***Vendor Warning***
Would you let them repair it or move on?
Then, would you think they would cover more than just their cost for parts, if you had another shop repair all thier mistakes?
Help me out with some advise here.........................Full story to follow.
I had a issue somewhat like this on my Eclipse a few years ago. My shop took it back and fixed it at no charge, no questions asked. They even changed my oil on top of it.
As for another shop fixing it, and having the first shop pay for it.....it's slim and none. And unfortunately, slim is on life support.
John - oneblackvette - came to us for heads and cam. We did the install, tuned the car, he picked the car up, it made 440 RWHP and at the end of the week he picked it up.
Monday I recieve a call, John says that the crank pulley bolt came loose and he was upset that it ruined his weekend. Understandable, who wouldnt be mad? I offer to take the car back and fix it at zero expense to him. He declines, saying that he wouldn't trust us to do it again.
- Side note - GM has a recall for this happening to thousands of vettes, we have it happen to one.
- We also check out the bulletin after this happens from GM. GM states that a thrust washer, behind the crank pulley, needs to be replaced with a different one and a new crank bolt be installed WITH LOCKTITE. We were unaware of the locktite being required, which is understandable since it isnt even that way from the factory. We just followed procedure to replace the bolt and re-torque to factory specs. Again, we offered to fix everything and anything free of charge, John declined.
It is very unfortunate that something like this did happen, we did everything in our power to take the car back and fix it, again, free of charge.
In the end, John chose to have someone do the work on the car on the side. He wants us to pay for full price as if a dealership did the work, which we declined to do as well.
It seems as if Straightline tried to do the right thing by making an attempt to repair the car. I think it is unreasable to expect them to pay for the repair at another shop. This is just my opinion though.
Dougie
Dougie
Dougie - again, another shop didnt, an individual did it on the side. Just trying to make sure that was noted.
Wow, very unfortunate indeed. I would have definitely offered to let the same shop do the repairs. Give the shop a chance to make amends, so at least(and hopefully) both parties walk away without a sour taste.
As for taking the car somewhere else and having the first shop pay for it.....that would never fly. Anywhere.
You said "No".
You then let a shadetree mechanic work on it and try to charge dealer rates. Shame shame shame.
You did NOT choose wisely grasshopper.
I think maybe before posting something like this you should have tried to exhaust every option with that particular vendor first. These guys are the ones that support us and bring us products and service and help maintain this virtual world we all like to participate in. Don't get me wrong, if there is something that was done wrong and you did get screwed, then we all should know about it. However, this post was probably a bit premature. Cars break, installs have issues. Give these guys a chance to stand up behind there products and service.
Dougie
Lack of a dealer invoice makes it shade tree. Where have you been.
Loose plug wire
Loose wheel
Crankbolt came out
Exhaust hitting trans and diff.
And now it seems wrong parts installed.
My question was, if someone did this to your car, would you let them have a second chance to do it again? The bolt I can maybe see the other things reflect poor workmanship that I did not want a second time.
Dougie
I think leaving parts loose on a car is wrong. Does not just happen. And I did try and work things out with them. But no way were they going to get to leave things loose again. I had my 5 year old with me when the belts flew off. Should I just be glad no one got hurt? And say oh they will do better the next time?
Loose plug wire
Loose wheel
Crankbolt came out
And my answer is still yes. Mainly because no shop is going to pay for work being done by someone who doesn't work for them. Now, if you would have taken the offer to have it repaired for free, and the same thing happened again, then you bring legal matters into it.
Furthermore, if what happened was in part, or fully due to overlooking a recall-and they even ponied up and admitted that-I would see that as a clear sign that they want to make things right, and not be so quick to write it off as poor workmanship. But that's just me.
It's very unfortunate what happened, but I honestly believe you went about it wrong.
#2- The shop offered to fix the problems- you should have brought it back to them, where they would of explained the situation and fixed it free of charge
#3- And now the exhaust is hitting the trans and diff.- again, explain that to the shop and they would probably again fix it free of charge if it was there fault
They gave you the opportunity to bring it back and have the problems fixed for free, should of taken them up on the offer, then if the same problems existed after that, you could start to complain
Two chances then legal?
