C6 1/4 Mile Performance Challenge
Old Oct 31, 2007 | 11:19 PM
  #1981
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Originally Posted by dennis50nj
Thanks to Julio at Cartek for installing a new tune and enabling me to run an 11.51
Hey Dennis,
Great Run
It is the one who gets to the stripe first who wins
Old Nov 3, 2007 | 01:15 AM
  #1982
robertjr44's Avatar
robertjr44
C6 2005 A4 Z51
2.073
13.006
108.98
I would like to know what techniques some of you guys are you using to get in the 12's stock, I tried all kind of variations traction on/off.
Comp mode etc. any insight would be appreciatted.
This was my first time to the track in Baytown TX and drag racing period, I had a fantastic time despite not hitting under a 13 second run. I did manage to win all 6 runs against the cars I was racing against and had one reaction time of .103.
Old Nov 3, 2007 | 02:08 AM
  #1983
LS1LT1's Avatar
LS1LT1
Originally Posted by robertjr44
C6 2005 A4 Z51
2.073
13.006
108.98
Just some quick/simple tips...traction control OFF, run low fuel (around a 1/3 to a 1/4 tank, a quality brand premium grade only), do a strong burnout (if you're spinning which it looks like you were with that 2.07 sixty foot) and try to run on the cooler days/nights, you will see 12s soon.
Old Nov 3, 2007 | 04:41 AM
  #1984
11secondGP's Avatar
11secondGP
Alot of times missing...
Old Nov 3, 2007 | 01:47 PM
  #1985
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Your just looking to get banned...This list is ran by Tommy D, not you, follow his rules and i am sure your times will appear, or start your own thread with your own list and stop with the hyjacking.
Old Nov 3, 2007 | 09:54 PM
  #1986
siffert's Avatar
siffert
Default A Day At The Races, Part 2
This was my second trip to Thompson Raceway Park which closed down for the season today. Weather was almost the same from two weeks ago (49 degrees, humidity 49%, Altitude 1250, Pressure 30.08). Unlike two weeks ago when there were only 15 cars there (got 5 runs in 1/2 hour) there were 100+ so no quick hot lapping.
Only changes from two weeks ago was upping my fronts tires from 42 to 45 lbs, dropping my rears from 28 to 24-25, widened my propped shroud opening from 1.5" to 3.25" and disabling TM "Upshifts" with my new HP Tuner.
Normally my first run usually stinks, but this first run was a 12.619 @112.86 (1.964). I kinda eased into the throttle from idle launch on this run. My second run was the best of the day, 12.545 @114.010 (1.995) as I stomped on the gas from idle launch. I was hoping to break into the 12.4's but from there it was downhill (12.65's) for two more runs as the track started going away.
For the first time I was finally and consistently breaking into the 60' 1.9's which I attribute to a)launching from an idle and b)running 24-25 lbs hot on the rear tires). I figure turning off the TM "upshifts" was worth about 1 to 1.5 tenths of a second. My Modular Depot corrected time was Density Altitude 777 feet, 12.44 @114.94. Many thanks again to Glennhl for his help/advice and particularly turning me on to the HP Tuner.
Hi Tommy:
07 A6 - CB, open shroud
Old Nov 3, 2007 | 10:47 PM
  #1987
glennhl's Avatar
glennhl
Originally Posted by siffert
This was my second trip to Thompson Raceway Park which closed down for the season today. Weather was almost the same from two weeks ago (49 degrees, humidity 49%, Altitude 1250, Pressure 30.8). Unlike two weeks ago when there were only 15 cars there (got 5 runs in 1/2 hour) there were 100+ so no quick hot lapping.
Hi Tommy:
07 A6 - Catback, propped shroud, stat, tune
Absolutely great runs for an almost stock car!!!! Silver cars are always the quickest.
Old Nov 4, 2007 | 12:39 AM
  #1988
Tommy D's Avatar
Tommy D
C6 2005 A4 Z51
2.073
13.006
108.98
Marc (LS1LT1) pretty much covered the basics. How were you launching the car and how much air was in the rear tires.
Very nice numbers for your first time
Old Nov 4, 2007 | 01:48 AM
  #1989
11secondGP's Avatar
11secondGP
12.22@116.78
2008
A6
Base
2.73
Stock
K&N CAI, Shroud prop
12.3 Subie I raced on this run:
http://www.centralvalleyspeed.com/fo...ted=1#post9715
Old Nov 4, 2007 | 02:22 AM
  #1990
LS1LT1's Avatar
LS1LT1
12.22@116.78
Wow, your trap speeds are really all over the place, have you really trapped as low as 115+mph and as high as 119.5mph with the same set of mods and all in the same week?
Old Nov 4, 2007 | 03:14 AM
  #1991
11secondGP's Avatar
11secondGP
Yes, the second track day, traps increased as the humidity and temp dropped. Last three runs were 117.9, 118.8, 119.0
Still getting used to launching this car, only have 10 passes. I was getting better though, last three runs were also all 2.1 60's.
The first track day was better weather and I only got three runs in, trapped 119.5, 118.1, 119.5.
Old Nov 4, 2007 | 04:22 AM
  #1992
LS1LT1's Avatar
LS1LT1
Yeah weather can certainly make a difference but I've normally only seen that kind of disparity (over 4mph in your case) when going from like July to December weather changes or through major mod changes of course, just seems odd that the weather from one day to the next could make that much of a difference in traps but I guess it can.
Of course the launch/sixty foot/level of wheelspin can affect trap speeds as well but normally that applies more to a manual than an automatic.
I'm certainly not questioning your numbers but when I see odd/major swings like that I often wonder just how accurate/or how 'NHRA approved' the timing equipment is. I mean I'm the last person to be questioning stock/near stock automatic trap speeds, I've hit one of the highest (if not THE highest) stock LS2 trap speeds out there (115.91mph...and automatics typically trap much lower than manuals) and at the time I too thought that there was no way my car could do that so then I wondered about the timing lights.
But hey, if the time slip says it then it has to be true.
Old Nov 4, 2007 | 07:26 AM
  #1993
Patman's Avatar
Patman
I really don't have a lot of faith in the timing equipment for trap speeds, especially after I ran yesterday at the strip! On my first two runs of the day, the mph was insanely off, it said 335.32 mph on my first run, and 564.61 mph on the second run!!
Old Nov 4, 2007 | 07:49 AM
  #1994
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Those C5s tend to pick up a lot of power once their broken in.
Old Nov 4, 2007 | 07:52 AM
  #1995
dennis50nj's Avatar
dennis50nj
that 564.61 does definitely make you the fastest c5
Old Nov 4, 2007 | 08:47 AM
  #1996
'06 Quicksilver Z06
12.22@116.78
2008
A6
Base
2.73
Stock
Just a quick question if you don't mind.
I looked at this time slip and compared it to your others run on the same day, and the car number on this slip appears to look different than the ones on these submitted in this thread for 10/26/07.
http://forums.corvetteforum.com/show...postcount=2108
Most of them look like car 213 this one looks like 216 ????
Also, can anyone read the car number of the first and last yellow slip in the top row here. I am having a tough time making it out.
The first yellow, I believe is #232 because I can make out the trap speed and ET and it matches the large yellow #231 slip. The last yellow in that top row I am thinking is #216 because the numbers I can make out from it match the larger #216 slip.
http://forums.corvetteforum.com/show...postcount=2098
One here on the bottom row reads 231 vs 213.
I'm having a time following the slips here. Any help appreciated.
Thanks.
Old Nov 4, 2007 | 09:48 AM
  #1997
Patman's Avatar
Patman
Cool, I thought the fall air was making it run a lot faster!
Here's the slip by the way:
To C6 1/4 Mile Performance Challenge
Old Nov 4, 2007 | 11:21 AM
  #1998
8850's Avatar
8850
Pretty good mph Pat! I am planning a trip to the track today. Don't think I'll reach quite the 500 mph range but hopefully somewhere in the 100 range. Unfortunately the temperature for today is suppose to be 82*. Don't expect I'll run a best today.
Old Nov 4, 2007 | 11:57 AM
  #1999
jschindler's Avatar
jschindler
I thought about going out to the track tonight as well, but decided not to because of this weather. I did run the back roads over to Sugarland this morning for a cup of coffee - sure was a LOT of fog on the way out back down 1462 from Alvin and 762 to Greatwood!
  #2000
Patman's Avatar
Patman
It only felt like 550 mph honestly.
I wish there were some C6s at the track yesterday! It wasn't the best conditions I've seen, as the humidity was a bit high and barometer a bit low, but it was only in the mid 40s. DA was about -25 feet (not as good as the -1300 feet when I ran my 12.8 last fall)
An 08 running at sea level DA should have no problem running 12.0s to 12.1s. I'm still waiting for some more guys with 08s to report in this thread! Where are all the bone stock 08s on here?
