Help ... False Hot Engine?
Old Oct 17, 2007 | 10:13 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default It's junk... Don't believe it....
Originally Posted by J HEBERT
I just replaced my laptop 3 months ago, at the time so many bugs w/ hptuner using vista, so I told them I wanted xp installed on my notebook, not vista..........guess what? The SOBs wanted 200.00 more because "microsoft comps them 200 a unit to install vista" according to the salesman who had to get a superior on the phone as he was loosing a 2,000.00 sale! In the end I got xp w/ no upcharge, and guess what? All the new drivers and bug fixes are out for vista....now
Vista is Junk...Don't believe it... All tuning EVERYTHING was designed PRE_VISTA....
It sucks. Even my new office machine sucks with Vista.....
It looks nice.....but does not work.
All my Vista stuff is up to date...and it still dosen't work with my tuning stuff....
Chuck CoW
Old Oct 29, 2007 | 09:38 PM
mitchm11741's Avatar
mitchm11741
Here's another update ... sorry to bring up an old thread but I thought some folks would want an update.
Have not had the false "hot engine" indication since pulling the battery terminal about two weeks ago. It was back this AM ... pretty cold out. Slow start and slow, easy warm up drive. After sitting at work all day in the cool weather, the temp gauge was working again tonight but the "Check Engine" symbol was on. Took it home, pulled the battery cable and it went out again. Can't keep doing this. Next time I am back up at Corvette's of Westchester, I think I will have Chuck put back the 180 t'stat (he did not install the 160 t'stat) ... unless one of you guys knows of a sure fire workaround or reason (other than disconnecting the battery).
Old Oct 30, 2007 | 12:26 AM
Silver05GTO's Avatar
Silver05GTO
What about warming up the car to at least 160 degrees before taking off? If you have Chuck look at it see if there is something that can be done about the CEL and t-stat. If not I may be heading where you are going (stock t-stat back in for winter)
Old Oct 30, 2007 | 07:39 AM
mitchm11741
I am going to try a warmup today. Temp is in the 40's so we'll see what happens.
Old Oct 30, 2007 | 07:48 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Could be a new problem is setting the check engine light. Did you check the code?
Old Oct 30, 2007 | 08:53 AM
NHRA95's Avatar
NHRA95
Originally Posted by Chuck CoW
Back to tuning again!
Chuck CoW
Do you have a tuning solution to this problem?
Old Oct 30, 2007 | 08:58 AM
6Speeder's Avatar
6Speeder
The solution is easy. There is one trouble code parameter you have to "unselect" when tuning and this will stop happening. I don't remember the code number but it is for "engine undertemp"
Old Oct 31, 2007 | 07:28 AM
mitchm11741
I will have Chuck look up this code. It is surprising that they would incorporate and "Engine Undertemp" parameter. My only guess on a reason for that for some reason the engine may have emmissions issues at low temp. Unless you are in northern Alaska, I don't think engine undertemperature is a real issue. Weird.
Old Nov 3, 2007 | 08:24 AM
Silver05GTO
Here's an update on my situation. Got the Engine Hot/AC off and CEL last night, came on after getting onto the highway headed to a resturant. After dinner started the car and sure enough the problem is still there, my fans are running at 100% too while the CEL is on (in an attempt to cool the motor despite it not being hot).
Looks like I'll be making a trip to CoW to tweak the tune or remove the 160 t-stat. For the slight gains it offers might not be worth dealing with this type of issue for 6 months out of the year.
Old Nov 3, 2007 | 08:35 AM
NHRA95's Avatar
NHRA95
And the code is?
Old Nov 4, 2007 | 06:45 AM
mitchm11741
I am with you on this. Please keep me (us) posted on how you resolve the issue (i.e. either tune it out or go back to 180 tstat).
Old Nov 4, 2007 | 09:11 AM
6Speeder's Avatar
6Speeder
The code number is P 0128
Deselect in your tune and all will be
Old Nov 5, 2007 | 09:50 PM
  #33
mitchm11741
Thanks! Hopefully, Chuck knows what to do with that parameter.
Old Nov 6, 2007 | 11:02 AM
  #34
edv2122's Avatar
edv2122
I was getting the same code off and on on cold nights with my 160 stat. I put my stocker back in for the winter yesterday.
Old Nov 6, 2007 | 11:33 AM
  #35
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Were I driving where the temperature can go to below freezing, rest assured that I would be running a stock t-stat to keep the engine warm and the temperature coming off the heater on the inside HOT. A 160 degree t-stat in the winter climates is not what I consider a good idea.
Hells bells, I'm in Florida and I'll keep the stock t-stat and not have over heating problems.
Drag race the car every week? Run the cooler t-stat. Drag race the car once in a while? Why bother with the 160 t-stat. Don't drag race the car? Fahgedaboudit.
My $.02
Elmer
Old Nov 6, 2007 | 11:34 AM
  #36
eboggs_jkvl
Moderator emeritus
He can put the "code" to sleep in 2 minutes.
Elmer
Old Nov 6, 2007 | 11:46 AM
  #37
6Speeder's Avatar
6Speeder
My $.02
Elmer
I ran a 160 in my convertible C5 year round. It gets in the 20's and 30's here and I was never cold. Heater worked just fine.
To Help ... False Hot Engine?
Old Nov 7, 2007 | 08:22 AM
  #38
Silver05GTO
Heading down to see CoW, I'll post my results here after, gonna have him unselect that Engine undertemp P 0128 code.
Old Nov 7, 2007 | 09:21 AM
  #39
eboggs_jkvl
Moderator emeritus
I'm sure that there are conditions where the engine temp will get toasty in the winter. My experience over a moderately long drive (2 or 3 hours), where the temperature is in the teens, will drop the engine temp down as low as the t-stat will allow and reduce mileage and also reduce the output temperature from the heater. Driving around town will not bother the heater of a car with a 160 t-stat.
Elmer
Old Nov 8, 2007 | 07:16 AM
  #40
mitchm11741
I'm scheduled for next Saturday. I look forward do hearing the results.
