C6 1/4 Mile Performance Challenge
08 A6 ls3 vert 79,000 miles
Toyo proxy r888R 285/35/19 like glue no slip @ 33psi fronts 38psi
I usually get 1.8xx 60fts not this night. Stall coming.
Bradenton drag way, FL. 68F
Kooks, High flow cats, X-pipe, SLP Loud mouth. No tune but shifts quickened in sport mode. 70.00 buck Cia box w/shroud opening.
Burnout in 1st till limiter. Brake to 1500 rpm, Stomp And release.
reaction: 1.3
60ft: 2.13
330ft: 5.41
1/8 ET: 7.96
1/8 MPH: 100.02
1/4 ET:11.86
1/4 MPH: 131.23
My biggest challenge right now is the launch once the car hooks it runs like a scalded dog. My tires were stock on 32psi I eventually dropped it down to 22 psi but my numbers didn't get any better as I had a lot of wheel hop that I was trying to fight through (let off the gas) until it stopped. If some one can provide what should be my average run on this slightly modified engine. I just want to know if I'm a bad or terrible driver.
reaction: 1.3
60ft: 2.13
330ft: 5.41
1/8 ET: 7.96
1/8 MPH: 100.02
1/4 ET:11.86
1/4 MPH: 131.23
If you really want to try and learn on stock tires (I don’t recommend it, it’s much easier to learn on drag radials) check out this website.
Www.rangeracceleration.com.
It helped many of us.
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # 7348 posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2010
5. Type of Trans M6
6. Type of Suspension Base With Bilsteins and Z51 rear mono leaf
7. Stock Performance options None
8. Tires utilized Hoosier QTP 26x9.5x16
9. Modifications: 4.10, EWP, PTB, RodMod Intake, Ram Air, 1.85 Rockers, PSI1511, Hooker Tri Y Headers, 3" X pipe to stock NPP, Crank Scraper, ATI, Flex Fuel, GTO skinnes, Tune
10. Dyno numbers if you have them SAE 453/445 STD 468/460
11. 13.5 PSI, 3000 Slip/Stab
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track US 41 Motor-Plex Morocco Ind.
___ Date of the pass & weather conditions 4/20/2018 62 degrees and near zero DA
___ 60'.............1.5274
___ 330'...........4.4237
___ 660'...........6.8161
___ 660’ mph....102.86
___ 1320'..........10.5843
___ 1320’ mph….130.89
5. Type of Trans M6
___ Name of the Track US 41 Motorsports-Plex Morocco Ind.
looks like a perfect launch.
Bullet Exhaust, MGW (that's it)
Michelin Pilot's
386whp
Right lane #8. Had trouble with burnout. When I did a decent burnout didn't seem to help. Had some wheel hop as well. Has been 14 years since I was down a track and that was with a Mitsu Evo. Much easier to drive.
I would have liked to get into the 12's but on these tires not sure I could. MPH seems kinda low, was expecting 110-112. Then again not even sure if I ran it all the way through the big end. Next time I will be less nervous.
5. Type of Trans M6
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
4. Year Corvette 2008
5. Type of Trans A6
7. Stock Performance options (as in optional gears with the automatic, & etc.) none
8. Tires utilized Michelin pilot sport A/S 3+
9. Modifications if any exhaust cutouts, GM racing spoiler, tinted light overlays
10. Dyno numbers if you have them none
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 30psi front tires 25-26 rear, held brake to launch at 1200-1300 rpm, half tank of gas, oil temp at 230, coolant at 205, trans at 195, car seat removed
___ Name of the Track Top End Dragways, MN
___ Date of the pass & weather conditions 8-11-18 hot & humid, 3600+ DA all day
___ 60'.............2.024
___ 330'...........5.532
___ 660'...........8.318
___ 660’ mph....88.46
___ 1000'.........10.647
___ 1320'.........12.719
___ 1320’ mph…113.00
Considering the great traction I'm not sure why but I couldn't get below a 2 second 60' on any of my runs. Not a single bit of wheel spin all day. The all seasons did pretty good. This was the second of 3 back to back to back passes after cooling down from my first couple runs.
PS: This was my first day ever running down the strip. I'll be back at the next test and tune for sure!
My car is a stock '12 GS with the 6MT. So I have a few questions:
-What RPM to launch it from?
-What RPM to shift gears at? Peak HP is at 5900 rpm I believe.
-Do i go into 4th towards the end or wring out 3rd?
Thank you very much for the input in advance.
let us know how you do!
Also, I've been on the track only once before in my life, and it was last year with this same car. Did 2 passes. First time i got wayyy too much wheelspin on the launch and ran almost a 14sec time. On the second run i never got into 4th, kept it in 3rd and ran a 13.5.
So yes, I need all the help i can get.
It’s much more fun if you get drag radials. They make it a lot easier it’s a fun habit! Just get out and do it. One word of advice if you go sideways or start to wheel hop just let out. It will help you regain control. Again drag radials help prevent both.
All the tips in that post will help you, the ls3 has similar torque band as ls7 just a bit lower.
ps to centinennial ., your 1st gear is a 2.97 (which makes 2nd and 3rd come sooner in this transmission gearing) you will for sure need to grab 4th .,if you were a ls7 car for instance where 3rd is deeper especially with 20” wheels then you could ride out 3rd since also ls7 rev limiter is higher .,
