Predictions on modding the new LS3?
Old Jun 22, 2007 | 01:35 PM
NORTY's Avatar
NORTY
Originally Posted by 68roadster
Freakin computers! Give us a carb,
Yeah, and 6 and a half miles per gallon!
Old Jun 22, 2007 | 02:50 PM
bunk22's Avatar
bunk22
Originally Posted by C6Brian
All I can say on this is look how much better the LS2 responds to boltons than the LS6 or the LS1. It would probably be like that.
Does the LS2 respond better than the LS6? From what I've seen when I peruse the C5Z forum, the LS6 and LS2 look about equal when we add the basics, such as long-tubes, intake, tune. Then again, they often have a little more juice stock so maybe the LS2 does respond a little better.
Old Jun 22, 2007 | 04:19 PM
TTRotary's Avatar
TTRotary
Whatever the change is, it is for 08 onward and does not include 07. I don't think GM did this to screw the aftermarket. This is instead a fuel-saving change permitting the car to operate more efficiently when not in closed loop: instead of fixed fuel maps, the engine adjusts for conditions, allowing each engine to run at maximum efficiency in all regimes. But it also means tuners cannot make permanent changes to the WOT maps.
We just need to wait and see. This may be a blessing in that the computer adjusts for mods (no more tune needed for say headers CAI rockers baby cam) or it may be a nightmare. And other solutions will come up.
I remember back when I had my 3rd Gen RX-7, one tuner came up with a piggy-back computer that basically hijacked the signal from the EEC-IV ECU, modified the values, and sent it back to the computer. You controlled boost electronically as well as the transition from single to twin turbo operation, fuel maps, ignition advance, etc. all from inside the car - back in 1993. It was trick, that's for sure!
Old Jun 23, 2007 | 12:31 AM
glass slipper's Avatar
glass slipper
The poor MPG of the old carbed cars was more a function of the cam and engine/car design, not the carb. Give me an old Quadrajet and some dyno time and I can get you up to 500 HP (cam/heads of course as well as headers) and 20+ MPG on an LS2. With two even older 4-Jets, 600 HP and 20+ MPG on an LS7 are a piece of cake...but I'll need more dyno time (4-Jets have 4 floats and ~10 adjustments per float ), a 2X4 tunnel ram manifold, and exhaust gas temperature monitors for each cylinder. The only thing that beats a venturi for fuel atomization is the new direct injection systems, and the Q'jet has triple venturis on the primaries. Just like computers, it all depends on who's doing the tuning and how well they know the carb.
Old Jun 23, 2007 | 02:06 AM
lexaudio's Avatar
lexaudio
Well mine does at least. (lucky bastard)
It will all be sepculation until we get the marks from the owners, and tuners.
But if it comes down to tighter restrictions, then the lS6.2 will be a bitch to deal with.
It will be less than 2 months before the 1st hit the new owners.
Still, no one has answered the Z06 factor.
Is the Z06 going to get the same computer restrictions in the 08's?
LEX
Old Jun 23, 2007 | 02:23 AM
Maui's Avatar
Maui
St. Jude Donor '08
I wish you were in the nw. I can't get the quadrajet on '68 Camaro to quit siphoning. Any suggestions?
Old Jun 23, 2007 | 04:21 AM
shopdog's Avatar
shopdog
Lots of tuners will be looking for work if the new ECMs are fully adaptive.
Same thing in the 350Z world until the tuning software guys managed to crack the computer. But there's an alternative to piggyback kludges in the Corvette world, just swap in a 2005 ECM. That can already be tuned.
Old Jun 23, 2007 | 08:35 AM
glass slipper
What do you mean by siphoning??? I've never heard that term to describe a carb problem. Are you talking about fuel flowing from the main circuit at idle or is your fuel bowl draining after it sits for a while? I'm just not sure what you mean by the term "siphoning" as the only place there's a continuous low pressure area is in the venturis.
Old Jun 23, 2007 | 12:28 PM
HPTuners's Avatar
HPTuners
Supporting Vendor
We will do what we can to bring tuning solutions to the LS3 equipped vehicles as soon as possible.
We have been pretty good in the past about being first to market with many of the new platforms, years, and ECM's.
__________________
https://www.hptuners.com/https://www.hptuners.com/
Old Jun 23, 2007 | 12:36 PM
SpinMonster's Avatar
SpinMonster
Not to mention the best in the end.
Old Jun 23, 2007 | 12:43 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
These guys have a great product.
Old Jun 23, 2007 | 12:51 PM
8850's Avatar
8850
Sounds good Keith. I was thinking of updating to an 08 but without tuning I would keep my "old" 07 for sure. It would be great even if only minumal management is available like shift points, fans, converter lock speeds, etc.
Old Jun 23, 2007 | 11:20 PM
  #33
HPTuners's Avatar
HPTuners
Supporting Vendor
Indeed.
Its very difficult to modify any type of performance vehicle without tuning these days.
When new platforms are released we get e-mails from people who have highly modified vehicles, just weeks after they have gone public with nothing to tune, and the cars run just aweful.
We don't want you guys to wait any longer than you have to. As soon as our product is tested for production use, we'll let you guys have it.
Old Jun 23, 2007 | 11:29 PM
  #34
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
I do mainly Ford tuning, but I love using HPTuners software for the few local GM cars I tune. There will be some ragged LS3 cars out there for a few months, my bet, until Keith releases the LS3 updates. Worth the wait.
Joe
Old Jun 24, 2007 | 12:09 AM
  #35
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
According to several tuners I have spoken with, the '08 Corvette will be very difficult to work with because the LS3 computer is totally different from prior years. .................
Newer is not always better.
Are they the same people who told you that the 2008 Corvette would have 400 HP ?
Old Jun 24, 2007 | 01:27 AM
  #36
TTRotary's Avatar
TTRotary
Hey, I'm even, OK. You forget I'm the one who predicted the Z06 would have a 427 because that was the only engine that made sense for emissions and power, back when you and others were convinced it would be a 6.4L or some such thing.
No one told me about 08 power. I made a guess and I was wrong. Happens, ya know. Can we please move on now?
Keith, I take it the changes to LS3 PCM are not that big a deal?
Old Jun 24, 2007 | 07:59 AM
  #37
punky's Avatar
punky
Banned Scam/Spammer
Interesting. Is it then possible that the pcm in the 08s wil be capable of recognizing and adjusting for increased airflow throughout the range of rpm, loads, etc. That would would be great.
Maybe just wishfull thinking that you could add headers, intake and not need to address the computer to compensate for the greater efficiency.
To Predictions on modding the new LS3?
Old Jun 24, 2007 | 02:59 PM
  #38
TTRotary's Avatar
TTRotary
I am surmising from Keith's responses that HP Tuners has something coming. Let's wait to see what these guys come up with.
Old Jun 25, 2007 | 09:02 PM
  #39
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I assure you the computer will not keep a racer out. Thousands of man hours will be put into the new system until it is fully fuctional. Then the new cars will be better because of the faster-smarter new ECU.
Randy
Old Jun 26, 2007 | 12:27 AM
  #40
Cory@LS2PortWorks's Avatar
Cory@LS2PortWorks
St. Jude Donor '09
Bolt-on's are already in production. Halltech has CAI's already sorted out. I have already ported a few L92 intake manifolds, too. I've already got the TB porting covered as well.
Tuning will be great when available. I run HP Tuners Pro so I'll be looking for the new releases, too!
