***Vendor Warning***
I have read this thread with keen interest. My car is at Straightline Performance for a head and cam installation. After reading these 88 posts the only thing I really know is that Straightline should be highly motivated to make sure that everything on my car is perfect on my car before I get it back. I owe the OP some gratitude for creating intense interest in QC at Straightline.
I checked out Straightline on the forums and found only positive feedback. I talked to them and formed the opinion that thay could do the work. I also believed that they would resolve any problems that they caused with no loss to me. After reading these 88 posts I still feel that way.
I have sympathy for the OP because something went wrong for him. I recognize that buying a head and cam job involves certain risks but nobody likes to see anyone else hurt. The holiday weekend ruined. The child in the car. All of this sounds quite frustrating.
Unfortunately, however, I believe that he compounded his problems by refusing to let Straightline fix his car. He did that for his own reasons and we can't judge the merit of that decision in his unique circumstances. His car is fixed now and that problem is solved. He is out some money and that problem is still subject to resolution. I am not a lawyer but I am reasonably confident that he waived legal remedies by failing to allow Straightline to fix the car. Again, I would urge resolution of that issue in private.
An issue that the OP may also need to consider is that his posts constitute an attack on Straightline with a clear intent to cause them damage. I don't recall the specific words but the OP urged us "not to call these guys for work on our cars." He said that he didn't know who at Straightline could be trusted, etc. If they are damaged by this attack, he may have liability. This liability could be much larger than the amount he is seeking from Straightline. Once again, I would urge the parties to make a deal and move one.
I also have sympathy for Straightline. They may have done something wrong but the way they have been handled here is unnecessarily painful and unproductive.
Best wishes to you both.
This could have happened anywhere, and Mike@Straightine has a long history as a quality shop. And he offered to make everything right. We had a similar incident where a customer came in with a vibration under power. First thing we looked at was the dampner since they are so prone to failure. Sure enough, it's wobbling, a sign of impending failure. He has a aftermarket warranty on the car so we have to have the adjuster come & approve the claim. The adjuster comes by & sure enough verifies it....says he sees this alot, but then sees the ProCharger on the car & asks us "Is that a supercharger?" Duh, yes.....so he denies the claim as the warranty is clear that any power adder voids it. Customer is mad, but says go ahead. We replace the pulley, bolt, etc & after it is done there is still a slight vibration. We call customer to get permission to go further & he says no, he'll drive it like it is for a few days & then let us know. Well he takes it to another shop with a questionable rep (not a forum sponsor) and the other shop tells him there was nothing wrong with the dampner & we ripped him off by includeing a new bolt...and said the swap only takes an hour (not the 4 we take to remove the rack, etc.) so the guy sues us. What a nightmare. Turned out fine in the end but when you are dealing with a reputable shop with a proven track record, why not let them make it right when they offer? The bolts are a common well known problem.
Straightline stepped up and did all they could. There are dealerships that would not go that far.
First of all I never said who the vendor was they did, and second they have not denied their wrong doing.
I had an experience with a local Chicagoland tuner that was equally unsatisfactory. They tuned my car awhile back, and at the time of the service I asked them what happens if the dealer has to re-flash my car for warranty purposes. The shop told me that they of course keep the tunes on file and that they would re-flash for a nominal charge. Well, the issue came up. I called the tuner about a re-flash and I was told the following. Well, we saved all of the customer tunes on a laptop, which crashed, nothing was backed up, and the tunes may have all been lost. I asked what this means to me if I need a re-flash. They said, in effect, that was my problem. They will re-tune at full price.
So what is the difference? Both shops made mistakes. Straightline offered to do everything reasonable to fix it, to honor their agreement, so to speak. The tuner said their mistake was my problem and they had no intention of "making it right" per their original agreement with me. Would I now use Straightline? Yes. Would I go back to the tune shop? No.
With respect to the narrow issue of liability for attacks on Straightline, I am trying to help you only. You made the remarks that I referred to in post 56, long after we knew that the "Vendor" was Straightline. That looked like an attack to me. As I said, I am not a lawyer. I am just trying to open your mind to the possibility that you may end up needing one because of this. I would urge restraint and focus on resolving the problem, not on attacking the Vendor. That's all.
With respect to wrong-doing, you have accused Straightline of wrong-doing but they neither denied or admitted any. You have stated your side and they have stated theirs. Without a third-party verification of all the pertinent facts, this is not a useful process. You are both losing, at this point. Once again, I would urge you to seek resolution. If you want to do it on the internet, then have at it but be careful and recognize that it will take longer than it needs to take and that there may be unintended downsides for you both. I would urge you to try to do it in private.
Before deciding on a place it is probably important to realize that this may not be your first and only round of modifications through them. Most shops realize that. When I took my car to XXX shop I was intrested in developing a relationship with them knowing full well that good/bad experiences may come out of it. Fast forward one year later and yes good and bad things have happened but far more good than bad. When the issues came up they more than stood behind their work, shop, and most importantly their word. Most of them very minor issues that were resolved with simple communication.
I don't think there is a shop on this board that shouldn't be on "Vendor Warning" by your definition. I'm not discounting the the fact that you had some issues with your install. They should not have happened plain and simple. However, it is a risk we take when modifying cars. Be happy that the shop offered to take care of the issue. We probably wouldn't be reading this had the shop agreed to pay all your outside costs/repairs. The post has turned bitter due to no resolution to monetary outlay after the fact more than the original issue.
I haven't been so lucky in the past with some shops. I could name you countless issues that have come up from very well know named vendors that have been pm'd and have stayed off the public forum, but 99% of those were resolved with good communication and people willing to stand behind their work.
I hope you get a resolution to your issue, you deserve it. However it would probably go lots smoother with a good solid phone call to air it out and put and end to it.
dougie
Just like insurance companies can not tell you you must take your car to xyz body shop to have it repaired you are not obligated to have the service place do the repair work.
You need to file a claim against the service facilities insurance company for the defective/ faulty work.
If the repair work had been INVOICED through a licensed repair facility the claim would be much, much stronger.
However, there is still a legitimate claim just not as strong.....you may have to reduce your claim $$ amount.
Its always good to have several estimates and a judge/insurance co. would usually go with or award the lower one.
Why don't you guys ask a third party to work it out and settle up with each other.This s/b settled by compromise, seek and arbitrator and for a couple hundred bucks resolve the issue
In the long run the shop screwed up they know it they have an obligation to make you whole.
The shop is just trying to minimize the pain, out of pocket expense.
One Black vette produce evidence of your $$ claim to the shop.
It is very unlikely that if the OP were to take this to court in attempt to recoup money that he would win. Just my .02
It sucks if you happen to be the one where - perhaps - some things dont go right. But, the shop's response was correct, and lacked any holier-than-thou attitude. Their response was proper, and as best you could expect.
What your post really is saying is "warning. beware. this vendor isn't perfect, nor infallable. avoid at all costs." which to me is silly - but that's just my opinion.
Have YOU ever made a mistake in your life? Were you forgiven or given a second chance, or are you somebody to avoid at all costs due to that one mistake?
Subject: Check Gages Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install New Crankshaft Balancer with POA Friction Washer) #05-06-01-001D - (02/24/2006)
Models: 2005 Chevrolet Corvette
with 6.0L Engine (VIN U - RPO LS2)
Built Prior to VIN Breakpoint 55111039
As you can see it only refers to 2005 Corvettes up to the VIN number posted. I checked to see if this applies to any 06 or 07 Vettes and couldn't find anything referring to them.
In that bulletine if a problem arises, the dealer is to replace the balancer and the POA washer which resides on the crankshaft side of the balancer. The manual also states that the old bolt can be used provided that a minimum of 237 ft/lbs of torque can be acheived or if a new bolt is installed that its installed at 37 ft/lbs and then torqued to 140 degrees.
The bulletine states that the old bolt is to be used and torqued to 237 ft/bs to verify that the balancer is seat to X depth, then a new bolt is to be installed with loctite on the threads and torqued to 37 ft/lbs plus 140 degrees on the second pass.
I have used this very same proceedure for installing the balancers with new bolts and have yet to have one come off.
as far as I am concerned this one is done...I will read and review to make sure
John - oneblackvette - came to us for heads and cam. We did the install, tuned the car, he picked the car up, it made 440 RWHP and at the end of the week he picked it up.
Monday I recieve a call, John says that the crank pulley bolt came loose and he was upset that it ruined his weekend. Understandable, who wouldnt be mad? I offer to take the car back and fix it at zero expense to him. He declines, saying that he wouldn't trust us to do it again.
- Side note - GM has a recall for this happening to thousands of vettes, we have it happen to one.
- We also check out the bulletin after this happens from GM. GM states that a thrust washer, behind the crank pulley, needs to be replaced with a different one and a new crank bolt be installed WITH LOCKTITE. We were unaware of the locktite being required, which is understandable since it isnt even that way from the factory. We just followed procedure to replace the bolt and re-torque to factory specs. Again, we offered to fix everything and anything free of charge, John declined.
It is very unfortunate that something like this did happen, we did everything in our power to take the car back and fix it, again, free of charge.
In the end, John chose to have someone do the work on the car on the side. He wants us to pay for full price as if a dealership did the work, which we declined to do as well.
