OBD-II Scanner
Old Mar 27, 2007 | 02:28 AM
NewToC6's Avatar
NewToC6
Default OBD-II Scanner
Any recommendations on a scanner? Also, since the 2006 has a push button start what do you do when it says turn on the ignition but do not start the car.......Use accesory mode????
Thanks in Advance
Old Mar 27, 2007 | 02:37 AM
cbrf4i1's Avatar
cbrf4i1
Thanks in Advance
no, if you have manual, key on without depressing the clutch. or just like auto just hold down the kill / engine off switch for 5 sec.
Old Mar 27, 2007 | 06:20 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Yea, what he said......
ACC Mode: Hold in the bottom of the Start/Stop button for 5 sec.
Old Mar 27, 2007 | 07:49 AM
corvette-pilot's Avatar
corvette-pilot
Thanks in Advance
www.scangauge.com
I just got one for my DD, haven't hooked it up yet. When I called I was able to get in on a group purchase someone had going and got it for $150 shipped
This thing is amazing at what it can do Not only read codes and clear them but moitors all sorts of stuff.
Old Mar 27, 2007 | 09:20 AM
AFVETTE's Avatar
AFVETTE
Thanks in Advance
Third one from the top, best $65 you'll spend. http://www.diydiagnostics.com/
Pays for itself with one CEL event.
Tom
Old Mar 27, 2007 | 10:03 AM
Michael K's Avatar
Michael K
I just had my first check engine light on Saturday. I am looking for a good code checker.
Has anyone tried the MSD DashHawk?
Old Mar 27, 2007 | 10:53 AM
cbrf4i1's Avatar
cbrf4i1
http://www.diydiagnostics.com/pro_se...bdii_specs.htm
does anyone have this one? curious to see the feature of scanning live data, and how of of data are available for viewing. thanks
Old May 2, 2007 | 07:16 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
ttt
HAs anyone used the dash hawk to clear codes yet ?
Old May 2, 2007 | 07:51 PM
timd38's Avatar
timd38
If you get a Predator it will read and clear codes.
Old May 2, 2007 | 08:33 PM
VET4LES's Avatar
VET4LES
I have a Innova 3110, it is CAN enabled which is a must for the C6. It works great on both of my cars and several of the neighbors also. OB2 scanners are for all 96 and newer automobiles.
Old May 3, 2007 | 02:29 AM
TRJ's Avatar
TRJ
I have the same Innova 3110 model, OBD II, CAN supported, it works great at reading codes and shows the diagnosis right on the unit. Erases codes in an instant. Very satisfied with mine. Comes in a quality pouch, and a tutorial owners manual. $179.00 at Sears...
LINK: http://www.sears.com/sr/javasr/produ...id=00942270000
Old May 3, 2007 | 01:00 PM
burtonbl103
Originally Posted by TRJ
I have the same Innova 3110 model, it works great at reading codes and shows the diagnosis right on the unit. Erases codes in an instant. Very satisfied with mine. Comes in a quality pouch, and a tutorial owners manual. $179.00 at Sears...
Nice
I have a scanner
Was just wondeing abut the dash hawk
How did you make out with the cel ?
Old May 3, 2007 | 01:17 PM
TRJ's Avatar
TRJ
Originally Posted by burtonbl103
Nice
I have a scanner
No experience here with the Dash Hawk, Bill.
You have a PM...
Old May 3, 2007 | 01:53 PM
Buffy's Avatar
Buffy
There are several levels of these things. Generally, code readers will read and reset CELs, scanners will do that at more, like showing pending codes, viewing freeze-frame data (saved when there's an event), monitoring real-time parameters and logging data to a personal computer.
Some of them also are better at handling manufacturer-specific codes (all recent cars use the OBD-II base set, but the individual manufacturers can add to that).
I have an AutoXray 4000, that's a semi-pro model, runs about $300. It does just about everything except the active procedures, for which you need a GM Tech II (about $3K).
But do make sure you get one with CAN support. Most newer models should have it, as I believe that's to be the standard next year. But beware something that's way far on sale - it might be an old non-CAN model they're unloading.
Old May 3, 2007 | 02:55 PM
Whiterock1's Avatar
Whiterock1
And it does it well, supposedly. Like getting a freebie thrown in. So far, very happy with mine.
Old Jun 2, 2007 | 11:06 AM
Brandegee's Avatar
Brandegee
Default OBDI/II Scanner
A few days ago I purchased the new Innova 3140 ODBI/ODBII Scanner. For those who have both OBDI and OBDII cars in their garage, or may have occasion to scan a car of the ODBI persuasion, this may be just the ticket. It is advertised as "the only OBD2 & 1 diagnostic tool you need in your garage"...maybe so. In additon to reading generic and manufacturer-specific codes, it includes Freeze-Frame Data and Live Data displays. The Live Data update rate is very quick and allows for recording and playback of 20 frames of live data. Not bad for $208 plus shipping from West Coast Tools.
http://www.iequus.com/news/news.php?id=23
Old Jun 2, 2007 | 02:18 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I have the Innova 3100c....it's OBDII compliant and you can upgrade via the Interweb. It does everything I need it to do.......
http://www.canobd2.com/knowledge/what_is_obd.asp
Old Jun 3, 2007 | 10:14 PM
cerino2000's Avatar
cerino2000
I use autotap and it does rather well. I have it with the GM modules and consider it excellent. You can read/clear codes but on top of that it shows you real time data about the car and allows you to log that data for further review. I bought it to use for tuning my 96 C4 when I had it as they don't make ANYTHING that will do both tuning and datalogging for a 96 C4 since it is the first year of OBDII yet not an LSx engine.
To OBD-II Scanner
