C6 1/4 Mile Performance Challenge
Lmk when you're headed back to the track again as I'm itching to go and try to squeeze off a 10.7 as well, but may not happen as they won't run if it's below 50*:-/
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post #: Time Slip Posted Below
3. The complete the details of your pass using this template in your post:
4. Year Corvette: 2008
5. Type of Trans: A6
6. Type of Suspension: z51
7. Stock Performance options (as in optional gears with the automatic, & etc.) Stock z51 2.73 Gears, Stock NPP exhaust
8. Tires utilized: Nitto Invo 285/30/19 on Gumbies
9. Modifications: Haltech Beehive, AR Headers, Tune
10. Dyno numbers if you have them: None
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: launched from idle, 20 psi rear tires and 35 psi front tires, Ran in S mode, 1/2 a tank of gas. First run out with the car and there was a 25mph head wind
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track: Dallas Raceway
___ Date of the pass & weather conditions: 3/5/13 25mph (average) headwind and 62°
___ 60'.............2.004
___ 330'...........5.291
___ 660'...........7.940
___ 660’ mph....92.98
___ 1000'.......... 10.210
___ 1320'..........12.118
___ 1320’ mph….116.77
Hoping to go back and dip into the 11s without the headwind. My 60's suck...I know. I jammed on the gas instead of rolling onto it. I'm pretty sure it's an 11 second car on DRs but I want 11s on street tires.
Category :external mod ls-2
1. Your entire profile completed & read Instructions:check
2. A copy of your entire time slip posted to the thread as in post # _____
4. Year Corvette2006
5. Type of TransA6
6. Type of Suspensionbone stock
7. Stock Performance options (as in optional gears with the automatic, & etc.)none
8. Tires utilizedstock size Hankook ventus v12 evo k110
9. Modifications if any10% under-driven hb, stock Diablo tune, Flowmaster catback
10. Dyno numbers if you have themnone
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc32psi rear 35psi front, Maybe 1900rpm launch at most
___ Name of the TrackOrlando speed world
___ Date of the pass & weather conditions3-8-13, high 50's low 60's no wind about 50% humidity (rough guess)
___ 60'.............1.950
___ 330'...........5.386
___ 660'...........8.110
___ 660’ mph....91.35
___ 1000'.........10.449
___ 1320'.........12.384
___ 1320’ mph…116.78
Copy of Time Slip Below
Three runs this night, this being my quickest and fastest but slowest rt. My best rt was .044
12.118 @ 116.77 MBB
12.384 @ 116.78 Goatdad
If your time has not been posted it is because you have not followed the requirements for posting your time. I need the entire time slip as well as the template included in your request as required on page one.
Historical Record:
Showroom Stock LS2 (2005 -2007)
12.215 @ 115.45 - LS1LT1 - 06 A6 - (1278)
12.235 @ 115.58 - 06C6FVR - 06 M6 Z51 - (333)
12.290 @ 114.29 - Proney - 07 M6 - (4500)
12.314 @ 114.82 - CYA Vett - 05 M6 F55 - (675)
12.422 @ 113.90 - DrRichie - 05 M6 Z51
12.499 @ 114.90 - Jschindler - 05 M6 Z51
12.53x @ 113.00 - Wicked07C6 - 07 M6 Z51 - (914)
12.540 @ 113.59 - Tony 63 Vette - 06 A6 - (1510)
12.548 @ 113.74 - Tony96LT4 - 06 A6 Z51 - (1149)
12.56x @ 113.39 - Red Sleeper - 06 A6
12.56x @ 112.00 - Orange C6 - 05 A4 Z51 - (56)
12.650 @ 111.65 - Zippin Zee - 05 M6 Z51 - (48)
12.665 @ 113.03 - Mdrrandall - 07 M6 Z51 - (1675)
12.693 @ 114.88 - Prankster - 06 M6 - (1621)
12.69x @ 112.32 - Silverlx - 06 A6 - (872)
12.703 @ 112.43 - Jelsis - 06 A6 Z51 - (452)
12.70x @ 113.00 - Blackmajik - 07 A6 - (1627)
12.71x @ 111.30 - Flyin05 - 05 M6 Z51
12.71x @ 111.00 - Demented - 05 A4 Z51
12.74x @ 108.67 - Shooter 49 - 05 A4 3.15 - (39)
12.756 @ 112.57 - C5Pilot - 07 A6 Z51 - (903)
12.757 @ 109.25 - Ponchorello - 05 A4 3.15 - (990)
12.795 @ 112.17 - Jchazr - 05 M6 Z51 - (447)
12.80x @ 111.00 - SheDevilC6 - 07 A6 Z51 - (1668)
12.81x @ 112.83 - Vette-oholic - 05 M6 Z51 - (494)
12.817 @ 110.95 - SkyKing - 07 A6 F55 - (2480)
12.85x @ 114.53 - Mr Z51 - 06 M6 Z51
12.917 @ 111.67 - Brewcitygymratt - 06 A6 - (4578)
12.936 @ 111.40 - DiggyMoe - 07 M6 - (965)
12.97x @ 108.00 - Ginny C6 - 05 A4 F55 - (56)
12.98x @ 108.00 - Tampa Vet - 05 A4 3.15 - (119)
12.99x @ 111.70 - C64ME - 05 M6 Z51 - (329)
13.04x @ 109.15 - TMyers - 06 A6 - (528)
13.054 @ 113.31 - RDunn - 06 M6 - (982)
13.10x @ 108.70 - Rothchilds - 05 A4 F55 3.15
13.12x @ 110.40 - JDWK - 05 M6 Z51
13.25x @ 110.60 - C6 Matt - 05 M6 Z51 - (118)
13.267 @ 108.59 - Sfadchi - 06 A6 Z51 - (884)
13.26x @ 105.30 - Joeking - 05 A4 Z51 - (657)
13.30x @ 107.00 - Shurite44 - 06 A6 Z51 - (764)
13.35x @ 108.10 - Phatpharmd - 06 A6 - (591)
13.62x @ 106.18 - Rich28 - 05 A4 Z51
Showroom Stock LS3 (2008 - 2013)
11.718 @ 119.94 - AndrewZPSU - 08 M6 - (2586)
11.806 @ 118.82 - Gmrulz - 08 A6 Z51, NPP - (3478)
11.974 @ 116.98 - Proney - 08 M6 Z51, NPP - (4652)
12.058 @ 122.05 - AndrewZPSU - 10 A6 NPP - (5051)
12.100 @ 115.19 - Odin - 09 A6 2.73 npp - (4325)
12.102 @ 117.60 - Dingrao - 08 A6 - (3561)
12.127 @ 116.59 - Pettvette - 08 A6 - (4278)
12.159 @ 115.59 - Old Goat - 09 A6 2.73 - (3708)
12.167 @ 117.15 - DarkOctane - 08 A6 NPP - (6310)
12.167 @ 116.54 - Vinsane112 - 08 A6 2.73 - (2740)
12.186 @ 117.72 - Hardhattg - 08 M6 Z51 - (2686)
12.237 @ 112.86 - 940CACC - 08 A6 - (2871)
12.244 @ 117.83 - 74Vette - 08 M6 - (4617)
12.400 @ 116.36 - RandyDank23 - 08 A6 - (6059)
12.262 @ 115.22 - Oklahoma - 08 A6 - (3765)
12.276 @ 118.66 - EZ28 - 08 M6 Z51 NPP - (3247)
12.355 @ 117.47 - Bain - 08 A6 NPP 2.73 - (2755)
12.357 @ 116.94 - TNorman - 08 A6 NPP - (4227)
12.409 @ 114.70 - Jschindler - 08 M6 Z51 NPP - (2132)
12.419 @ 116.15 - JTorchz06 - 09 A6 Z51 NPP - (3185)
12.412 @ 115.38 - HOXXOH - 08 A6 F55 - (2478)
12.428 @ 116.67 - Pea-Jay - 08 A6 - (4448)
12.494 @ 115.54 - 1.8T - 08 M6 Z51 - (2310)
12.500 @ 115.53 - Shane Fap - 08 A6 - (6298)
12.514 @ 116.73 - SK360 - 08 A6 2.73 - (6283)
12.552 @ 114.70 - Larry R - 08 A6 2.73 - (4054)
12.600 @ 114.12 - Beefcake - 08 A6 - (2875)
12.658 @ 114.99 - PhillyLS1 - 09 M6 - (3151)
12.668 @ 113.61 - CFP40 - 08 A6 NPP 2.73 - (2828)
12.689 @ 112.07 - Bfppt1 - 10 A6 - (5300)
12.747 @ 114.31 - Detoxx03 - 08 M6 NPP- (4057)
13.354 @ 110.78 - M453W - 09 A6 NPP- (5708)
13.428 @ 109.32 - Dan Wendling - 09 A6 NPP - (4032)
Showroom Stock LS3 Grand Sport (2010 - 2013)
12.319 @ 115.75 - Grand SportMan - 10 A6 - (5128)
12.559 @ 115.41 - Fastenuf - 11 A6 - (5269)
12.805 @ 113.33 - PhillyLS1 - 11 M6 NPP - (5085)
________________________________
External Engine Modifications LS2 (Bolt-Ons)
10.626 @ 126.98 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, hdr, ptb, tune, & more, DR - (3944)
10.788 @ 127.29 - LS1LT1 - 06 A6 - CAI, conv, fast, hdr, ptb, skinnies, tune, & more, DR - (5611)
10.936 @ 123.01 - Dicky - 06 A6 - CAI, conv, cutouts, fast, 3.42, hdr, & more tune, DR - (5485)
11.121 @ 124.49 - Teetheriot - 07 A6 - CAI, conv, fast, hdr,nc , Z06 muff, & more, tune, DR - (5869)
11.293 @ 122.24 - JMT1669 - 06 A6 - CAI, conv, cb, fast, 3.42, hdr, tune, DR - (4427)
11.295 @ 122.29 - FloydSummer of 68 - 07 A6 - CAI, conv, Pfast, hdr, no cats, tune, udp, DR - (5105)
11.342 @ 125.78 - Silvervette05 - 05 M6 – pfast/tb, gto skinnys, Z06 exhaust, tune, DR - (4422)
11.412 @ 119.27 - Devilish34 - 07 M6 - CAI, hdr, pfast, Z06 rear, tune, DR - (5536)
11.667 @ 118.76 - Its Stock - 06 M6 - CAI, hdr, udp, tune, DR - (4565)
11.683 @ 118.89 - Vade 46 - 07 M6 Z51 - CAI, hdr, tune, DR - (6400)
11.747 @ 120.83 - Siffert - 07 A6 - CAI, cb, pfast, hdr, skinnies, tune, DR - (3982)
11.76x @ 119.00 - NastyC6 - 05 A4 Z51 - CAI, conv, 3.73, hdr, pi/tb, tune
11.775 @ 121.58 - Red06vette - 06 A6 Z51 - CAI, cb, hdr, pi/tb, tune - (2175)
11.792 @ 117.26 - 06C6FVR - 07 M6 - CAI, 3.90, Z06 exhaust, tune, DR - (3225)
11.811 @ 118.76 - Joe G - 05 M6 Z51 - CAI, 3.90, hdr, pi, tune, DR - (1870)
11.879 @ 120.02 - C5pilot - - 07 A6 Z51 - CAI, hdr, pi, tune, DR - (3554)
11.87x @ 112.99 - Cucchiara - 05 A4 - CAI, cb, conv, hdr, tune, DR - (835)
11.937 @ 115.77 - DMcRacer - 07 A6 Z51 - CAI, conv, Z06 exhaust, tune, DR - (5438)
11.94x @ 117.99 - JimSpeed - 06 M6 Z51 - CAI, cb, hdr - (525)
11.969 @ 118.98 - GMRULZ - 06 M6 Z51 - Bilstein shocks, cai, hdr, pi, tune, DR - (2159)
11.98x @ 116.44 - C6speedjon - 07 M6 Z51 - CAI, cb, hdr, pi/tb, tune, DR - (1966)
12.01x @ 116.00 - Mr Z51 - 06 M6 Z51 - CAI, cb, hdr, pintake, tune, DR
12.03x @ 118.50 - Serendipity - 06 M6 - CAI, cb, hdr
12.035 @ 118.43 - Glennhl - 06 A6 Z51 - CAI, hdr, pi, tune, DR - (2273)
12.05x @ 117.02 - CYA Vett - 05 M6 F55 M6 - Hdr
12.052 @ 113.71 - Justasheet - 05 A4 Z51 - CAI, cb, 3.73, hdr, tune, DR - (4467)
12.084 @ 117.00 - Forrest - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1445)
12.091 @ 114.63 - 68RSSS -05 A4 F55 - CAI, hdr, tune - (5066)
12.136 @ 115.15 - Ben Diss - 07 M6 F55 - CAI, hdr, tune, Nitto Ivos - (1915)
12.169 @ 116.82 - Gmkillr - 07 M6 Z51 - CAI, cb, fast, hdr, x pipe, tune, Dr - (6345)
12.174 @ 114.58 - C6dreamvette - 05 A4 - CAI, no muff, tune, kdw - (2185)
12.17x @ 119.00 - RHecox - 06 A6 Z51 - CAI, cb, hdr - (1224)
12.18x @ 115.85 - Mdrrandall - 07 M6 Z51 - CAI, cb - (1818)
12.18x @ 114.00 - Toptoneone - 06 M6 Z51 - CAI, cb, hdr, tune, DR - (1820)
12.216 @ 115.98 - Mike Campbell - 06 A6 - CAI, DR - (5093)
12.219 @ 115.14 - Shocker Racing - 05 M6 - Homemade Air filter, DR - (1319)
12.22x @ 116.70 - Ponchorello - 05 A4 3.15 - CAI, hdr, tune - (1702)
12.26x @ 119.40 - Dstage - 06 M6 - CAI, cb, fast, hdr, - (654)
12.26x @ 116.65 - Waveblaster785 - 06 A6 Z51 - CB, fast, hdr, - (1114)
12.311 @ 117.82 - ParisTNdude - 06 A6 - CAI, cb, hdr, tune, DR - (6426)
12.275 @ 115.94 - TNTC4Vette - 06 M6 Z51 - Bilstein shocks, cai, hdr, no cats, ptb, tune, Ps2 (5018)
12.278 @ 114.19 - Stanger383 - 05 A4 3.15 - CAI, hdr, Z06 Muff, tune - (4223)
12.285 @ 114.46 - AngeloC6 - 05 A4 F55 3.15 - CAI, cb, hdr, hankook tires, tune - (6300)
12.293 @ 118.41 - Ganador01 - 06 A6 F55 - CAI, Fast, hdr, tune (6263)
12.319 @ 115.85 - Dave2007 - 07 A6 Z51 - CAI, cb, hdr, tune - (3625)
12.371 @ 112.29 - CTVette05 - 05 A4 3.15 - CB, hdr - (64)
12.378 @ 117.67 - Nicodemus - 05 M6 - CAI, cb, gears, hdr, tune - (364)
12.384 @ 116.78 - Goatdad - 06 A6 - CB - (6489)
12.391 @ 115.50 - Tony96 LT4 - 06 A6 Z51 - CAI, ptb, DR - (1469)
12.42x @ 116.12 - YellowVette22 - 05 M6 F55 - CAI, cb, hdr, DR - (393)
12.483 @ 113.52 - EvlJake - 07 A6 - Cb, tune - (6051)
12.49x @ 114.43 - Colinsmom - 06 A6 Z51 - CAI, cb, hdr
12.49x @ 113.50 - 12 Oh- 06 A6 - CAI, cb, hdr, tune, DR - (1245)
12.50x @ 118.00 - Larry Chip - 05 M6 - CAI, cb, tune - (173)
12.50x @ 115.20 - Flooznie - 05 A4 - tune - (212)
12.515 @ 113.56 - Jelsis - 06 A6 Z51 - CAI - (488)
12.522 @ 115.26 - Tony B4 - 06 A6 - CAI, cb, hdr, tune - (1598)
12.525 @ 115.10 - USAF_C6 - 06 A6 - CAI, cb, hdr, tune - (4408)
12.525 @ 112.09 - H-Z/28 - 06 M6 - Cb, no cats, tune - (6362)
12.534 @ 114.99 - BMT03-mach1 - 05 M6 - CAI, no cats, tune (4572)
12.539 @ 113.78 - Ultimate CC - 07 M6 Z51 - CAI - (1641)
12.54x @ 113.63 - Anky1631 - 05 M6 - CAI, cb
12.55x @ 114.95 - Shurite44 - 06 A6 Z51 - CAI, cb, hdr (839)
12.55x @ 111.98 - 2003Anniversary - 05 A4 Z51 - CAI, cb, hdr - (236)
12.590 @ 111.46 - 07Cobaltss/sc - 07 A6 F55 - CAI, cb, 3.42, RE11, tune - (5239)
12.59x @ 114.89 - AZVette2005 - 05 M6 Z51 - CB hdr, tune - (198)
12.59x @ 113.46 - Badassbu - 07 A6 - CAI - (1765)
12.60x @ 114.00 - SScamaro - 05 M6 Z51 - CAI, cb, hdrs, tune - (56)
12.627 @ 111.69 - GTkiller97 - 05 M6 Z51 - Ivos - (4521)
12.636 @ 112.93 - 05Vettelag - 05 A4 F55 3.15 - CAI, cb, tune
12.63x @ 112.35 - Lusky - 06 A6 Z51 - CAI, 325 tires
12.65x @ 113.70 - Hitman99 - 06 A6 - CAI, hdr, tune
12.683 @ 111.39 - 30Milesoffshore - 05 M6 - CAI, cb, tune - (2598)
12.68x @ 113.92 - Sditch - 05 A4 Z51 - CAI - (184)
12.712 @ 113.70 - C6Brian - 07 M6 - Tune - (1614)
12.770 @ 110.18 - CMB13 - 05 M6 Z51 - CB, DR - (1265)
12.78x @ 112.50 - Dan-t - 06 A6 - Tune - (1175)
12.797 @ 115.58 - Sebaj - 05 M6 - CB, pi/tb, ud, Z06 exhaust, tune - (4435)
12.83x @ 111.00 - TMyers - 06 A6 - CAI, tune - (764)
12.88x @ 112.50 - MickyC6 - 05 M6 - CAI, cb, tune
12.891 @ 112.57 - Bunk22 - 05 M6 Z51 - CAI, cb, hdr, rockers, tune - (856)
12.89x @ 112.00 - Tom400CFI - 05 M6 Z51 - CB -(826)
12.900 @ 114.83 - Normlunt - 05 M6 Z51 - tstat - (537)
12.933 @ 110.64 - C6Vette - 06 M6 Z51 - CAI, cb, tune - (1202)
12.97x @ 111.22 - Zoli007 - 06 M6 Z51 - CB - (222)
12.97x @ 109.00 - Tsnipe11 - 05 A4 Z51 - CAI, hdr, tune - (693)
12.994 @ 111.25 - Parkev - 05 M6 Z51 - CB - (79)
13.30x @ 110.00 - Chempowr - 05 M6 F55 - CAI, cb - (1037) high alt
13.32x @ 108.87 - CorvettePilot - 05 M6 Z51 - CB
13.953 @ 104.94 - Fright88 - 06 A6 - CB, hdr - (1679) high alt
External Engine Modifications LS3 (Bolt-Ons)
10.820 @ 125.82 - HOXXOH - 08 A6 F55 - CAI, conv, ptb, Z06 Exhaust, tune, & more, DR - (4804)
10.888 @ 125.25 - 8850 - 08 A6 NPP 2.73 - CAI, conv, gto skinnies, hdr, udp, tune, DR - (6178)
10.987 @ 124.66 - Theofel - 08 A6 - CAI, cb, conv, 3.15, hdr, tune, & more DR - (4739)
11.252 @ 125.07 - Jbsblownc5 - 08 M6 Z51 - CAI, cb, 3.73, hdr, pi, torco & meth inj, tune, DR - (3739)
11.301 @ 123.54 - JohnDaMan - 08 A6 - CAI, cb, conv, hdr, ptb, udp, tune, DR - (6391)
11.468 @ 123.52 - Shane Fap - 08 A6 - CAI, hdr, tune, Z06 muff, Nittos - (6354)
11.468 @ 119.14 - HPAvette - 08 A6 Z51 NPP 2.73 – CAI, conv, hdr, tune, DR - (5241)
11.519 @ 122.72 - James1990 - 08 A6 Z51 NPP - CAI, cf/ hood, hdr, ptb, Z06rear, tune, Invos - (3565)
11.537 @ 121.20 - XStang - 08 A6 Z51 - CAI, Conv, hdr, ptb udp, tune, DR - (3735)
11.545 @ 123.09 - JerzeyLS3 - 08 A6 – CAI, CBx, hdr, tune, DR - (5146)
11.558 @ 120.71 - StageIt - 08 M6 Z51 - CB, hdr, fast, 3.90, Et St - (3085)
11.56x @ 120.02 - Quicktime - 08 M6 - CAI, cb, hdr, pi/tb, tune, DR - (2405)
11.562 @ 118.82 - MCV - 08 M6 Z51 - CAI, DR - (1848)
11.672 @ 118.89 - Justinjor - 08 M6 Z51 NPP - CAI, hdr, ptb, Removed fuse, DR - (5340)
11.688 @ 121.22 - Socalz06 - 08 A6 - CAI, hdr, DR - (2590)
11.706 @ 118.54 - Z51 6spd - 08 A6 Z51 NPP - Ewp, hdr, tune - (2171)
11.726 @ 118.81 - BSPC608 - 08 A6 Z51 NPP – CAI, hdr, tune, DR - (4421)
11.796 @ 122.65 - Y2K2Z28 -08 A6 Z51 - CAI, cb, hdr, tune, Nitto Ivos - (3785)
11.803 @ 121.56 - Cdaniel525 -08 M6 - CAI, hdr, no cats, Z06 exhaust, tune - (5437)
11.942 @ 119.44 - Corvet786C - 08 M6 - cb, hdr, 3.90, DR - (5854)
11.989 @ 120.04 - Rock n' Blue08 - 08 M6 - CAI, 3.90, hdr, Xpipe, Z06 muff - (2890)
11.992 @ 120.25 - HeavyRightFoot - 08 M6 Z51 NPP - CAI, hdr, tune - (4432)
11.994 @ 120.44 - 1.8T - 08 M6 Z51 - CAI, cb, hdr, tune, DRs - (2464)
11.995 @ 118.34 - Oklahoma - 08 A6 Z51 NPP 2.73 - Z06 exhaust & h pipe, P2s - (5718)
12.002 @ 116.49 - Chets Z06 - 08 M6 - Nittos - (4475)
12.017 @ 119.91 - Insom - 09 M6 Z51 NPP - CAI, hdr, pi, ud, tune, DR - (4473)
12.016 @ 116.26 - Pettvette - 08 A6 - propped shroud no af - (4598)
12.033 @ 120.42 - Quikag - 08 M6 Z51 - CAI, cb, hdr, tune - (2525)
12.041 @ 115.99 - Bain - 08 A6 NPP 2.73 - CAI - (3525)
12.058 @ 118.15 - DarthOctane - 08 A6 NPP - DR - (6327)
12.066 @ 118.18 - SeeFiveOhFun - 09 A6 - Con Dws Tires - (6439)
12.103 @ 118.03 - TorchZ06 - 09 A6 NPP 2.73 - CAI - (4220)
12.118 @ 116.77 - MBB - 08 A6 Z51 NPP 2.73 - CAI, hdr, tune, nittos - (6488)
12.122 @ 118.06 - Badassbu - 09 A6 NPP - Removed fuse - (3141)
12.144 @ 118.12 - Crisis - 09 A6 Z51 - Cai - (5234)
12.179 @ 117.24 - QuickZilver - 08 A6 Z51 NPP - Removed fuse - (3540)
12.231 @ 116.61 - Danieloneil01 - 08 M6 NPP - Hdr, NC, nittos - (5703)
12.267 @ 117.52 - Ragtop99 - 08 M6 Z51 - CAI, hdr - (3927)
12.344 @ 118.40 - Airbuspilot - 08 M6 - CB - (3711)
12.410 @ 119.65 - PeterPan - 09 A6 2.73 - CAI, Tune ZR1 exhaust, 325 generals - (5902)
12.467 @ 117.86 - MMartin - 08 A6 Z51 - CAI, hdr, tune - (2906)
12.561 @ 114.70 - Gfish - 08 A6 Z51 NPP - CAI, tune - (5181)
13.336 @ 113.31 - Gaussian Mist - 08 M6 F55 NPP - Npp comander - (2704)
External Engine Modifications Grand Sport (Bolt-Ons)
11.528 @ 121.89 - GrandSportMan -10 A6 - CAIHM, hdr, tune, - (5572)
11.945 @ 118.55 - Agent White - 10 A6 NPP - CAI, hdr, tune - (4577)
12.185 @ 116.72 - EBF2K - 11 A6 NPP - CAI, hdr, tune, Ivos - (6398)
12.400 @ 115.45 - Thomasmoto - 11 A6 NPP - M2W switch - (6037)
12.696 @ 113.31 - EBF2K - 11 A6 F55 NPP - Cai, Forgeline rims, Nittos - (6248)
Internal Engine Modifications LS2
10.157 @ 129.43 - Stanger383 - 05 A4 - CAI, conv, 3.42, H&C, hdr, ptb, Z06muff, tune, & more, DR - (6370)
10.201 @ 129.99 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6403)
10.585 @ 131.43 - DSP300C - 07 M6 – al/fw, CAI, cb, ewp, pfast, 4.10, H&C, hdr, 100maf, tune, DR - (4330)
10.665 @ 133.29 - Braciole - 07 M6 - CAI, cb, dp, ewp, pfast, 4.10, hdr, H&C, tune, DR - (4296)
10.684 @ 128.05 - Justasheet - 05 A4 Z51 - CAI, cb, H&C, conv, pfast, 3.73, hdr, ptb, mh, Z06 Muff, tune, DR - (6455)
10.815 @ 128.07 - Joe G - 05 M6 Z51 - CAI, cb, cam, pfast, 4.10, hdrs, tune, DR - (5758)
10.821 @ 127.85 - Silver93vert - 06 A6 - CAI, conv, fast, H&C, hdr, udp, tune, & more DR - (4579)
10.844 @ 125.83 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, ported int/tb, udp, tune, DR - (4010)
10.87x @ 125.33 - Tek-Newbie - 05 A4 - CAI, cb, conv, fast, 3.42, H&C, hdr, tune, DR
10.908 @ 126.00 - Thesubfloor - 07 A6 - CAI, cam, conv, 3.42, hdr, tune, DR - (3687)
10.967 @ 125.59 - Mike4572 - 07 A6 - CAI, cam, conv, 3.42, hdr, pi/tb, Z06 Muff, tune, DR - (4412)
11.002 @ 124.60 - EvlJake - 07 A6 - Cai, cam, conv, cb, hdr Ls3 heads, tune, udp, Dr - (6384)
11.013 @ 127.04 - Pete@Championmotors - 06 A6 F55 - CAI, cb, conv, 3.15, H&C, hdr, tune, DR - (4611)
11.034 @ 126.46 - Isaiah48 - 05 M6 Z51 - CAI, cb, 3.90, H&C hdr, tune, DR - (3918)
11.192 @ 124.17 - C6Jack - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, DR - (4256)
11.199 @ 123.05 - Evilways - 06 A6 Z51 - CAI, cb, cam, hdr, L92/L76 combo, tune, Dr - (4075-76)
11.201 @ 120.19 - C6Dreamvette - 05 A4 - CAI, cam, conv, hdr, no muff, tune,DR - (2470)
11.23x @ 123.00 - Texas Ranger - 07 M6 - CAI, cb, cam, 4.10, hdr, udp, tune, Z06 tires - (1692)
11.243 @ 123.05 - Its Stock - 06 M6 - CAI, cam, hdr, udp, tune, DR - (5084)
11.247 @ 126.33 - Sebaj - 05 M6 - CB, Z06 Ex, H&C pi/tb, QA1 shocks, ud, Tune DR - (5934)
11.354 @ 121.70 - C6speedjon - 07 M6 Z51 - CAI, cb, cam, pfast, hdr, ptb, tune, DR - (3468)
11.467 @ 122.96 - Superstock1200 - 06 A6 - CAI, cb, cam, hdr, pi tune, DR - (2572)
11.477 @ 122.19 - Firefighter813x - 06 A6 Z51 - CAI, cb, 3.15, H&C, hdr, ptb, tune, , DR - (5717)
11.49x @ 125.62 - Wa$nt me - 06 M6 Z51 - CAI, cb, cam, fast, hdr, udp, tune, DR - (1606)
11.514 @ 122.48 - GTkiller97 - 05 M6 Z51 - CAI, cam, fast, hdr, tune, DR - (5462)
11.52x @ 125.73 - High Roller1 - 06 A6 Z51 - CAI, cb, H&C, hdr, udp, tune, DR - (1905)
11.535 @ 124.97 - Boiler RXC6 - 05 M6 F55 - CAI, cb, fast, H&C, hdr, tune, DR - (867)
11.552 @ 126.31 - Bowmanized - 07 M6 - CAI, cb, pfast, H&C, hdr, susp, tune, DR - (2757)
11.76x @ 116.76 - 1955 Belair - 05 A4 Z51 - CAI, cb, conv, fast, H&C, hdr, tune, DR
11.790 @ 120.12 - Greentank - 06 A6 - CAI, cb, 3.15, H&C, hdr - (1817)
11.982 @ 120.87 - Mr Z51 - 06 M6 Z51 - CAI, cam, 4.10, hdr, pi, udp, tune, DR - (1261)
11.994 @ 120.11 - Turboffr - 06 M6 Z51 - CAI, cam, hdr, fast udp, tune, DR - (4461)
12.31x @ 119.28 - Black02SS - 07 M6 - CAI, cam, hdr, tune
12.410 @ 120.10 - Covert Guy - 05 M6 Z51 - cam, hdr, tune - (5700)
13.12x @ 119.00 - Mitchell242 - 05 M6 - CAI, cb, fast, H&C, hdr, tune
Internal Engine Modifications LS3
10.374 @ 133.59 - Matt@TuneTime - 08 M6 Z51- Cai, ewp, fast, hdr, H&C, 4.10, skinnies, tune, DR - (6378)
10.611 @ 131.81 - Turbovic - 08 M6 - cam, gto skinnies, hdr, mh, pi, tune, Z06 susp, tune, DR - (4609)
10.633 @ 132.44 - Max@Cartek - 08 M6 - Cartek 4X H&C package, DR - (3640)
10.662 @ 131.68 - Doug@ECS - 08 M6 Z51 NPP - Blistens, cai, 3.90, H &C, hdr, tune, DR - (3193)
10.673 @ 129.31 - Justinjor - 08 M6 Z51 NPP - CAI, cam, hdr, ptb/int, no fuse, skinnies, udp, tune, Zo6spring DR - (5904)
10.709 @ 122.92 - Bsc608 - 08 A4 Z51 NPP - CAI, cam, conv, 3.42, hdr, udp, tune, DR - (6452)
10.739 @ 131.28 - Ls3yeager - 08 M6 - CAI, cb, cam, gto skinnies, hdrs, pi/tb, udp, tune, DR - (3968)
10.793 @ 127.17 - Theofel - 08 A6 - CAI, cb, cam, conv, ewp, 3.15, hdr, tune, & more, DR - (5086)
10.996 @ 130.13 - AndrewZPSU -10 A6 NPP - CAI, cam, hdr, mhvj, ptb, tune, DR - (5571)
11.032 @ 126.93 - Socalz06 - 08 A6 - CAI, cam, conv, hdr, tune, DR - (3896)
11.109 @ 123.70 - Xstang - 08 A6 - CAI, cam, conv, hdr, shaneTB, tune, DR - (4069)
11.143 @ 129.27 - AndrewZPSU - 08 M6 - CAI, cam, hdr, Z06 Exhaust, tune, DR - (4211)
11.179 @ 120.58 - Texasranger - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.527 @ 125.42 - CBVette - 08 A6 - CAI, cam, 3.15, hdr, tune, DR - (2801)
11.946 @ 121.11 - Beefcake - 08 M6 - CAI, cam, hdr, udp, tune, DR - (5936)
Power Adders LS2 (supercharger, turbo, nitrous)
09.732 @ 143.17 - Doug@ECS - 05 A4 F55 -Novi 2200, alky, cam, conv, 3.42, hdr, RPM trans, tune, DR - (3258)
09.936 @ 136.88 - Tekhombre - 05 A4 - SC, Cartek cus fuel sys, H&C, hf cats, HD rad, tune, DR - (1153)
09.984 @ 135.44 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 4.10, tune, DR - (6363)
10.065 @ 141.65 - Jutskin - 05 A4 Z51 – SC Cam, coil overs, Flipdrive, Fast 3.42, Z06rear, & more, DR - (5901)
10.201 @ 138.66 - Devilish34 - 07 M6 - SC, hdr, meth, pintake, Z06 rear, tune, DR - (6443)
10.227 @ 143.70 - FactoryRaceCar - 05 A4 – TTurbo & alky, conv, 3.42, Z06rear, RPM Trans, tune, & more, DR - (5375)
10.420 @ 133.25 - RealCanuk - 07 A6 NPP - SC, gears, hdr, HFcats, tune, DR - (6311)
10.665 @ 136.52 - Carlrx7 - 06 M6 Z51 – TTurbo & E85 pfat coil overs, tune, udp, DR - (5544)
10.680 @ 136.70 - N77nxc - 07 A6 - SC, CAI, cam, conv, hdr, DR - (4217)
10.866 @ 125.30 - JerryMuniz - 05 A4 - N2O, CAI, cb, conv, 3.73, hdr, tune, DR - (476)
10.899 @ 129.93 - DTE - 05 A4 – Twin Turbo, gears, muff, DR - (935)
10.905 @ 134.14 - Javw - 07 M6 – APS Twin Turbo, bilsteins, tune, DR - (6357)
10.996 @ 125.65 - Z51 6spd - 06 A6 Z51 - SC, CAI, cb, hdr, tune, DR - (3296)
11.074 @ 127.62 - Nextphasemarko - 06 A6 Z51 - MC, cb, hdr, DP, tune, DR - (3661)
11.094 @ 128.62 - Soldsyclone - 06 A6 - N2O, CAI, hdr, DR - (2820)
11.18x @ 125.42 - Stuart3232 - 06 M6 Z51 - N2O, CAI, CB, DR
11.281 @ 131.61 - Salvitale - 07 M6 Z51 - SC with meth, cb, hdr, tune, DR - (1800)
11.285 @ 126.48 - MCV - 06 A6 - SC, CAI, cb, tune, DR - (1648)
11.316 @ 123.93 - Ponchorello - 05 A4 - N2O, CAI, cam, hdr, tune, DR - (1896)
11.370 @ 135.29 - Turboffr - 06 M6 Z51 - SC, cai, cam, fast hdr, meth, udp, tune, DR - (4516)
11.379 @ 126.64 - Nine Ball - 05 M6 Z51 - SC, cb, cam, hdr, tune, DR - (589)
11.402 @ 121.47 - C6 Roller - 05 A4 - SC, hdr, tune, DR - (1768)
Power Adders LS3 (supercharger, turbo, nitrous)
09.556 @ 144.52 - Gsbowman - 08 A6 - SC, cam, conv, 3.42, hdr, Z06 muff, & more, tune, DR - (5347)
09.759 @ 139.83 - Silver Bullet C6 - 08 A6 - SC, alky, cam, cb, hdr, pi/tb, tune, DR - (4986)
10.248 @ 139.15 - Slowsome - 08 M6 F55 - ECS Novi, cb, fuel system, H&C, hdr, meth, tune, DR - (5556)
10.331 @ 136.88 - RV00GT - 08 M6 NPP - CAI, cam, hdr gto skinny, N2O, tune, DR - (6207)
10.551 @ 135.06 - The Game - 08 M6 Z51 NPP - ECS Novi2000, alky, hdr, tune, DR - (3232)
10.575 @ 135.18 - Winters 97 GT - 08 M6 - SC, alky, B&B mufflers, tune, DR - (5029)
10.704 @ 136.61 - ZbadestZ - 08 A6 NPP - ECS 2200, hdr, fuel system, tune DR - (5021)
10.732 @ 133.32 - Deecount - 09 A6 F55 NPP 2.73 - SC, boost a pump, tune, DR - (6262)
10.872 @ 131.13 - Beefcake - 08 A6 - CAI, cam, hdr, SC, tune, DR - (3899)
Power Adders Grand Sport (supercharger, turbo, nitrous)
10.368 @ 137.29 - DCI - 11 M6 GS - SC, cam, hdr,smaller pulley, tune, DR - (6449)
10.657 @ 134.70 - Fordracer9 - 10 A6 GS - SC, hdr, meth, xpipe, tune, DR - (5654)
11.386 @ 125.56 - CaptainBob - 11 A6 GS - Eforce SC, hdr, DR - (6203)
Larger Displacement (All entries)
07.982 @ 174.44 - Tluck - 05 A4 Z51 - 427cid, turbo, power glide, eldbrock intake, coil overs, & more, tune, DR - (6296)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.681 @ 148.36 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5881)
09.751 @ 147.05 - Icevettez06 - 05 M6 - 402 APSTT, alky, fast, fuel system, Z06 trans, more, tune, DR - (6301)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.290 @ 137.43 - Deecount - 09 A6 Npp 2.73 - SC LPE 427, cam & pheads Ls9 Intake, more tune, DR - (6349)
10.369 @ 134.42 - Pete Champion Motors - 06 A6 – LS7, cam, cb, conv, fast, 3.15, forged int, ph, tune, DR - (5153)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
1/8 mile Please submit complete 1/8 mile time slip (All entries)
6.338 @ 111.82 - Shoaf85 - 07 M6 – Upp Twin Turbo, drag pk, fuel sys, twin disk, 3.90, tune, DR - (6358)
6.519 @ 107.03 - Thesubfloor - 07 A6 - CAI, cam, conv 3.42, hdr, tune, & more DR - (4688)
6.945 @ 106.14 - Pmj341 - 07 A6 – CAI, conv, 427, fast, H&C, ptb, 100maf, tune, DR - (4357)
7.19x @ 97.56 - Socalz06 - 08 A6 - CAI, cam conv, hdr, DR - (3782)
7.145 @ 97.67 - Carlrx7 - 06 A6 - CAI, cam, conv hdr, tune, DR - (6393)
7.213 @ 95.10 - Joe G - 05 M6 Z51 - CAI, cam, 3.90, pfast, hdr, tune, DR - (3788)
7.279 @ 98.71 - XStang - 08 A6 Z51 - CAI, conv, hdr, ptb udp, tune, - (3786)
7.275 @ 92.27 - Sparo2 - 05 M6 Z51 – CAI, Cb, afw, ewp hdr, pi/tb, C5-3.90, tune DR - (4530)
7.342 @ 96.69 - Tony B4 - 06 A6 - CAI, cam, cb, conv, hdr, pi/tb, udp, tune, DR - (3052)
7.36x @ 98.03 - StageIt - 08 M6 Z51 -Cb, fast, hdr, 3.90, Et Street - (2863)
7.50x @ 99.47 - Vettechictwins - 08 M6 Z51 - CAI, cam, cb, pi/tb, hdr, tune PS2s - (3081)
7.65x @ 93.64 - C5Pilot - 07 A6 Z51 - CAI, pi & tb, hdr, tune Dr - (3558)
7.676 @ 94.37 - DavetteGuy - 08 A6 - CAI, Ptb tune - (5064)
7.835 @ 92.14 - Bunk22 - 05 M6 Z51 - CAI cb, hdr, pi, nitto ivos - (4160)
8.096 @ 91.07 - Carmos - 08 A6 Z51 NPP - (4042)
8.428 @ 85.00 - ByByBMW - 05 A4 3.15 – CAI, cb, tune - (1660)
2. A copy of your entire time slip posted to the thread as in post # 6492___
5. Type of TransA6
7. Stock Per 275/40/17 on C5 Z06 wheels
8. Tires MT
9. Modifications: Vararam CAI, Vmax CNC, LG longtubes, LG HF cats, LG X Pipe, Z06 bi-mode exh, Email tune
11. 25 PSI in drag radials, traction was not good with cold temps, foot braked to 1500 rpm
12. Typed in the post:
___ Name of the Track Memphis International Raceway
___ Date of the pass & weather conditions 03/14/2013 cool 57 deg
___ 60'.............1.918
___ 330'...........5.286
___ 660'...........8.006
___ 660’ mph....91.11
___ 1000'.......... 10.32
___ 1320'..........12.26
___ 1320’ mph….114.74
Category :
2. A copy of your entire time slip posted to the thread as in post # _6493____
4. Year Corvette05
5. Type of TransA4
6. Type of SuspensionZ51
8. Tires utilized275 45 17 HOOSIERS
9. Modifications if any CARTEK H&C ALL THE BOLT/ONS
___ 60'.............1.354
___ 330'...........4.106
___ 660'...........6.431
___ 660’ mph....106.45
___ 1000'.........8.547
___ 1320'.........10.163
___ 1320’ mph…131.08
What more could you ask for
2. A copy of your entire time slip posted to the thread as in post #_____:Time slip posted below
5. Type of Trans: A4
6. Type of Suspension: Z51 with JOC stage 1 sways and shocks
7. Stock Performance options stock NPP exhaust, stock heads, stock intake
8. Tires utilized: MT 305 x 18 on C5 Z06 replica rears Has the larger rotors on the rear 18" wheels barley clear calipers.
9. Modifications if any: G6X3 cam, A4 with 3.42 Diff, Yank 4000 ss conv, 1 7/8" LTH with cats, Callaway cold air with filter, drag radials, UDP, Tune
10. Dyno numbers if you have them 487RWHP 441 torque.
11. As much info you may want to add about the run, launch techniques, tire air pressure 20 PSI, 6800 shift points
___ Name of the Track: Texas Mortorplex
___ Date of the pass & weather conditions: 3/15/13: 72 degrees
___ 60'............. 1.438
___ 330'........... 4.306
___ 660'........... 6.758
___ 660’ mph.... 99.88
___ 1000'......... 8.8887
___ 1320'......... 10.684
___ 1320’..........125.49
[IMG]
[/IMG]I included the 10.72 time slip when I raced Big John's car driven by his 140lb nephew. His car 2008 A6 convertible stock converter supercharged running 8psi boost 560 RWHP. Complete drag setup. He was going to send me a link to YouTube video when he got home, maybe later.
Category :Power Adder LS3
1. Your entire profile completed & read Instructions:Yes
5. Type of Trans: M6
7. Stock Performance options (as in optional gears with the automatic, & etc.) Base model
8. Tires utilized: 28x10x17 hoosier slicks
9. Modifications if any: CAI,FAST102,G6X3,hdrs,4.10s,N2O,gto spares
10. Dyno numbers if you have them: 655/722
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc: 12psi tire pressure, 5k launch
___ Name of the Track: No Problem Raceway
___ Date of the pass & weather conditions 11/24/12 Around 80 and humid
___ 60'.............1.466
___ 330'...........4.247
___ 660'...........6.547
___ 660’ mph....105.74
___ 1000'.........8.513
___ 1320'.........10.150
___ 1320’ mph…138.16
[IMG]
Big Daddy vs Brian C6 08 @ Ennis - YouTube
10.684 @ 125.49 BSPC608
10.163 @ 131.08 Dennis50NJ
12.266 @ 114.743 ParisTNDude
10.150 @ 138.16 RV00GT
11.399 @ 123.44 Thomasmoto
Historical Record:
12.266 @ 114.74 - ParisTNdude - 06 A6 - CAI, cb, hdr, tune, DR - (6492)
10.163 @ 131.08 - Dennis50NJ - 05 A4 Z51 - CAI, cb, conv, ewp, pfast, 3.73, H&C, hdr, ptb, tune, & more, DR - (6493)
10.684 @ 125.49 - Bspc608 - 08 A4 Z51 NPP - CAI, cam, conv, 3.42, hdr, udp, tune, DR - (6495)
10.150 @ 138.16 - RV00GT - 08 M6 NPP - CAI, cam, hdr gto skinny, N2O, tune, DR - (6498)
11.399 @ 123.44 - Thomasmoto - 11 A6 NPP - Eforce SC, hdr, M2W switch, DR - (6503)
