Broken rear diff housing?
Old Jan 3, 2007 | 06:29 PM
  #41
UDRIVESLOW's Avatar
UDRIVESLOW
#PIP3559F Rear Axle Chatter Shudder On Turns - keywords bind differential - (Dec 6, 2006)
#PIP3930 Possible Seal Leak And Axle Seal Popped Out Of Position - keywords axle differential fluid - (Sep 28, 2006)
#PIP3923 Manual Transmission Fluid Leak From Weep Hole - keywords differential seal - (Sep 27, 2006)
#PIP3892B Rear Differential Clutch Pack Stack Height Change - keywords axle bind chatter shudder - (Sep 14, 2006)
#PIP3442A Transmission Fluid Leak from Weep Hole at the Rear of the Transmission - keywords axle differential - (Jul 18, 2006)
#03-04-20-006A Fluid Leak at Rear Axle (Replace Left Differential Side Cover O-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange) - (May 9, 2006)
THIS IS ALL THE TSBS THAT IVE FOUND..
NONE WITH THEM COMMING APART....
HAS ANY ONE TAKEN THEM TO A DEALER BEFORE??
UDRIVESLOW
Old Jan 3, 2007 | 08:34 PM
  #42
DJackman's Avatar
DJackman
Originally Posted by CustomShop
I am going to call the dealer on tuesday. I am crossing my figures. I painted the General Mang. C5 a year or so ago so I hope maybee he will help me out.
Dont tell him about the wheel-hop situations and clean all of the rubber peel from the wheel well and I mean ALL. Good luck
Old Jan 4, 2007 | 02:08 AM
  #43
CustomShop's Avatar
CustomShop
I only told the I was taking off alittle hard and it popped. I really did not have any rubber in the wheels wells at all. I just hope they dont say its because I have 345/30/ 19 tires on it? Theay are supposed to let me know tomorrow. I am praying Thanks
Old Jan 4, 2007 | 11:17 AM
  #44
ShockerRacing's Avatar
ShockerRacing
Good luck!
Old Jan 4, 2007 | 11:15 PM
  #45
CustomShop's Avatar
CustomShop
Still have not gotten a straight answer for the dealership. So I have been talking to DTE about getting one of there Rearends. maybee a stage 2? any body have exp. with there rearends?
Also does any one know if there is a better outpt shaft for the trans. then just getting a stock shaft? Thanks
Old Jan 5, 2007 | 12:00 AM
  #46
SONKIST's Avatar
SONKIST
St. Jude Donor '07
My tuner HIGHLY recommends them. They have installed many of them in various cars, including the C6.
I'm looking for the recipe to keep this from happening, not how to fix it once it happens...
Old Jan 5, 2007 | 12:02 AM
  #47
CustomShop's Avatar
CustomShop
WHO? is it?
Old Jan 5, 2007 | 10:32 AM
  #48
SONKIST's Avatar
SONKIST
St. Jude Donor '07
WHO? is it?
MC Racing. Overland Park, KS. (Kansas City Metro)
Old Jan 5, 2007 | 12:00 PM
  #49
ShockerRacing
I think Breathless Performance makes a better output shaft.
Old Jan 5, 2007 | 05:37 PM
  #50
BDRME's Avatar
BDRME
IMHO whats going on with the diff/trans breaking is "axle wrap". In a leaf spring car you would add traction or slapper-bars to keep the pinion, front of axle housing, from pointing upwards. But in a c5-c6 the engine,torque tube, trans, diff are 'one piece'.
Mounting points in the front of the engine and two at the rear of the diff creating a long bridge. When traction is good and torque applied its trying to force the middle upwards. Thats why most of the damage is on top off the trans/diff cases. A stronger trans output shaft might not cure the problem. A DTE trans diff brace will help but then the energy will be put on the torque tube.
Old Jan 5, 2007 | 08:02 PM
  #51
DrivnXcitment's Avatar
DrivnXcitment
We ought to all start a club! All who have blown up their diffs can join. But you MUST blow it up to become a member
All 05's have notoriously weak rear end casings. The gears are strong, but the case is not. That is why they reinforced the 06 and up crowd.
Old Jan 6, 2007 | 08:52 PM
  #52
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You raise an interesting point. I'm certainly not an engineer, but since our pinion gear is at the back of the ring gear, wouldn't the pinion try to climb down the ring gear (instead of up the ring gear like a normal diff), causing the front of the diff try to torque down (against the new side cover mounts), and the back to torque up (against nothing, compared to the C5 mount under the back of the diff)? Would that explain the breakage that we're seeing, with the back of the cases breaking on the top of the pinion and the trans output shafts breaking when that happens?
And that said, would the DTE brace, which supports the top of the diff case, provide good protection against this kind of breakage?
Has anyone seen a DTE equipped C6 rear break?
Oh and for those planning to put a 06 rear in their 05, here's a thread showing the differences and outlining the reasons why it's not an easy change.
http://forums.corvetteforum.com/show...ential+changes
Old Jan 7, 2007 | 09:17 AM
  #53
BDRME's Avatar
BDRME
[QUOTE=Joe_G;1558405750]You raise an interesting point. I'm certainly not an engineer, but since our pinion gear is at the back of the ring gear, wouldn't the pinion try to climb down the ring gear (instead of up the ring gear like a normal diff), causing the front of the diff try to torque down (against the new side cover mounts), and the back to torque up (against nothing, compared to the C5 mount under the back of the diff)?
No, you are right about the pinion in back but the ring gear is on the opposite side as well. We have c-5 drivetrain sitting on a c-6 rear craddle. At the start of our race the initial launch broke the cases but the car managed to make turn one under full power before the output shaft on the trans broke. Now we run the DTE brace.
Old Jan 7, 2007 | 11:05 AM
  #54
Z-51 POWER's Avatar
Z-51 POWER
I had the same exact problem that you had, I broke the hole housing on my stock 3:42, because of really bad "wheel hop"...called Reese @ www.mtiracing.com and he helped my out really quick. I now have a DTE 3:90 stage 2 installed...It is awsome, it's like having a new car!!!
Regards,
Manuel
Old Jan 7, 2007 | 12:48 PM
  #55
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Ahh. I didn't realize that. I bet you are correct, axle wrap must what's causing this and the different mount from C5 to C6 must be the reason why axle wrap is now a problem.
I run the DTE brace too, had it on my C5 also. I figure it's so cheap it's silly to not get one if you change your gears and have the diff out anyway. I haven't seen a posting of a C6 rear broken WITH the DTE brace, so that's good.
What kind of times are you posting on the C6 rear?
Old Jan 14, 2007 | 12:58 PM
  #56
CustomShop's Avatar
CustomShop
I have not heard anything yet from the dealler I will ask them tomorrow . They said they were having a hard time finding a complete rearend for warranty????? But I did find out that Bowlers performance trans. says they have a better output shaft if any one else is looking. http://www.bowlertransmissions.com/
ask for Mark
Old Jan 14, 2007 | 01:07 PM
  #57
CustomShop's Avatar
CustomShop
I also wanted to let everyone know that we have the build up pictures on our website now at http://www.customshop.org/sema_2006_...ain.html:cool:
To Broken rear diff housing?
Old Jan 14, 2007 | 01:08 PM
  #58
CustomShop's Avatar
CustomShop
sorry http://www.customshop.org/sema_2006_...eous_main.html
try this one.
Old Jan 15, 2007 | 02:00 AM
  #59
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
The Link is still Bad...
Let us know how it all turns out....
Old Jan 16, 2007 | 01:21 AM
  #60
CustomShop's Avatar
CustomShop
Try www.customshop.org under sema 2006 Sorry again
