Ka Boom! Engine Bye Bye
Old Feb 3, 2007 | 06:08 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by carboman
LSX block is the way to go!
Yes that thing appears to be almost indestructible but the weight penalty (over 100 pounds more than an LS2 block) is a big downside. And you still have to outfit it with the strong internals as well.
An OEM aluminum block should be fine, just have to build it and tune it right.
Old Feb 4, 2007 | 01:07 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Originally Posted by tfenton
Wow. Tough day. Blown engine. Modded with Vortech which means I eat it. I either rebuild or look for option B. All in all, I was happy with the vortech but I'd like to see more low end torque.
I'd like to maintain a stealth approach .. especially with a vert.
Any suggestions before I begin rebuild ....
Sent you a PM.
I'm willing to come up there with my enclosed trailer at N/C and give you a killer deal on any engine combo you'd like.
I have 402 and 416 engines in stock.
I also have a fuel system that will support any power level you desire.
Let me know.
Andy
Old Feb 4, 2007 | 01:23 PM
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
Crate 7 litre Z-o6
Old Feb 4, 2007 | 06:42 PM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
LS7 Time
Old Feb 4, 2007 | 07:45 PM
a2zpcwiz's Avatar
a2zpcwiz
Sorry to hear. How about one of these? http://www.turnkeyenginesupply.com/streetpackages.html
Old Feb 4, 2007 | 08:26 PM
BADC64GO's Avatar
BADC64GO
Originally Posted by 07C6NTX
You could always get a crate LS7
Now there is lemons to lemonade!
Old Feb 4, 2007 | 10:37 PM
shopdog's Avatar
shopdog
Originally Posted by LS1LT1
That's assuming that the cylinder walls in his stock LS2 are still in good enough shape and weren't too badly scored when the motor (rod? piston?) let go.
I like that L92 idea as well.
A LS2 block can be resleeved.
Old Feb 4, 2007 | 11:30 PM
tfenton's Avatar
tfenton
Thanks for the advise everyone ....looking at a few different options at this point. Will keep you all posted ...
Old Feb 5, 2007 | 01:41 AM
TTRotary's Avatar
TTRotary
Originally Posted by Craigster05
LS7 Time
No dosrespect, but this is the worst advice I have heard. These engines are failing left and right due to either defective valvesprings or (much worse) oiling problems leading to failed bearings. Neither problem is resolved. Plus, you can't boost them. That is the very LAST engine I would get.
My vote is 402 with forged internals so you can boost later and a nice top end for now. It will make better power than the 427 anyway.
Old Feb 5, 2007 | 04:09 AM
LS1LT1's Avatar
LS1LT1
True.
I wouldn't use a stock LS7 for a boosted application either...though starting with the bare LS7 block alone and building it right might be ok.
Old Feb 5, 2007 | 01:02 PM
NORTY's Avatar
NORTY
Congrats on taking responsibility for your actions. Too many children on this site try to blame anyone and everything for their choices.
Now,as far as a new engine, how about an LSX block? They'll be available @ the end of March? You can get some big inches with that block.
Old Feb 5, 2007 | 01:44 PM
Waveblaster785's Avatar
Waveblaster785
Detonation FTL.
Half the time people don't realize that tip in detonation is just as bad as WOT detonation. Make sure when you get your new motor and get it tuned that they don't just tune it for WOT, they drive it and listen for tip in detonation and check the AF throughout the RPM range. There is more load on the motor in 6th gear at 1500 rpm than people think.
Old Feb 5, 2007 | 01:58 PM
  #33
tfenton's Avatar
tfenton
Here's the plan. Car's headed down south to A&A and we'll drop in a 402 along side the vortech and a few other enhancements.
Thanks a number of folks on in this forum that have helped along the way ... Rick @ Synergy, Andy @ A&A and your ideas.
More to come ...
Old Feb 5, 2007 | 06:02 PM
  #34
DaWorm111's Avatar
DaWorm111
Originally Posted by vertC6
Yeah, thats what I was thinking something with the timing because 6.5 is nothing on these engines, the guys here in Houston run 11 all day with no problems.
Yea, the last two Procharged C6's we have built made 11 lbs of boost and put down over 700rwhp on a stock bottem end. Both cars had methonal kits. Andy will get you taken care of. Good luck on the new project.
Steven Fereday
HPE
281-448-1300
Old Feb 6, 2007 | 12:12 AM
  #35
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Most people want crazy amounts of power and do not realize that you have to build it right from the getgo. A conserative tune will save you many dollars in broken parts. This is the key to keeping the motor together
Old Feb 6, 2007 | 10:49 AM
  #36
sditch's Avatar
sditch
If your running boost i would just get a iron 402 shortblock with nice internals, get some reworked L92 heads and intake and your be all set. Sounds like a fried a piston or berings. Just make sure your compression is right for your boost. Boosting a resleved block is another thing that can go wrong.
Old Feb 6, 2007 | 01:08 PM
  #37
BLU-BY-U's Avatar
BLU-BY-U
that was real oregonc6-ish
To Ka Boom! Engine Bye Bye
Old Feb 6, 2007 | 02:37 PM
  #38
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
Sorry to hear about your engine. Makes you wonder that even with a small boost level you're still not too far away from blowing it.
Old Feb 6, 2007 | 03:22 PM
  #39
LOS ANGELES PI's Avatar
LOS ANGELES PI
Bummer. But, there are more important things in life than a car so It's not a really big deal.
Very nice attitude. I should be more like you.
Old Feb 6, 2007 | 05:22 PM
  #40
TTRotary's Avatar
TTRotary
I thought Foosh was coming in here to deny everything as usual, so I had to ruffle up a bit .
Seriously, 12 documented failures in the Z06 section, 4 at my dealer out of 13 or so cars sold (that was back in May 06), and two more I personally know of, including the very Z06 I was to drive at Spring Mtn. earlier that same day.
Sorry, but that is just not the kind of operating record I want in a crate engine or, for that matter, any engine. I just wish GM would do right by this because it impacts the whole corvette hobby and car values. Maybe they could follow BMW's lead and offer 7/100 warranties to Z06 owners. Seems only fair.
