Drifting with an automatic?
Old Oct 2, 2007 | 07:48 PM
csun213's Avatar
csun213
Default Drifting with an automatic?
Since there are so many drafting movies out there, 2 of my friends were arguing about whether a car would have to have a manual transmission in order to drift. One guy said that you can drift with an auto while the other guy said no, you must have a manual transmission in order to drift.
Since I don't know the answer, I told them I would post on the corvette forum and see if anyone knows the answer to this.
So I would appreciate information on this. Thanks
Old Oct 2, 2007 | 09:23 PM
runutzzzzz's Avatar
runutzzzzz
All you need is power to break the rear tires loose in a turn to drift! You actually don't need that much power, you just need to pull the e-brake up You don't need an manual to do it.
Old Oct 2, 2007 | 10:48 PM
rollin18's Avatar
rollin18
Im pretty sure all you need is some deep water and mabey a sail f you want to drift fast... a good current helps also
seriously though, ive scene it done Both ways, you might check out some drifting forums.. seems like it would be easier with AT as you can work the breaks/ e break/ and gas/ steering wheel better
Old Oct 2, 2007 | 11:23 PM
LS1LT1's Avatar
LS1LT1
I've often wondered about that as well. Most well known/successful drift cars are in fact manual transmissioned, I think they need to be able to not only select a specific gear during a run but more importantly be able to hold it there. I would think that a paddle shift/A6 Corvette type of trans could be even better than messing with a clutch pedal in that regard.
If the rear would hold up I would think that a Corvette could make a decent drift car.
Old Oct 3, 2007 | 01:03 AM
thx007's Avatar
thx007
You can absolutely drift with an automatic. It is only a matter of power, balance and grip. When drifting a manual, you aren't using the clutch to break the tires loose, only the lateral g's of the car and power application. The same is easily done with an auto.
Old Oct 3, 2007 | 01:54 AM
Skunkworks's Avatar
Skunkworks
I would think a tight torque converter is a must, also not sure what additional torque management with A6 is going to do.
A manual would be more predictable IMO.
Mike
Old Oct 3, 2007 | 05:22 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
yes, you can drift with an automatic transmission. in the c6 you must turn off the 'driver aids' when/if you want to drift. the t/c and a/h will have fits if you try to drift with them on.
place the automatic in first or second and it will stay there it won't shift any higher, and you can drift all day.
Old Oct 3, 2007 | 05:44 AM
timd38's Avatar
timd38
Lets us know how long the trans lasts when you do this.
Those with curios minds would like to know.
Old Oct 3, 2007 | 10:35 AM
thx007's Avatar
thx007
I have repeatedly drifted several automatic equipped cars. My last car was a G35 with an automatic. It really isn't that hard on the transmission if you think about it. The tires have lost their grip and you are just applying a light throttle, feathering to keep everything in balance. You can take a professional drifter and give them an old Buick and it will drift. Other than the tires, the suspension takes more abuse that anything.
Old Oct 3, 2007 | 12:09 PM
csun213's Avatar
csun213
Thanks for all the answers. just to let you know that this question was not directed at using a corvette for drifting but just drifting in general.
Old Oct 3, 2007 | 12:32 PM
joegengsta's Avatar
joegengsta
1) hi tokyo drifter
2) buy a manual
3) problem with auto is that it will prematurely upshift around the actual bend.. not engaging the powerband... and have issues to 'power over'
4) talk to either paul walker, vin diesel, or johnny tran, they can help you out
Old Oct 3, 2007 | 01:11 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Oct 3, 2007 | 01:25 PM
jogar80's Avatar
jogar80
lol....well..........actually, neither paul walker, vin diesel, or johnny tran do any drifting, they are the quarter mile dudes. The drifters are all in "Tokyo Drift"
Old Oct 3, 2007 | 03:45 PM
Zig's Avatar
Zig
1) hi tokyo drifter
2) buy a manual
hah, that's funny.
remember, auto's can manually be put into 1st, 2nd, and sometimes 3rd, and turn off or don't select overdrive (if equipped).
Originally Posted by Dashti
Old Dec 20, 2017 | 12:47 PM
PILOTO AMATEUR's Avatar
PILOTO AMATEUR
1st Gear
Default I do dridting in my c4... and i have no hand brake
Hi, I drift my c4, it is automatic and i use no hand brake or ebrake... I certaily believe it is a very goodncar for drifting... However you need plenty of power to be able to lose the tires... When i first got it it was almos impossible to do it... The l98 didnt have the guts... But with the new 6.0 ls swap and 500rwhp at my dispossal it is quite easy...
People would talk sh..t about drifting but only skilled drivers can understand...
The answer is yes. They drift.
Old Dec 22, 2017 | 03:56 PM
mikeCsix's Avatar
mikeCsix
I've done it with my A-6, it was part of driver skills training with one of the local porsche clubs, done on a skid pad. It's fun to throttle steer the car in circles, and I could do it with someone else holding the wheel just using the throttle. It wasn't hard on the transmission, but the tires didn't like it much. Once they heated to grease it didn't take much throttle to keep everything in balance.
The bigger issue isn't the transmission - that just couples the engine power to the differential. The bigger issue is what type of differential is used. The positraction (both rear wheels are powered to ground) works better than the limited slip (one rear wheel that alternates between the two). I don't know if you can drift with a limited slip differential.
To Drifting with an automatic?
