C6 1/4 Mile Performance Challenge
Larry
Ah yes....... both myself and my son sat on the parts for sale section just to get the set I have on the car. They are not that easy to find. I still have a lot of rubber on my goodyears so I am not in a rush to change anything just yet.
I still have some more bolt ons sitting uninstalled in my garage that could put be me very close to Marc on the list but I have not had the time to play.
1. Your entire profile completed
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. Year Corvette - 2008
5. Type of Trans - A6, stock converter
6. Type of Suspension - base
7. Stock Performance options- n/a
8. Tires utilized - M.T. ET Street DRs and borrowed skinnies in front
9. Modifications if any - A&A Corvette Si-trim supercharger (pullied down to 3.0"), 1 3/4" LT, ported intake/ t-body, meth kit, baby cam (220/220), 3.42 gear ratio, Corsa Sports.
10. Dyno numbers if you have them
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track - Dallas Raceway
___ Date of the pass & weather conditions - 11-20-10, warm and windy
___ 60'.............1.686
___ 330'...........4.575
___ 660'...........6.872
___ 660’ mph....104.19
___ 1000'.........8.841
___ 1320'.........10.494
___ 1320’ mph…134.50
The most significant change to the set up was a smaller supercharger pulley (was 3.4", now 3.0"). Bullet is the left lane car.
, 1 3/4" LT, ported intake/ t-body, meth kit, baby cam (220/220), 3.42 gear ratio, Corsa Sports.10. Dyno numbers if you have them
http://www.youtube.com/watch?v=1M1e9ZGhK60
http://s904.photobucket.com/albums/a...urrent=132.mp4
5. Type of Trans - M6.
6. Type of Suspension – Z51
7. Stock Performance options- npp exhaust option
8. Tires utilized – stock Goodyear run flats
9. Modifications if any - none.
___ Name of the Track – Maryland International Raceway
___ Date of the pass & weather conditions - 11-21-10, 63 degrees with the DA +150, and a 4 mph headwind
___ 60'.............1.828
___ 330'...........5.066
___ 660'...........7.764
___ 660’ mph....92.30
___ 1000'.........10.045
___ 1320'.........11.979
___ 1320’ mph…116.98
My car number is 324 and I was in the right lane.
Thanks again to Ranger for mentoring me, as I sure would not be here without his tutoring.
Frank "Evilways" warming up for another 11 second pass
Please see page 1 post # 6 for instructions & rules. In order to be placed on the list I need a complete timeslip & completed template in your post per the example.
THE LIST
Regarding correction factors:
Times are received from all over the country and are not corrected. Because track and weather conditions vary, this list ranking does not, and can not, identify the fastest cars or drivers in any particular order. It only lists the recorded times, regardless of conditions, in order from quickest to slowest. In cases where ET is the same, the higher MPH determines list order. The bold numbers refer to the post number utilized to report the elapsed times in this thread.
________________________________________ _________________
NEW or IMPROVED ELASPED TIMES
10.49 @ 134.50 Silverbullet
Showroom Stock LS2 (2005 -2007)
12.21 @ 115.45 - LS1LT1 - 06 A6 - (1282)
12.23 @ 115.58 - 06C6FVR - 06 M6 Z51 - (337)
12.29 @ 114.29 - Proney - 07 M6 - (4504)
12.31 @ 114.82 - CYA Vett - 05 M6 F55 - (679)
12.42 @ 113.90 - DrRichie - 05 M6 Z51
12.49 @ 114.90 - Jschindler - 05 M6 Z51
12.53 @ 113.00 - Wicked07C6 - 07 M6 Z51 - (918)
12.54 @ 113.59 - Tony 63 Vette - 06 A6 - (1514)
12.54 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1153)
12.56 @ 113.39 - Red Sleeper - 06 A6
12.56 @ 112.00 - Orange C6 - 05 A4 Z51 - (60)
12.63 @ 114.88 - Prankster - 06 M6 - (1625)
12.64 @ 108.69 - DMcRacer - 07 A6 Z51 - (4223)
12.65 @ 111.65 - Zippin Zee - 05 M6 Z51 - (51)
12.66 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1679)
12.69 @ 112.32 - Silverlx - 06 A6 - (876)
12.70 @ 112.43 - Jelsis - 06 A6 Z51 - (456)
12.70 @ 113.00 - Blackmajik - 07 A6 - (1631)
12.71 @ 111.30 - Flyin05 - 05 M6 Z51
12.71 @ 111.00 - Demented - 05 A4 Z51
12.74 @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.75 @ 109.25 - Ponchorello - 05 A4 3.15 - (994)
12.76 @ 112.57 - C5Pilot - 07 A6 Z51 - (907)
12.79 @ 112.17 - Jchazr - 05 M6 Z51 - (451)
12.80 @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1672)
12.81 @ 112.83 - Vette-oholic - 05 M6 Z51 - (498)
12.81 @ 110.95 - SkyKing - 07 A6 F55 - (2488)
12.85 @ 114.53 - Mr Z51 - 06 M6 Z51
12.93 @ 111.40 - DiggyMoe - 07 M6 - (969)
12.97 @ 108.00 - Ginny C6 - 05 A4 F55 - (60)
12.98 @ 108.00 - Tampa Vet - 05 A4 3.15 - (123)
12.99 @ 111.70 - C64ME - 05 M6 Z51 - (333)
13.04 @ 109.15 - TMyers - 06 A6 - (532)
13.05 @ 113.31 - RDunn - 06 M6 - (986)
13.10 @ 108.70 - Rothchilds - 05 A4 F55 3.15 - (1087)
13.12 @ 110.40 - JDWK - 05 M6 Z51
13.25 @ 110.60 - C6 Matt - 05 M6 Z51 - (122)
13.26 @ 108.59 - Sfadchi - 06 A6 Z51 - (888)
13.26 @ 105.30 - Joeking - 05 A4 Z51 - (661)
13.30 @ 107.00 - Shurite44 - 06 A6 Z51 - (769)
13.35 @ 108.10 - Phatpharmd - 06 A6 - (595)
13.62 @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - ????)
11.71 @ 119.94 - AndrewZPSU - 08 M6 - (2590)
11.80 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3482)
12.10 @ 117.60 - Dingrao - 08 A6 - (3567)
12.10 @ 115.19 - Odin - 09 A6 2.73 npp - (4329)
12.12 @ 116.59 - Pettvette - 08 A6 - (4282)
12.15 @ 115.59 - Old Goat - 09 A6 2.73 - (3712)
12.16 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2744)
12.18 @ 117.72 - Hardhattg - 08 M6 Z51 - (2690)
12.23 @ 112.86 - 940CACC - 08 A6 - (2880)
12.24 @ 117.83 - 74Vette - 08 M6 - (4621)
12.26 @ 115.22 - Oklahoma - 08 A6 - (3767)
12.27 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3251)
12.35 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2759)
12.26 @ 116.94 - TNorman - 08 A6 NPP - (4231)
12.40 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2138)
12.41 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3190)
12.41 @ 115.38 - HOXXOH - 08 A6 F55 - (2486)
12.42 @ 116.67 - Pea-Jay - 08 A6 - (4453)
12.49 @ 115.54 - 1.8T - 08 M6 Z51 - (2314)
12.55 @ 114.70 - Larry R - 08 A6 2.73 - (4058)
12.60 @ 114.12 - Beefcake - 08 A6 - (2882)
12.65 @ 114.99 - PhillyLS1 - 09 M6 - (3156)
12.66 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2834)
12.91 @ 111.67 - Brewcitygymratt - 06 A6 - (4582)
13.35 @ 110.78 - M453W - 09 A6 NPP- (4061)
13.42 @ 109.32 - Dan Wendling - 09 A6 NPP - (4036)
External Engine Modifications LS2 (Bolt-Ons)
10.62 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, hdrs, 3.73, ptb, tune, & more DR - (3948)
10.92 @ 125.13 - LS1LT1 - 06 A6 - CAI, Conv, fast, hdrs, ptb, skinnies, tune, DR - (4305)
11.12 @ 123.23 - Dicky - 06 A6 - CAI, Conv, cutouts, fast, 3.42, hdrs, tune, DR - (4358)
11.29 @ 122.24 - JMT1669 - 06 A6 - CAI, Conv, cb, hdrs, fast, 3.42, tune, DR - (4431)
11.34 @ 125.78 - Silvervette05 - 05 M6 – Z06 exhaust, pfast/tb, gto skinnys nitto555 tune - (4426)
11.58 @ 119.12 - FloydSummer of 68 - 07 A6 - CAI, Conv, hdrs, no cats, tune, DR - (4604)
11.67 @ 118.76 - Its Stock - 06 M6 - CAI, , hdrs, udp, tune, DR - (4569)
11.74 @ 120.83 - Siffert - 07 A6 - CAI, cb, hdrs, pfast, tune, DR - (3986)
11.76 @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, hdrs, 3.73, pi & tb, tune
11.77 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdrs, pi & tb, tune - (2179)
11.79 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, muff, tune, DR - (3231)
11.81 @ 118.76 - Joe G - 05 M6 Z51 - CAI, hdrs, 3.90, pi, tune - (1874)
11.87 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdrs, pi, tune, DR - (3558)
11.87 @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdrs, tune, DR - (839)
11.94 @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdrs - (521)
11.96 @ 118.98 - GMRULZ - 06 M6 Z51 -CAI, hdrs, pi, bilstein shocks, tune, DR - (2163)
11.98 @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdrs, pi & tb, tune, DR - (1970)
12.01 @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdrs, pintake, tune, DR
12.03 @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdrs
12.03 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdrs, pi, tune, DR - (2277)
12.05 @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdrs
12.05 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, hdrs, tune, 3.73, DR - (4471)
12.08 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdrs, tune, DR - (1449)
12.13 @ 115.15 - Ben Diss -07 M6 F55 - CAI, hdrs, tune, Nitto Ivos - (1919)
12.17 @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdrs - (1228)
12.17 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2189)
12.18 @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1822)
12.18 @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdrs, tune, DR - (1824)
12.21 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1323)
12.22 @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdrs, tune - (1706)
12.26 @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdrs, - (659)
12.26 @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdrs, - (1118)
12.27 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdrs, Z06 Muff, tune - (4227)
12.31 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdrs, tune - (3629)
12.31 @ 114.43 - Mike Campbell - 06 A6 - CAI, - (4440)
12.37 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, hdrs, gears, tune - (368)
12.37 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdrs - (69)
12.39 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1473)
12.39 @ 114.83 - DMcRacer - 07 A6 Z51 – CAI, Continental tires - (4526)
12.42 @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdrs, DR - (393)
12.49 @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdrs
12.49 @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdrs, tune, DR - (1249)
12.50 @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (177)
12.50 @ 115.20 - Flooznie - 05 A4 - tune - (216)
12.51 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (492)
12.52 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdrs, tune - (1602)
12.52 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdrs, tune - (4408)
12.53 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.53 @ 113.53 - Vade46 - 07 M6 Z51 - CAI, CB - (4280)
12.54 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4576
12.54 @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55 @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdrs (843)
12.55 @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdrs - (240)
12.59 @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdrs, tune - (202)
12.59 @ 113.46 - Badassbu - 07 A6 - CAI - (1769)
12.60 @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (59)
12.62 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4525)
12.63 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63 @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65 @ 113.70 - Hitman99 - 06 A6 - CAI, hdrs, tune
12.65 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2601)
12.68 @ 113.92 - Sditch - 05 A4 Z51 - CAI - (188)
12.71 @ 113.70 - C6Brian - 07 M6 - Tune - (1616)
12.72 @ 110.85 - AngeloC6 - 05 A4 F55 3.15 open shroud - (1654)
12.77 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1269)
12.78 @ 112.50 - Dan-t - 06 A6 - Tune - (1179)
12.79 @ 115.58 - Sebaj - 05 M6 - CB, Z06EM, pi & tb, ud, Tune - (4439)
12.80 @ xxx.xx - Thanos - 05 A4 Z51 - CB - (59)
12.83 @ 111.00 - TMyers - 06 A6 - CAI, tune - (768)
12.88 @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.89 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdrs rockers, tune - (860)
12.89 @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(830)
12.90 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (541)
12.93 @ 110.64 - C6Vette - 05 M6 Z51 - CAI, cb, tune - (1206)
12.97 @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (226)
12.97 @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdrs, tune - (697)
12.99 @ 111.25 - Parkev - 05 M6 Z51 - CB - (83)
13.30 @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1041) high alt
13.32 @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.95 @ 104.94 - Fright88 - 06 A6 - CB, hdrs - (1683) high alt
External Engine Modifications LS3 (Bolt-Ons)
11.21 @ 121.18 - Theofel - 08 A6 - CAI, cb, conv, hdrs, 315, tune, DR - (4594) [SIZE=1]
11.25 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, hdrs, pi, 3.73, torco & meth inj, tune DR - (3743)
11.49 @ 121.65 - HOXXOH - 06 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, DR - (4334)
11.51 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdrs, ptb, Z06rear, tune, Invos - (3569)
11.51 @ 120.32 - 8850 - 08 A6 NPP 2.73 - CAI, hdrs, tune Invos - (4587)
11.53 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdrs, ptb udp, tune, - (3737)
11.55 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdrs, fast, 3.90, Et St - (3089)
11.56 @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdrs, pi & tb, tune DR - (2409)
11.56 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1852)
11.61 @ 120.86 - HPAvette - 08 A6 – CAI, hdrs tune DR - (3649)
11.63 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx hdrs, tune (4632)
11.68 @ 121.22 - Socalz06 - 08 A6 - CAI, hdrs, DR - (2594)
11.70 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdrs, tune - (2175)
11.72 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdrs, tune DR - (4425)
11.79 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdrs, tune Nitto Ivos - (3790)
11.98 @ 120.04 - Rock n' Blue08 - 08 M6 -CAI, hdrs, 3.90, Xpipe Z06 muff, - (2894)
11.99 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdrs, tune, DRs - (2471)
11.99 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdrs, tune - (4436)
12.00 @ 116.49 - Chets Z06 - 08 M6 - Nittos - (4479)
12.01 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdrs, pi, ud, tune, DR-(4477)
12.01 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4602)
12.03 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdrs, tune - (2529)
12.04 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3529)
12.10 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4224)
12.12 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3145)
12.17 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3544)
12.26 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdrs - (3931)
12.34 @ 118.40 - Airbuspilot - 08 M6 - CB - (3715)
12.46 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdrs, tune - (2910)
12.71 @ 112.79 - Gfish - 08 A6 Z51 NPP - CAI, tune - (4437)
13.33 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2706)
External Engine Modifications Grand Sport (Bolt-Ons)
11.94 @ 118.55 - Agent White - 10 A6 GS NPP - CAI, hdr tune - (4581)
Internal Engine Modifications LS2
10.58 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast H&C, hdrs, 4.10, 100maf, tune, DR - (4334)
10.59 @ 130.09 - Dennis50NJ - 05 A4 Z51 - CAI, cam, cb, conv, ewp, pfast, hdrs, 3.73, ptb, tune, DR - (4302)
10.66 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, hdrs, H&C pfast, 4.10 tune, DR - (4300)
10.82 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C hdrs, udp, tune, & more DR - (4583)
10.84 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdrs, ported int/tb, udp DR - (4014)
10.87 @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, H&C, hdrs, 3.42, intake, tune, DR
10.90 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdrs, tune, DR - (3691)
10.96 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdrs, PI, PTB, Z06 Muff, tune, DR - (4416)
11.01 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, Conv, H&C hdrs, 3.15, tune, DR - (4615)
11.03 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdrs, tune, DR - (3923)
11.19 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdrs, pi & tb, udp DR - (4260)
11.19 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdrs, L92/L76 combo tune, Dr - (4079-80)
11.22 @ 125.19 - Joe G - 05 M6 Z51 - CAI, cb, cam, hdrs, 3.90, pfast, tune, DR - (4330)
11.20 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdrs, no muff, tune,DR - (2478)
11.23 @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, hdrs, 4.10, udp, tune, Z06 tires - (1696)
11.35 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, hdrs, pfast/tb, tune, DR - (3472)
11.46 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdrs, pi - (2847)
11.49 @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast hdrs, udp, tune - (1610)
11.52 @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdrs, udp, tune, DR - (1909)
11.53 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdrs, tune -(871)
11.55 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdrs, susp, tune, DR - (2757)
11.76 @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdrs, tune, DR
11.79 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdrs - (1821)
11.98 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdrs, pi, udp, DR - (1265)
11.99 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdrs, fast udp, tune, DR - (4465)
12.12 @ 118.27 - Sebaj - 05 M6 - CB, H&C,Z06EM, pi & tb, ud, Tune PS2 - (4547)
12.31 @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdrs, tune
13.12 @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdrs, tune
Internal Engine Modifications LS3
10.61 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdrs, pi, tune, Z06 susp,DR - (4621)
10.63 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3644)
10.66 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, H &C CAI, hdrs, 3.90, tune, DR - (3198)
10.73 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, ported tb/int, udp tune, DR - (3972)
11.03 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdrs, tune, DR - (3900)
11.10 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdrs, shaneTB, tune, DR - (4073)
11.14 @ 129.27 - AndrewAPSU - 08 M6 - CAI, cam, hdrs, Z06 Exhaust, DR - (4211)
11.17 @ 120.58 - Texasranger - 08 A6 - CAI, cam, hdrs, 3.15, tune, DR - (2805)
11.94 @ 121.11 - Beefcake - 08 A6 - CAI, cam, hdrs, tune -(3039)
Power Adders LS2 (supercharger, turbo, nitrous)
9.73 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, hdrs, RPM trans, 3.42 , tune, DR - (3262)
9.93 @ 136.88 - Tekhombre - 05 M6 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune - (1157)
10.29 @ 138.17 - BlownV6 - 06 A6 – N2O, CAI, cb, H&C, hdrs, tune, DR
10.29 @ 135.00 - Willisfast - 06 M6 Z51 - SC with meth, cam, CB, hdrs, DR
10.68 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdrs, DR - (4221)
10.86 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdrs, tune, DR - (480)
10.89 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (939)
10.99 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, cb, hdrs, tune, - (3300)
11.07 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdrs, DP, DR - (3665)
11.09 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdrs, DR - (2825)
11.18 @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.28 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1652)
11.28 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdrs - (1804)
11.31 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdrs, tune - (1900)
11.37 @ 135.29 - Turboffr - 06 M6 Z51 - CAI, cam, hdrs, fast SC, meth, udp, tune, DR - (4520)
11.37 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdrs, tune, DR - (589)
11.40 @ 121.47 - C6 Roller - 05 A4 - SC, hdrs, DR - (1772)
11.89 @ 120.20 - FLC6 - 05 A4 3.15 - N2O, CAI, cb
Power Adders LS3 (supercharger, turbo, nitrous)
10.49 @ 134.50 - Silver Bullet C6 - 08 A6 - supercharger, alky, cam, cb, hdrs, pi & pt, DR - (4649)
10.55 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdrs, DR - (3238)
10.87 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdrs, SC, tune, DR - (3903)
11.30 @ 124.45 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune - (4222)
Larger Displacement (All entries)
9.51 @ 148.77 - Todd@RPM - 05 A4 -TT, 427, fuel sys, L92 heads, 3.42, RPM Trans DR (4278)
9.65 @ 141.11 - Tluck - 05 A4 Z51 - 402 cid, ccw drag pack, 373, N20 & more, DR - (3922)
9.89 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, DR - (4277)
9.95 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, Tune, DR (4469)
10.41 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, .3.42, hdrs, tune, DR - (4198)
10.41 @ 132.71 - Craftfox - 07 A6 Z51 – 440, conv, fast, 3.42, hdrs, tune, DR - (4469)
10.68 @ 133.21 - Schilitj - 05 M6 Z51 - 402, SC, cb, H&C, hdrs - (3529)
10.76 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (782)
11.43 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416 cid, conv, H &C p/fast,& tb, tune, Nitto Ivos - (3740)
11.68 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (662)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.94 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, H&C, fast, ptb, 100maf, tune, DR - (4361)
7.00 @ 99.44 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdrs, tune, DR - (3690)
7.19 @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdrs, DR - (3782)
7.21 @ 95.10 - Joe G - 05 M6 Z51 - CAI, Cam, 3.90, pfast, hdrs, - (3793)
7.27 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.27 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdrs, pi & tb, C5-3.90, tune DR - (4534)
7.34 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdrs, pintake/TB, udp, tune, DR - (3056)
7.36 @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdrs, 3.90, Et Street - (2863)
7.50 @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi & tb, hdrs, tune PS2s - (3081)
7.65 @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdrs, tune Dr - (3558)
7.79 @ 93.72 - DavetteGuy - 08 A6 - CAI, Ptb tune - (4563)
7.83 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdrs, pi, nitto ivos - (4164)
8.09 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4046)
8.45 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1664)
DA http://www.dragtimes.com/da-density-...calculator.php
Thank You CALLAWAY for sponsoring the C6 Tech & Perf section & making this list possible
and to ALL
Have a very happy Thanksgiving
1.92 60 ft
7.0x @ 109.3
Ill post the slip soon. Should have a 10.teen in it when she doesn't bog at 141ish. Not bad for a full weight stick car with only cam, exhaust and spray. Car is a 08 ls3 with stock heads and intake, vararam and 3.90s. I was on a 17 inch MT2
We had killer DA yesterday at Infineon (it started off at -1400ft and never got above -500ft) but because of the rain the night before they decided to only run the 1/8th but I actually kind liked that since I didn't have to slow the car down like I usually do for the 1/4 mile.
As such, I have a new time to submit as shown below. The mods are unchanged since my last submission but I can repost them if necessary.
It would have been sooooo nice if we had been able to run the 1/4 mile because that 6.519 is only .15 seconds off the 1/8th mile MPH of my 9.950 which means it would have been a 10.0xx pass. Oh well, that's what Test & Tunes are for I guess.
