJCreeper
Oh.
No, I'm more the 'casual' driver I suppose.
Old Oct 8, 2006 | 07:22 PM
TTRotary's Avatar
TTRotary
Old Oct 8, 2006 | 08:11 PM
StarJack's Avatar
StarJack
NineBall! You are having entirely too much fun! Keep it up!
Old Oct 8, 2006 | 09:48 PM
TTRotary's Avatar
TTRotary
NineBall, I'm sorry. I just realized I totally hijacked your thread. :o
Old Oct 8, 2006 | 11:14 PM
NineBall's Avatar
NineBall
No prob, your discussion applies here too!
No overheating issues at all with mine. The 160F t-stat and revised fan settings keep the engine coolant temps in the 183F range on the hottest days. The highest I ever saw it reach was 204F, when I got stuck in a traffic jam mid-summer. Still cooler than it ran when stock (220F all the time).
I've also done several full throttle laps at Road Atlanta, no problems there either.
As for traction, I have a set of 17x9.5 front C5 Z06 wheels with a set of 275 M/T drag radials on them. Those tires hook great, I only use them if I go to the drag strip though. Click the link in my sig to see the gallery, then click on the Corvette and then the photo gallery. It is a few pages back for a photo of that combo.
Tony
Old Oct 8, 2006 | 11:22 PM
excessive81's Avatar
excessive81
you know a metal rod in the right place welded to the mounting plate on the camera that would hold the camera rite way up and hung from the rear window make less noise and better lap times since topp is in!!
Old Oct 9, 2006 | 02:23 AM
TTRotary's Avatar
TTRotary
Thanks Tony. BTW, what is the sound we hear in the video: it sounds like belt slippage or tires. Happens right after you hear the blower accelerating. It is a constant, single pitch sound. Thanks.
Old Oct 9, 2006 | 11:10 AM
NineBall's Avatar
NineBall
That would be the tires. No belt slippage here. Belt slippage is easy to spot, because it leaves a nice film of black powder around the manifold and pulleys from the belts. The blower itself is also kind of loud at high rpm, mixed with the hazing tire squeal.
I actually have more extensions and elbows, I can definitely make it hang from the window, or even stick it on the inside of the passenger window. I just did it this way because it was simple, and the weather was perfect. Plus, I wanted you guys to hear the blower and tires clearly
Old Oct 9, 2006 | 11:14 AM
  #33
LOS ANGELES PI's Avatar
LOS ANGELES PI
Very nice. How close was the installation guide from MAgnusson to what you actually encountered? Did you remove the rack and pinion or raise the motor to pin the crank?
Any tips to share?
Awesome video.
Old Oct 9, 2006 | 11:22 AM
  #34
NineBall's Avatar
NineBall
The Maggie install instructions were actually pretty good. This was my fourth Maggie install (different cars), so I had a clear idea of how everything went though. The hardest part is removing all the junk in front of the engine to get to the crank pulley to drill/pin it. If it weren't for that, these kits would be super simple to install.
As for tips, I have a big one. The steering rack can be completely unbolted (hoses, steering rod ends, etc...) and slipped out towards the passenger side first, then lifted up and out towards the driver's side. No need to lift the engine or even unbolt it off of it's mounts. Getting to those hoses and tightening them back up required small stubby wrenches and such though. Not much room to work down there!
Old Oct 9, 2006 | 01:08 PM
  #35
Dgatto's Avatar
Dgatto
thats exactly why I went with a procharger.....so far never went over 190
Old Oct 9, 2006 | 02:29 PM
  #36
SteveL2's Avatar
SteveL2
That's awesome. I had a Maggie and 460+ rwhp on my C5 and it would do that in first, but not all the way through second like yours is doing.
Old Oct 9, 2006 | 07:38 PM
  #37
AintQik's Avatar
AintQik
Nine,
First off beautiful car and I'm glad you did the work yourself. Not enuf guys like us around. I had one question. I've got 4.10s and an N/A stroker that wraps up just like yours and will get crooked thru 3rd and get a piece of 4th rolling into it just like you did. Does 3rd come loose at all? I'm just wondering what kind of power I'm making... I'm still tuning before I get to a dyno. I think your car is a good comparison. I'd love to be over 500rwhp on this one.
rj
To Supercharged C6 Video
Old Oct 9, 2006 | 08:46 PM
  #38
LS1LT1's Avatar
LS1LT1
Pretty cool vid.
Old Oct 9, 2006 | 10:14 PM
  #39
NineBall's Avatar
NineBall
Originally Posted by AintQik
Nine,
rj
Anything over 475 rwhp should cook the tires pretty good on a Corvette. Get that thing to a dyno and let us know what you find out!
Tony
Old Oct 10, 2006 | 03:44 AM
  #40
TTRotary's Avatar
TTRotary
Thanks Tony You're running some serious power there
