Electrical tech question???
Old Apr 19, 2007 | 12:11 AM
BATMAN06's Avatar
BATMAN06
Default Electrical tech question???
I replaced my LS2 with a LS7 w/drysump & engine harness. I no longer have the engine oil level switch or wire connector that went to the oil pan. I am getting the DTC "Check Oil Level" and I cannot make it go away even with HP Tuners software disable. I believe the fuse box is the problem because the wiring still exists going to the ECM but not to the motor. I need to know what wires it is and what I need to do to be able to stop the message from showing up. Please help...it is really driving me nuts. Thanks,
--glenn
Old Apr 19, 2007 | 12:20 AM
johnodrake's Avatar
johnodrake
Moderator
I read about a guy in Florida that put an LS7 in a vert. He wound up having to use the Z06 ECM and BCM to make everything work. He was a Chevy dealer too....
Old Apr 19, 2007 | 12:26 AM
BATMAN06's Avatar
BATMAN06
Everything works great, the computers are the same...just different engine harness and tune. I just have the stupid DTC I can't get rid of...I am hoping someone can tell me how I can trick the computer to turn it off. I put 600 miles on it already!
Old Apr 19, 2007 | 01:00 AM
tjwong's Avatar
tjwong
The switch goes open circuit when its low on oil. Just short the two wires together and the idiot lite should go off.
Old Apr 19, 2007 | 12:27 PM
BATMAN06's Avatar
BATMAN06
That's kind of what I thought...however I need to figure out which wires...I have the schematics...but it's kind of a pain to interpret...i rebuilt the whole car myself...but when it comes to electrical schematics...I need some help.
Old Apr 19, 2007 | 12:45 PM
Miaugi's Avatar
Miaugi
I have the service manual, maybe I can help. Do I understand correctly that you put a different harness on the car?
BTW, I just sent you a PM about something else.
Old Apr 19, 2007 | 12:52 PM
dbradley's Avatar
dbradley
Why not just use the "LS2" sensor in the dry sump tank?
Old Apr 19, 2007 | 03:12 PM
BATMAN06's Avatar
BATMAN06
The LS7 uses a different engine harness...they are almost identical except for just a couple of differences...one being the Oil Level plug is no longer part of the harness.
It won't work...and it no longer is on my car...it was on the old harness.
To Electrical tech question???
