Rear axle nuts
Old May 21, 2007 | 01:13 PM
jimsc6's Avatar
jimsc6
Cruise-In VII Veteran
Originally Posted by haljensen
No need for a picture, just remove the center cap from your rear wheel and the 33mm nut is right there dead center on the axle. Hard to miss, the nut is over an inch and a quarter wide.
Can you remove the center cap while the wheel is mounted or do you first need to remove the wheel?
Old May 21, 2007 | 01:34 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
So, we all agree? It's 34mm? Right?
Old May 21, 2007 | 02:31 PM
IC6's Avatar
IC6
33mm, 34mm, or 1 5/16" ?????
Old May 21, 2007 | 03:10 PM
AintQik's Avatar
AintQik
The "Performance Tool" 33mm that I bought at Pep Boys doesn't have close tolerances; measuring across the flats I get 33.71mm, 33.68mm, 33.75mm. But $12.99 @ Pep Boys has to beat Snap On prices.
Not when the fiance's dad is a Snap-on Rep
Old May 21, 2007 | 03:51 PM
eboggs_jkvl
Moderator emeritus
I guess no one knows the correct answer to the size?
Old May 21, 2007 | 03:55 PM
pit-pony's Avatar
pit-pony
My 34mm chinese cheap o socket ($4 at Princess Auto in Canada) worked fine, no problems found, my nuts are tight after 3000 km.
..jack
Old May 21, 2007 | 05:20 PM
torquetube's Avatar
torquetube
I do. It's 1 5/16" (I understand GM likes to call it 34mm, but it's not). 34mm, however, will work; it's just a little on the loose side.
33mm will only work if you've got a largish socket and/or a smallish nut.
Old May 21, 2007 | 05:26 PM
torquetube's Avatar
torquetube
You do not need to remove the wheel. The center cap pops outwards.
It's a bit tricky to get a hold of, though. I use a little L-shaped pick to grab the back of the cap and pop it out.
Old May 21, 2007 | 07:05 PM
joela's Avatar
joela
just use 34mm, 33 mm is a crap shoot.
http://forums.corvetteforum.com/show....php?t=1676084
Old May 21, 2007 | 08:29 PM
torquetube's Avatar
torquetube
Or 1 5/16", which is the right size, and easier to find to boot.
Old May 22, 2007 | 12:59 PM
IC6's Avatar
IC6
thanks much!
Old May 22, 2007 | 02:10 PM
rmp's Avatar
rmp
Same here; problem seems to be widespread.
I've been following the Z06 thread on loose axle nuts and decided to check my C6. Dial caliper showed the nut to be just under 33mm so I bought a 33mm GM axle nut from Pep Boys. Passenger side was very loose, 80lb.ft. or so, drivers side was tighter but still not correct. Tightned both to 118 lb. ft. and will continue to check them now that I've proved to myself that it's a problem. May be Locktite time?
Old May 22, 2007 | 05:50 PM
  #33
Miaugi's Avatar
Miaugi
I just ordered a second set of nuts and I plan to double nut them...can't think of any downside to doing this and the upside is this should stop the originals from backing off.
I think the reason you are reading one side was "more loose" than the other is that it is unlikely both sides would loosen the same amount.
Old May 22, 2007 | 06:47 PM
  #34
cbrf4i1's Avatar
cbrf4i1
how much are they? and from where?
Old May 22, 2007 | 07:02 PM
  #35
LOS ANGELES PI's Avatar
LOS ANGELES PI
Interesting idea, you would have to torque the first, then tighten the second without adding torque to the first nut, I guess hold the socket out a little from the second nut so as not to touch the first?
Besides, what would that do to the balance of the half shaft or bearing hub assembly? Probably nothing, but I wonder...............
Old May 23, 2007 | 06:40 AM
  #36
Miaugi's Avatar
Miaugi
Rather than search out something that "might" do the job I just bought the OEM nuts at a dealer, they cost me ~$13 each.
That won't be a problem as the nut has a integral shoulder washer incorporated into it so the socket can't go past the first nut to get to the second one.
There is plenty of room to add a second nut onto the shaft and in will have no effect on balance as it is at the very center of the wheel assembly.
I will pick the new axle nuts up today (dealer had only 1 in stock), my plan is to torque the existing nuts to the 118 ft.lbs. and then torque the second nut to 100 ft.lbs. which should prevent the original from backing out as the nuts should lock to each other.
"Double nutting" (sounds weird) has been around forever and I've never seen something come loose when using this method.
Old May 23, 2007 | 09:20 AM
  #37
glass slipper's Avatar
glass slipper
Excellent suggestion!!!
Maybe you could start a new thread titled "Solution to Loose Axle Nuts" to get the info out to as many people as possible. Then it should be made a sticky. This is the cheapest and easiest solution to this nagging problem...hopefully, GM is reading this and will at least incorporate a "half-nut" as a locking nut. It doesn't take a lot of torque when double-nutting something to get them locked on the threads, 100 ft-lb will have them on there until the axle shaft or nuts rust away.
Good job!
To Rear axle nuts
Old May 23, 2007 | 09:25 AM
  #38
LOS ANGELES PI
Double nutting?
Hmmmm, could think of many comments that would get me banned.
Old May 23, 2007 | 02:40 PM
  #39
Jon_R's Avatar
Jon_R
Default Loose Nuts (Rear Axle)
I gotta quit reading these threads about issues I would of normally been unaware of......
Checked my 2006 C6 A6 garage queen (700 miles) and it has never ever been pushed and found both nuts about 1/6 of a turn loose. They were not loose but they were not at 100 ft lbs which is where I set my torque wrench as I was just trying to verify tightness not break loose. My concern with breaking loose the nut has destroying the "Locktite seal" if there was a factory seal and I can tell you for sure there was NO factory installed locktite seal. The minor nut movement I experienced could be the calibration difference between my torque wrench and the factory's impact wrench even though I set mine at 100 ft lbs so I'd rather doubt this theory.
This will be a routine inspection when I change the oil from now on....Thanks everybody for the heads up.
John
Old May 23, 2007 | 06:44 PM
  #40
VET4LES's Avatar
VET4LES
Has there ever been a case where a rear wheel come off or loose where the driver had a problem?
