C6 1/4 Mile Performance Challenge
Old Jan 20, 2008 | 10:11 AM
  #2361
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Originally Posted by dennis50nj
congratulations Joe, i am positive you will drop ets big time even in hot weather, that's why you were the fastest ls2 manual on the list, and if you stayed bolt/on you probably would have went even faster. you moved up in performance with a cam, and most people don't understand you have to learn to drive that application all over again. you obviously hit on something to run that good in that DA, so now you will refine that technique and drop ets big time.
You're absolutely right, the car is a lot harder to launch with the big cam. I have to come out at 4500-4800 and walk the clutch perfectly. if I try to launch higher the tires will spin (had a couple of those launches) or below 4500 it'll bog - either way it's a 1.9 60 when I do that. I had 3 runs 1.719, 1.684 and 1.696 all resulting in 7.5's and 11.6's. My buddy has a 402 in a C5z and 480 ft lbs of torque, he can launch at 3000 and get 1.4's and 10 second slips.
I'm hoping the new Weiand intake gives me more low end torque - if it doesn't pan out I'll get a FAST. The low end torque kick from the FAST will help a lot in the 60ft.
Man the race is really at the first 60 ft isn't it.
Old Jan 20, 2008 | 03:05 PM
  #2362
LS1LT1's Avatar
LS1LT1
Very true, it's a whole new ballgame after going cam or heads/cam.
And what an awesome sound that cam makes too. (I heard the video).
Old Jan 20, 2008 | 05:13 PM
  #2363
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Thanks! The sound alone is worth the price. I do love it.
Old Jan 20, 2008 | 07:40 PM
  #2364
06C6FVR's Avatar
06C6FVR
Well, took the 07 to the track today
Wow, never thought the re-learning curve would be so steep. Havent driven a stick down the track since about a year ago.
1st pass- Clutch stuck to the floor....19.0 1/4 mile time..aborted
2nd pass- changed out the clutch fluid, ran 12.740 @113.30, not bad, but disapointed.
3rd pass- 12.603 @114.03, still not where I would like to be
4th pass (best one of the day)
60' 1.897
330 5.220
1/8 7.965
MPH 90.11
1000 10.316
1/4 12.303
MPH 113.36
Not quite what i was expecting, but I got tired of waiting over an hour between each pass, decided to go home. Im sure with a little more seat time in this car, ill get down to my 12.04 mark i set in my 06.
Mods are as follows: Tuning by Texas Speed and Performance and Drag Radials. Otherwise the car is bone stock. The car weighed 3475 with me in it (Car has Z06 Wide body kit, brakes, wheels and tires...heavier.
Car is an 07 3LT, M6. NON-Z51
Conditions were 47 Degrees, 50% humidity, At HRP in Baytown, Tx. (about 6 ft above sea level), which equates out to approximately Negative 1300 DA.
Overall, not too bad...Tommy, please add me again to the bolt on list.
Daren
Old Jan 20, 2008 | 09:23 PM
  #2365
jschindler's Avatar
jschindler
60' 1.897
330 5.220
1/8 7.965
MPH 90.11
1000 10.316
1/4 12.303
MPH 113.36
Daren
Daren - for such minor mods, that is still a damn good time. I know you'll knock it down even further. Congrats
Old Jan 20, 2008 | 09:39 PM
  #2366
Tony B4's Avatar
Tony B4
St. Jude Donor '08
Originally Posted by Joe_G
I'm finally learning how to drive my big cammed car on the strip. It's harder to launch with a 6 speed than the stock cam, I have to come out at 4500-4800 or I bog.
Tonight I got a personal best in 2300 DA (80 degrees 61% humidity):
60 - 1.695
330 - 4.899
1/8 - 7.512
1/8 mph - 94.00
1000 - 9.752
1/4 - 11.619
1/4 mph 121.19
Had a couple of 11.6 runs tonight. If we get some cooler weather I hope I can best these numbers. At 11.6 I'm not doing very well compared to others who are cam only.
Great Pass Joe !
Old Jan 20, 2008 | 09:41 PM
  #2367
Tony B4's Avatar
Tony B4
St. Jude Donor '08
06C6FVR,
60' 1.897
330 5.220
1/8 7.965
MPH 90.11
1000 10.316
1/4 12.303
MPH 113.36
Nice Pass!
Old Jan 21, 2008 | 03:35 AM
  #2368
LS1LT1's Avatar
LS1LT1
Those Z06 wheels, brakes and body panels do add some real weight to the car and outside of the few ponies that a tune might add you have no real power adding mods done...DRs do help so I think the car could have a 12.0 in it for sure.
Old Jan 21, 2008 | 09:45 AM
  #2369
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
are gtech time acceptable? i have a video to verify it
Old Jan 21, 2008 | 11:17 AM
  #2370
Joe_G's Avatar
Joe_G
St. Jude Donor '08
60' 1.897
330 5.220
1/8 7.965
MPH 90.11
1000 10.316
1/4 12.303
MPH 113.36
Daren
That is fantastic time on stock tires. No way I could do that. You need drag radials.
What are you launching at? If you can walk the clutch at 4500 on drag radials and get some 1.6's as I was doing the other night, you'd have your 11 second slip. Based on the splits you know how to shift.
Just for fun I compared our runs. You can get the shift points from the splits (60-330 is 1-2, 330-660 is 2-3, 1000-1320 is 3-4.
60 ft. I was .20 seconds faster, 1/4 was .68 faster, I gained 4.4 MPH in 1/8 to 1/14 trap delta, that's the big cam effect. I gained 27 mph, you gained 23. I beat you by two tenths at the 60 which translated to 6.8 tenths by the 1/4. That's the horsepower.
But you can sure shift that car (if I'm any barometer). I was faster than you by the following amounts:
1-2 shift .11
3-4 shift .12
1-2 shift .11
Since I've got 50 peak RWHP over you, you're a faster shifter than me!
That's just a very long winded way for me to say, I'm sure if you got some drag radials and came out at 4500, got a 1.65 60 ft. like I'm doing, you'd have an 11.9 slip in your hands.
Old Jan 21, 2008 | 11:49 AM
  #2371
06C6FVR's Avatar
06C6FVR
Hey Joe, I guess you missed the part where the only mods were Drag Radials and a Tune. !! I was launching at 4500, but my clutch was acting up a bit, so It wasnt completely holding at the launch. My other car went 1.72 on the same tires, So I know I can get in the 12.1's. and Gonna put the same mufflers i had on the other car, then prolly will run the same.
Thanks for the kind words on the shifting. Im not positive, but im very close to powershifting...barely lifting.
Daren
Old Jan 21, 2008 | 11:55 AM
  #2372
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Daren
I did miss that! I thought you had heavy 345 tires on it.
I was languishing with 1.8 60 fts for months with clutch troubles, spin or bog....guess what...I bought new DR's (mine were only a year old and had tread left) and boom - 1.7's and 1.6's. No other changes. DR's get old even though they look fine. You might buy a new set before the weather warms up!
Oh and I posted yesterday a dyno sheet of my car through the mufflers vs. cutouts open when I was bolt on only...no difference at all bypassing the mufflers. None. So don't expect any gain from changing out your mufflers, factory muffs flow very well. Now that I've got the cam I get 6 rwhp/tq from cutouts open but zero with bolt ons only.
Old Jan 21, 2008 | 12:15 PM
  #2373
06C6FVR's Avatar
06C6FVR
Actually, when I replaced the mufflers on my other car, i dynod before and after and got 7rwhp. (magnaflow 14336 weld in)
Daren
Old Jan 21, 2008 | 12:19 PM
  #2374
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Daren
Wow no kidding! I just sold my 14336 weld ins when I went cam only - they droned too bad for me without the cam and I was sure they'd be worse with the cam so I went to cutouts.
Old Jan 21, 2008 | 12:39 PM
  #2375
SinisterC6's Avatar
SinisterC6
Speedy
i didnt get a chance to go to the track last year but my Gtech recorded a 12.57 at 113.8 with 0-60 in 4.23s it was my 2nd attempt that day and 4th attempt since getting the car, im feeling i can get 12.50 at 114 with some more practice
Old Jan 21, 2008 | 03:06 PM
  #2376
LS1LT1's Avatar
LS1LT1
I would have to say that they aren't, they can be calibrated in and provide at least some accuracy but most will agree that ya really have to get out there on an official 1/4 or 1/8th mile track and see what she'll do.
Old Jan 21, 2008 | 06:30 PM
  #2377
mdrrandall's Avatar
mdrrandall
Originally Posted by mcv
I'm waiting for Engineering to give me the dyno sheets on this particular car, so I can post them. Obviously not 40 to 50 hp increase.
Typical timeslip from Oct 10 session, with stock intake configuration:
Sorry for such a late reply but I was here the night you were running the 08 with my 07 and my best previous had been a 12.1 but this night I was only able to run 12.3. I really want to buy a nice dr set up and what you had looked IDEAL. I have been trying to find a setup all winter with no luck. I would like a light wheel and a MT ET street tire which is what you had, can you give the exact info on your wheel and tire setup?
To C6 1/4 Mile Performance Challenge
Old Jan 21, 2008 | 07:38 PM
  #2378
SinisterC6's Avatar
SinisterC6
Speedy
with what i have planned i wont be happy until i break into 11s at 120, ill be staying with stock rubber for now
Old Jan 22, 2008 | 12:09 AM
  #2379
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order.
________________________________________ ________________________________________ _______
NEW or IMPROVED ELASPED TIMES
11.61 @ 121.19 Joe_G
12.30 @ 113.36 06C6FVR
Showroom Stock
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 Z51 M6 - (337)
12.31 @ 114.82 - CYA Vett - 05 F55 M6 - (679)
12.40 @ 114.70 - Jschindler - 08 Z51 M6 NPP - (2138)
12.42 @ 113.90 - DrRichie - 05 Z51 M6
12.49 @ 115.54 - 1.8T - 08 Z51 m6 - (2314)
12.49 @ 114.90 - Jschindler - 05 Z51 M6
12.53 @ 113.00 - Wicked07C6 - 07 Z51 M6 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 Z51 A6 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 Z51 A4 - (60)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.65 @ 111.65 - Zippin Zee - 05 Z51 M6 - (51)
12.66 @ 113.03 - Mdrrandall - 07 Z51 M6 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 Z51 A6 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 Z51 M6
12.71 @ 111.00 - Demented - 05 Z51 A4
12.72 @ 111.98 - SR0707 - 06 A6
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 Z51 A6 - (907)
12.79 @ 112.17 - Jchazr - 05 Z51 M6 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 Z51 A6 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 Z51 M6 - (498)
12.83 @ 109.44 - Tommy D - 05 A4 3.15 - (114)
12.84 @ 112.98 - Proney - 06 M6
12.85 @ 114.53 - Mr Z51 - 06 Z51 M6
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 F55 A4 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 Z51 M6 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 F55 A4 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 Z51 M6
13.25 @ 110.60 - C6 Matt - 05 Z51 M6 - (122)
13.26 @ 108.59 - Sfadchi - 06 Z51 A6 - (888)
13.26 @ 105.30 - Joeking - 05 Z51 A4 - (661)
13.30 @ 107.00 - Shurite44 - 06 Z51 A6 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 Z51 A4
External Engine Modifications (Bolt-Ons)
11.14 @ 121.59 - Dennis50NJ - 05 Z51 A4 - CAI, CB, conv, hdrs, 3.73, tune, DR - (2225)
11.44 @ 119.11 - Theofel - 08 A6 - CAI, CB, conv, hdrs, 315, tune, DR - (2108)
11.56 @ 118.82 - MCV - 08 Z51 M6 - CAI, DR - (1852)
11.70 @ 118.54 - Z51 6spd - 08 Z51 A6 Npp - El wp, hdrs, tune - (2175)
11.76 @ 119.00 - NastyC6 - 05 Z51 A4 - CAI, conv, hdrs, 3.73, ported int/tb, tune
11.77 @ 121.58 - Red06vette - 06 Z51 A6 - CAI, CB, hdrs, ported int/tb, tune - (2179)
11.80 @ 118.62 - 8850 - 08 A6 2.73 NPP - CAI, hdrs, tune - (2012)
11.81 @ 118.76 - Joe G - 05 Z51 M6 - CAI, hdrs, 3.90, ported int, tune - (1874)
11.84 @ 121.43 - C6 DVL - 08 Z51 M6 NPP -Blistens, CAI, hdrs, tune - (2066)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, CB, hdrs, conv, tune, DR - (839)
11.94 @ 117.99 - JimSpeed - 06 Z51 M6 - CAI, CB, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 Z51 M6 -CAI, hdrs, ported int, bilstein shocks, tune, DR - (2163)
11.98 @ 116.44 - C6speedjon - 07 Z51 M6 -CAI, CB, hdrs, ported int/tb, tune DR - (1970)
11.99 @ 118.51 - JMT1669 - 06 A6 - CAI, CB, tune - (2176)
12.01 @ 116.00 - Mr Z51 - 06 Z51 M6 - CAI, CB, hdrs, ported int, tune, DR
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, CB, hdrs
12.03 @ 118.43 - Glennhl - 06 Z51 A6 - CAI, hdrs, ported int, tune DRs - (2277)
12.04 @ 114.01 - 06C6FVR - 06 Z51 M6 - Mufflers, tune, DR - (1301)
12.05 @ 117.02 - CYA Vett - 05 F55 M6 - Hdrs
12.08 @ 117.00 - Forrest - 06 Z51 M6 - CAI, CB, hdrs, tune, DR - (1449)
12.13 @ 115.15 - Ben Diss -07 F55 M6- CAI, hdrs, Nitto Ivos, tune - (1919)
12.17 @ 119.00 - RHecox - 06 Z51 A6 - CAI, CB, hdrs - (1228)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, Kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 Z51 M6 - CAI, CB - (1822)
12.18 @ 114.00 - Toptoneone - 06 Z51 M6 - CAI, CB, hdrs, tune DR - (1824)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, CB, hdrs, Intake - (659)
12.26 @ 116.65 - Waveblaster785 - 06 Z51 A6 - CB, hdrs, Intake - (1118)
12.30 @ 113.36 - 06C6FVR - 07 M6 - Tune, DR - (2369)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, CB, hdrs, gears, tune - (368)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 Z51 A6 - CAI, TB, DR - (1473)
12.41 @ 115.40 - Icebourg - 05 Z51 M6 - CAI, CB
12.41 @ 114.85 - C5Pilot - 07 Z51 A6 - CAI, DR - (1182)
12.41 @ 112.07 - WS6JJP - 05 Z51 M6 - CB
12.42 @ 116.12 - YellowVette22 - 05 F55 M6 - CAI, CB, hdrs, DR - (393)
12.48 @ 114.40 - Mike Campbell - 06 A6 - CAI, stat - (1144)
12.48 @ 113.00 - Demented - 05 Z51 A4 - CAI
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, CB & hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, CB, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, CB, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 Z51 A6 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, CB, hdrs, tune - (1602)
12.53 @ 113.78 - Ultimate CC - 07 Z51 M6 - CAI - (1641)
12.54 @ 114.01 - Siffert - 07 A6 - CB, open shroud - (1990)
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, CB
12.54 @ 113.24 - NineBall - 05 Z51 M6 - stat
12.55 @ 115.85 - Yell03 - 06 M6 - CAI, CB
12.55 @ 114.95 - Shurite44 - 06 Z51 A6 - CAI, CB, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 Z51 A4 - CAI, CB, hdrs - (240)
12.57 @ 113.04 - Jschindler - 05 F55 M6 - CB - (241)
12.57 @ 110.67 - Yell03 - 05 A4 3.15 - CB - (464)
12.59 @ 114.89 - AZVette2005 - 05 Z51 M6 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.60 @ 114.00 - SScamaro - 05 Z51 M6 - CAI, CB, hdrs, tune - (59)
12.63 @ 112.35 - Lusky - 06 Z51 A6 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - Sditch - 05 Z51 A4 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 F55 A4 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 Z51 M6 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - tune - (1179)
12.80 @ xxx.xx - Thanos - 05 Z51 A4 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, CB, tune
12.89 @ 112.57 - Bunk22 - 05 Z51 M6 - CAI, CB, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 Z51 M6 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 Z51 M6 - tstat - (541)
12.93 @ 110.64 - C6Vette - 05 Z51 M6 - CAI, CB, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 Z51 M6 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 Z51 A4 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 Z51 M6 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 F55 M6 - CAI, CB - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 Z51 M6 - CB
13.95 @ 104.94 - Fright88 - 06 A6 -CB, hdrs - (1683) high alt
Internal Engine Modifications
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, CB, conv, H&C, hdrs, 3.42, intake, tune, DR
11.23 @ 123.00 - Texas Ranger - 06 M6 - CAI, CB, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.41 @ 123.84 - Evilways - 06 Z51 A6 - CAI, CB, cam, hdrs, L92/L76 Combo tune - (2087)
11.47 @ 123.01 - Thesubfloor - 07 A6 - CAI, cam, 3.15, hdrs, DR - (1933)
11.49 @ 125.62 - Wa$nt me - 06 Z51 M6 - CAI, CB, cam, hdrs, intake, udp, tune - (1610)
11.50 @ 125.76 - BlownV6 - 06 A6 - CAI, CB, H&C, hdrs, tune, DR
11.52 @ 125.73 - High Roller1 - 06 Z51 A6 - CAI, CB, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 F55 M6 - CAI, CB, H&C, hdrs, intake, tune -(871)
11.61 @ 121.19 - Joe G - 05 Z51 M6 - CAI, CB Cam, hdrs, 3.90, ported int, tune, DR - (2361)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
11.76 @ 116.76 - 1955 Belair - 05 Z51 A4 - CAI, CB, conv, H&C, hdrs, intake, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, CB, 3.15, H&C, hdrs - (1821)
11.80 @ 123.50 - Xstang - 05 Z51 M6 - CAI, 4.10, H&C, hdrs, tune, DR - (1178)
11.98 @ 120.87 - Mr Z51 - 06 Z51 M6 - CAI, Cam, 4.10, hdrs, ported int, udp, DR - (1265)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, Cam, hdrs & tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, CB, H&C, hdrs, intake, tune
Power Adders (supercharger, turbo, nitrous)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 - NO2, CAI, CB, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 Z51 M6 - SC with meth, cam, CB, hdrs, DR
10.86 @ 125.30 - JerryMuniz - 05 A4 - NO2, CAI, CB, conv, 3.73, hdrs, tune, DR - (480)
10.88 @ 132.41 - Todd@RPM - 05 A4 -TT 427, L92 heads, 3.42 RPM Trans DR (2273)
10.89 @ 129.93 - DTE - 05 A4 - Gears, Mufflers, Twin Turbo, DR - (939)
10.96 @ 129.73 - Blue Racer - 05 Z51 A4 - SC LPE 427 & RPM trans DR - (1795)
11.14 @ 123.59 - Soldsyclone - 06 A6 - NO2, CAI, hdrs, DR - (1950)
11.18 @ 125.42 - Stuart3232 - 06 Z51 M6 - NO2, CAI, CB, DR
11.21 @ 127.82 - Schilitj - 05 Z51 M6 - SC, CB, H&C, hdrs - (1235)
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, CB, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, CB, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - NO2, CAI, cam, hdrs, tune - (1900)
11.37 @ 126.64 - Nine Ball - 05 Z51 M6 - SC, CB, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - NO2, CAI, CB
1/8 mile (All entries)
7.60 @ 92.00 - Joe G - 05 Z51 M6 - CAI, 3.90, hdrs, ported int - (1803)
7.92 @ 92.06 - Socalz06 - 08 A6 - (2261)
8.02 @ 92.24 - Bunk22 - 05 Z51 M6 - CAI CB, hdrs, ported int, rockers & tune - (2236)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 - CAI CB, tune - (1664)
The bold numbers refer to the post number utilized to report the elasped times in this thread
Old Jan 28, 2008 | 01:57 PM
  #2380
06C6FVR's Avatar
06C6FVR
Tommy can you update my time for External mods
Run was at HRP.
Temp was 50 Degrees
Mods as follows
MTI excelerator cold air
Magnaflow weld in 14336 mufflers
160 Thermo
Re-Tuned for mods
BFG Drag Radials
As you can see, it would have been much better, but I bounced the rev limiter in 3rd, which is why my MPH is so low. I will get better!
I guess my other car wasnt a freak after all! Must be the driver mod!
Daren
