C6 1/4 Mile Performance Challenge
Old Mar 22, 2006 | 02:10 PM
  #441
LS1LT1's Avatar
LS1LT1
Originally Posted by DSOM Z51
If thats the case, and it is, then its more than likely the fact that one car may have been run at a negative DA, I recall Redgar saying that his weather station read -300 at noon, (I believe that you asked what it was in the morning) at that track, and another may not have been so fortunate.
Also many, Ranger and a few others come to mind, will tell you in a minute what DA their times were run in. Especially if it was an unusually low time. Some actually post the DA to further bolster their claim as if to say "no this was not run under optimum conditions" or "yes, I know this was run in ideal conditions."
Finally most people who run an unusually quick time will readily tell you that DA played a huge role in it. They will sometimes even give the weather conditions in the description of the run. It is curious that you are not as quick to acknowledge the same thing. Sure it was a great run. But it should be, and indeed will be, like it or not, pointed out by many, that it was run at a usually very well prepped track and at a negative DA.
It's curious? Would I have actually publicly asked Redgar what the DA was in MY OWN thread, well knowing that the air was good and it could potentially detract from my accomplishments on these boards, if I was curiously trying to hide something? No, I didn't come right out and say that the DA was relatively low or that track prep was good. But I also didn't blatantly state that my car has only 700 miles on it (it WILL get faster with more miles) or that there were cross and even headwind gusts of up to 25mph either, both of which would HELP my claims.
That track prep by the way meant little to NOTHING for my car was bogging horribly on launch, I should've run higher pressures in the rears and/or done less of a burnout, then maybe I would've been able to utilize some of that better traction that was available to me and it would've then also been more of a factor in this discussion.
In the case of stock and near stock automatic C5 and C6 Vettes, "driver skill" amounts to not much more than being able to do a burnout, being able to keep the wheels straight and being able to mash the gas pedal to the floor.
No arguement there, while I will claim that not all automatics are quite that simple to launch/race well, this was by far the easiest car I've ever had the pleasure of racing at a drag strip.
When you take that into account, its a bit presumptious to make a claim to the effect of having the "fastest automatic car here" or anywhere else for that matter. Just because you ran the fastest time on a given day in Jersey, does not mean that car is any "quicker" than one posting a time slip 3 tenths slower running in July in Miami.
Well then I guess really NO ONE, not John Force, not Kenny Bernstein, not even one of my local heros Ranger himself can really claim that they have the fastest car/track times of their type either if they don't correct their numbers.
Please be sure to go tell them all to give their trophies back.
Old Mar 22, 2006 | 02:14 PM
  #442
CYA-Vett's Avatar
CYA-Vett
Which car was yours? I was there Saturday too. Air was cool, but very, very windy. Did Edgar post the DA?
Dave
Old Mar 22, 2006 | 02:24 PM
  #443
LS1LT1's Avatar
LS1LT1
The list is a lot of fun and it is interesting to see what people have run.
But it can hardly be used for bragging rights.
When a guy says, his car is the "Quickest bone stock automatic Corvette ever?" and "Considering that the C6 autos are all faster than the C5 autos and that the C5 autos are generally faster then the C4s, is it possible that I own the fastest automatic Corvette sold to the public since like 1971? Maybe ever? Gotta do some research on that."
All that based on being at the top of that list, well I sure hope he is just kidding.
Kidding? Yeah for the most part I am because as many have stated this is all in good fun and most of these supposed world records are trivial and meaningless in the big picture.
But on the other hand if YOU were the one running the quickest time of it's type and were yet still humble enough (I'm not an egotistical person by any means, just want my piece of the pie ) to not even remotely mention the possibility that you might be THE fastest then I will accept some criticism/denial of my claims. Until then, show me the proof of a quicker/faster factory bone stock automatic Corvette (I do still believe that an L-88 or ZL-1 automatic might actually be quicker even on the crappy bias plies they came with) otherwise I still have to stand by my trivial and meaningless claims.
And as I've joked about previously, I do know that I have the fastest bone stock Velocity Yellow/black interior/comp grey wheeled automatic Corvette in Union County on a Wednesday, NO ONE can take that away from me.
Old Mar 22, 2006 | 02:27 PM
  #444
LS1LT1's Avatar
LS1LT1
We were there Sunday actually.
Yes, Edgar stated that his weather station read approxiamately -300 around noon or so.
Old Mar 22, 2006 | 03:22 PM
  #445
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Old Mar 22, 2006 | 06:10 PM
  #446
dennis50nj's Avatar
dennis50nj
Depending upon the density altitude, that 13.20 you ran may correct out to a higher or lower ET is what I'm saying. If you ran it at a DA of +2500 feet it will correct out to lower than 13.2 seconds.
You saying that they have different amounts of torque management in them?
yes I am. I believe different settings are at the programmers discretion and are probably set within a plus or minus setting within a specific setting.now saying that there is no reason for a stronger rear in a 06 c6 over 05 c6 unless more torque management was taken out for better 0 to 60 times. I have ran my car very hard no rear problems
Old Mar 23, 2006 | 12:12 AM
  #447
jchazr's Avatar
jchazr
I have a new personal best, please replace my old time! Stock Z51 1SB MN6, 8600 miles, stock runflats.
This was at Orlando Speedworld tonight. According to the corresponding METARs for Orlando airport, the DA was +243ft at the time I raced:
12.795 @ 112.17 mph
Also got a new best trap of 112.52 mph, although that was with a slower ET of 12.881 since I screwed up the 60' time. Anyhow, I've no doubt the car has 12.6's and possibly 12.5's once I get better, with the current DA conditions. I'd be interested in seeing what she could do at a better location with negative DA.
Here's a couple pics the girlfriend took:
Joe
Old Mar 23, 2006 | 01:17 AM
  #448
'06 Quicksilver Z06
Nice run Joe. Thanks for posting the DA you ran at.
Old Mar 23, 2006 | 07:58 PM
  #449
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
B]STOCK RUBBER CLASS [/B]
2005 (2006 Model year noted by 06)
Drag Radials posted below stock ETs
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest.
Bone stock
06C6FVR, Z51 ....12.23 @ 115.58 06
DrRichie, Z51 .... 12.42 @ 113.9
LS1LT1, Auto ..... 12.48 @112.11 06
David K, Z51 .......12.49 @116
Jschindler, Z51 .... 12.49 @ 114.9
Nine Ball, Z51 ..... 12.54 @ 113.24 (fan/stat mod)
Orange C6, Z51/auto .... 12.56 @ 112
Zippin Zee, Z51 .... 12.65 @ 111.65
Demented, Z51/auto ...... 12.71 @ 111
Shooter 49, Auto/3:15 .... 12.74 @108.67
Jelsis, Z51/Auto..... 12.77 @110.53 06
Jchazr, Z51 ...... 12.79 @112.17
Tommy D, Auto/3:15 .... 12.83 @109.44
Ginny C6, Auto/F55 .... 12.97 @ 108
Tampa Vet, Auto/3:15 .... 12.98 @108
C64ME, Z51 ........12.99 @111.7
Soldsyclone, Auto …….13.05 @ 108.7706
TMyers, Auto ...... 13.20 @ 108.91 06
C6 Matt, Z51 ........... 13.25 @110.6
JDWK, Z51 ………. 13.25 @108.4
Rich28, Z51/auto ...... 13.62 @ 106.18
Cai
Demented, Z51/auto ........ 12.48 @ 113
Sditch, Z51/auto ...... 12.65 @ 111.39
Cai, Larger Tires 325/30
Lusky, Z51/Auto.......12.63 @ 112.35 06
Cat Back
WS6JJP, Z51 .... 12.41 @ 112.07
Jschindler, F55/6sp ....... 12.57 @113.04
Waveblaster785, Auto ...12.5 @ 113.57 06
FLC6, Auto/3:15 .... 12.7@
Thanos, Z51/auto .... 12.8 @
Zoli007, Z51 ....... 12.97 @ 111.22 06
Parkev. Z51....... 12.99 @ 111.25
CorvettePilot, Z51 ..... 13.32 @108.87
Cat Back & Cai
Icebourg, Z51 ..... 12.418 @115.4
Anky1631, 6sp ..... 12.54 @ 113.63
FLC6, Auto/3:15 .... 12.55@
Cat Back & Cai Nitrous
FLC6, Auto/3:15 .... 11.89 @ 120.20
Cat Back & Cai, Tune
Dennis50NJ, Z51/Auto..... 12.38 @ 113.36 (stat mod)
Larry Chip, 6spd .... 12.5 @ 118
MickyC6, 6 spd ........12.88 @ 112.5
Headers
CYA Vett, 6 spd/F55 ........ 12.22 @117.02
Headers & Cat back
CTVette05, auto/3:15 .... 12.37 @ 112.29
Headers & Cat back, Cai
2003Anniversary, Z51/auto..... 12.55 @111.98
Headers, Cat back, Cai & Tune
SScamero, Z51 .... 12.6 @ 114
1955 Belair, Z51/auto ....12.938 @ 108.60
Headers, Cat back, Cai, gears & Tune
Nicodemus, 6spd ....... 12.37 @ 117.67
Headers, Cat back, Heads & Cam, Converter
Blue Racer, Z51/auto..... 12.1 @ 115.36
Headers, Cat back, Cai &Tune, Heads & Cam, Intake
Mitchell242, 6spd ....... 13.12 @ 119
Heads & Cam, Intake
Xstang, Z51....... 12.6 @ 118
Tune
Flooznie, auto .......12.50 @ 115.2
Drag Radials
Cai, Cat back, Headers
YellowVette22, 6spd/F55 .... 12.42@116.12
Cai, Cat back, Nitrous
Stuart3232, Z51..... 11.18 @ 125.42 06
Cai, Cat Back, Converter, Headers, Heads & Cam, Intake, Tune, UD
1955 Belair, Z51/auto ....... 11.76 @ 116.76
Cai, Cat Back, Converter, Headers, Heads & Cam, Intake, Tune, UD, gears & hardened output shafts
Tek-Nebie, Auto..... 10.87 @ 125.33
Old Mar 23, 2006 | 08:10 PM
  #450
CYA-Vett's Avatar
CYA-Vett
Can you fix me, its still embarrassing but getting quicker.
12.22 @ 117.02
Old Mar 23, 2006 | 08:56 PM
  #451
dennis50nj's Avatar
dennis50nj
12.22 @ 117.02
your really driving now good run
Old Mar 24, 2006 | 11:25 PM
  #452
JELSIS's Avatar
JELSIS
I set a new best at E-town today. Bone stock A6 12.703et at 112.43mph. The car felt strong, I tried to leave off idle and only managed a 1.996 60' , I usually hold the rmps up to 1500 and get 1.95 60' consistently. On my next two passes I left at 1500 and managed to get back to 1.95 60' but the car was hot and I could only get 12.72 and 12.74. at 111.8.
Old Mar 25, 2006 | 12:07 AM
  #453
CYA-Vett's Avatar
CYA-Vett
.2 with the intake, .1 with the tune...12.4's in a few weeks
Headers and converter, easy 11's.
Old Mar 25, 2006 | 12:12 AM
  #454
JELSIS's Avatar
JELSIS
11's
Old Mar 25, 2006 | 12:17 AM
  #455
CYA-Vett's Avatar
CYA-Vett
11's
Honestly, I think a converter may get you there. I've seen stock C5's run very low 12's with a 3,200 conveter. The headers will be a bonus.
Remember though, it is getting warmer out, from here on, your times will get worse until October....I'll be in touch, you should come up to Island with us for a bunch of practice runs...Poor track, lots of passes though.....We go almost every Friday night...
Old Mar 25, 2006 | 01:08 AM
  #456
Tommy D's Avatar
Tommy D
JimSpeed 11.94 on stock rubber
Bone stock
Jelsis, Z51/Auto..... 12.70 @112.43 06
Cai
Cat Back
Cat Back & Cai
Headers
Headers & Cat back
JimSpeed, Z51 ...... 11.94 @117.99 06
Heads & Cam, Intake
Tune
Drag Radials
Old Mar 25, 2006 | 01:09 AM
  #457
Tommy D's Avatar
Tommy D
12.22 @ 117.02
Fixed (sounds like something we do to animals)
To C6 1/4 Mile Performance Challenge
Old Mar 25, 2006 | 01:32 AM
  #458
Tommy D's Avatar
Tommy D
WOW
Bone stock
Cai
Cat Back
Waveblaster785, Auto ..12.53 @113.57 06
Cat Back & Cai
Headers
Headers & Cat back
Serendipity, 6spd ..... 12.03 @ 118.5 06
Heads & Cam, Intake
Tune
Drag Radials
Old Apr 2, 2006 | 10:59 PM
  #459
Tommy D's Avatar
Tommy D
Bone stock
Mr 35th, Z51 ...... 12.85 @ 114.53 06
Cai
Cat Back
Cat Back & Cai
Headers
Headers & Cat back
Heads & Cam, Intake
Tune
Drag Radials
Old Apr 9, 2006 | 05:55 PM
  #460
yell03's Avatar
yell03
Can I get my times added please???
Today (4/9/06) I ran my
2005 C6 Convertible A4/3.15 at ATCO
Stock except for a Magnaflow catback
1.927 60'
8.145@89.52 1/8
12.570@110.67 in the 1/4
Thanks,
Howard
