... I am still getting some minor vibration in the rear end ... at around 136 km/hr. ... at first I thought the rear wheels were out of balance ... they were a bit, corrected that ... but still getting some vibration ... so next we are going to check the output shafts (may need to be rebalanced) Could also be the U-Joint.
So make sure, while they have your rearend all a part, have them balance the tires, and the output shafts, and check all other parts that may have been subject to the force that shattered your rearend.
I have heard that Cartek can make an adaptor to fit a C5 rear end in the C6 - I think a C5 core is about $700 vs. a C6 core at $2,100 and it sure seems they are a lot stronger. They break output shafts vs. entire cases.
My buddies have had good luck getting transmissions from Rodney at RPM Transmissions, good prices and good service. Sounds like you need a main shaft.
I hope it doesn't come to that but thought I'd mention some options I've kept in mind in case I find myself in your tough position. I sure wish you good luck in the new year.
hmm, I dont know about that, the C6 rear has been stregnthend quite a bit, besides all the instances I have heard of C6 rear ends breaking has been from wheel hop and not from their capacity to hold and transmit power. Wheel hop is curable, stronger rear ends arent what we need
I would not bother with the DTE brace your problem is you have an 05 which has the terribly designed small rear end that was reengineered in 06, you need to upgrade to the 06-07 rear end and get a set of Pfadt coil overs, that will eliminate any wheel hop.
As far as I know it will, the changes were made to the diff. and gears inside, they beefed up everthing, but the actual housing is still the same from what I have read. If you do a search you should find the pics that one forum member posted showing the differences in the 05 and 06. I would double check with the dealer and make sure, IMHO it should be swapped out for free they obviously knew there was a problem thats why they changed them. For future advice, don't ever buy the first year of a car, they rely on the general public to see what works and what doesn't and then they make changes.
Two things you need if you are going to drag race a '05 Z-51...
1. an 06-07 transaxle. GM strenghtened the transaxle after many failures with the '05's
2. Base springs - the Z-51 springs don't allow the proper squat and weight transfer as with the base springs. If you want to autocross, then the Z-51 is the way to go. If you want to drag race, then you want the base suspension.
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
I dont think you can put a 06 transaxle in an 05. The bolt pattern at the tranny is different. You need the 06 tranny as well if you want the 06 rear. I think if you have the cartek adapter you can put a C5 transaxle in without changing the transmission to 06. I havnt seen the cartek adapter yet, anybody that has one please post a pic. And we are all waiting for the DTE Cast Iron diff case. Coming soon...
Sorry to hear you had this happen. Let us know how it works out.
Both 05 and 06 differentials are very similar. The 06 has stronger out put shafts and pinion bearing support from the factory. The 05 and 06 C6 rear housing them selves are very different. The 05 housing is weaker by design and tend to break at the rear pinion due to lack of support. The C5 hosing has a lot more support and will resist breaking a lot better. Both can and will be damaged by wheel hop, but the C6 housing can and has failed even when wheel hop is present. I broke an 05 C6 housing while the car was stock on drag radials while base lining at the track. We have since replaced the housing to a C5, and have run as fast as 10.2’s with a 6 SPD and stock suspension. There will all way’s be a weak link some where’s in the drive train. Depending on how much power, traction, and how you drive, will a lot of the time dictate if some thing will break.
I have it at the Dealship not they are looking into see what they can do. ?????? Wish me luck!!
We are not complaining as much as trying to find the best solution to fix my problem. I guess I am complaining a little as I do feel that this should not have broken for no more then I was doing with the car. If I was out drag racing and broke it then its my bad. But I have driven my Porsche, C5 and Trans Am way way harder then this C6 and have never done this much damage to them. So I guess I am a little disappointed in the design and strength of the C6 so far. Hoping I can make it better in the end. If it does not drive me crazy first !!
And you're providing valuable information to other Vette owners by sharing your experience. And you might get some benefit yourself from others who have experienced the same or similar problems. Thanks for sharing - it's the point of the forum in my book. Don't worry about sour grapes that get posted in the C6 forum. Seems the C6 forum is crabbier than the C5 forum. In my experience anyway.
Back on topic - please keep us updated if you don't mind. I am quite concerned about this recent rash of broken trans output shafts with no wheel hop present and hope someone finds out the root cause.
Do you know when your car was built? Mine was May 2005 vin 124xxx.
You guys with modded cars that break and come here to complain about it floor me.
unbelievable
Hey genius, there is a reason why GM completely redesigned the 05 rear end... because they were breaking, not modded ones, if they were modded then they wouldn't have to replace them because you voided your warantee. There many members on this forum who had their rear ends fall out on STOCK cars.
As far as switching from the 05 rear end to the 06 rear end that wouldn't make any sense to me. My buddies rear end in his 2006 exploded at the track on a drag radial with just a cam and headers. This happened off the line and never even had a chance to wheel hop. Prior to this I had been running mine at the track on a ET street 16" and launching the car at 5000 rpms without any problems with the car having been dyno tuned and the TM supposedly gone. Now, I know I was probably just lucky and have since stopped using my slicks until I can afford a DTE Rear end but I just wanted to point out that the 2006 rear end hasn't proved to be any better, and also I recently found out that the 2007 Rear end has been changed again!!! Why in three years of production have they changed the rear end 3 times.... probably because GM made a junk rear end!!!
?? WHAT DO YOU MEAN THEY CHANGED THE DIFF TO FIX THE PROBLEM??
THE OUTPUT HOUSING ON THE TRANSMISSIONS ARE DIFFERENT.
DONT YOU THINK THATS WHY THEY CHANGED IT?
IVE NEVER HAD ONE GO SOUTH.....
WHAT WERE YOU GUYS DOING WHEN THEY CAME APART?
DID THEY START MAKING NOISE?
DID THEY LEAK?
ANY VIBRATIONS?
OR DID THEY JUST POP...
LET ME KNOW I WOULSD LIKE TO LOOK INTO THIS FURTHER//
