C6 1/4 Mile Performance Challenge
1. Your entire profile completed & read Instructions: yes
2. A copy of your entire time slip posted to the thread as in post # _____
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2007
5. Type of Trans A6
6. Type of Suspension Base
7. Stock Performance options (as in optional gears with the automatic, & etc.) 2.56
8. Tires utilized M/T Bias ply 26/10.5 x 17
9. Modifications if any Pro charger D1 sc, Alky control Methanol Kit, Kooks headers, Triple disc Fti convertor, Cartek flip drive, Ky Speed fuel system, Ky Speed Blower cam, Btr valve springs @ pushrods, Borla axel back
10. Dyno numbers if you have them 688/597
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 40 psi front 12 psi back, stalled convertor up
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Mt Park Dragway
___ Date of the pass & weather conditions 11-19-15, Da was + 1500 ish
___ 60'..1.481...........
___ 330'. 4.153..........
___ 660'..6.388.........
___ 660’ mph..109.885..
___ 1000'.........
___ 1320'. 9.905........
___ 1320’ mph…137.899
Copy of Time Slip Below
________________________________________ ________________________________________ ____________________
_____
Category: LS3 power adders grand sport
1. Yes
2. Entire time slip
3. Complete details of your pass. 69 degrees
4. Year of corvette....2011
5. Type of trans....A6
6. Type of suspension.....base
7. Stock performance options...duel mode exhaust
8. Tires... Hoosier drag radials
9. Modifications....a&a supercharger kit, headers,cam, meth, Ported heads, conv
10. Dino #'s. 713/634
11. 26 psi tires 2000 launch
12 track slip
Bradenton Motorsports park
....12/19/2015
....60' 1.424
....330 4.064
....1/8 6.221 @115.36
....1000 8.064
....1/4 9.617@ 145.56
Category:
1. Your entire profile completed & read Instructions: YES
2. A copy of your entire time slip posted to the thread as in post: see end of this post
4. Year Corvette : 2010
5. Type of Trans M6
6. Type of Suspension Base w/Bilstein B8
7. Stock Performance options (as in optional gears with the automatic, & etc.): None
8. Tires utilized Potenza RE-11 (standard street tire) 305/30/19
9. Modifications if any Novi 1500, meth, hdr, cb, tune, clutch, street tires
10. Dyno numbers if you have them : Mustang Dyno 640 RWHP / 588 RWTQ
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : Right off the highway driven just as is on the road
___ Name of the Track: Bradenton Motorsports Park
___ Date of the pass & weather conditions : 12/10/15 65F
___ 60'.............2.071
___ 330'...........5.045
___ 660'...........7.432
___ 660’ mph....105.60
___ 1000'.........9.443
___ 1320'.........11.109
___ 1320’ mph…135.74
Copy of Time Slip Below (Slip on left was best run)
Category : LS3 External Modification (Bolt On)
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post #_____:Time slip posted below
4. Year Corvette: 2008
5. Type of Trans: A6
6. Type of Suspension: Z51 Front & Rear sway bars removed
7. Stock Performance options: Z51, NPP
8. Tires utilized: Hoosier 275/40/17 DR2 on 17x9 tsw, M&H bias plys on gto spares
9. Modifications if any: Vararam intake, fast 102, LG Superpro headers, catless open xpipe, Yank SS4000, removed passenger seat, weight reduction
10. Dyno numbers if you have them: 417/402 (maybe 2 extra hp from open xpipe?
11. As much info you may want to add about the run, launch techniques: Foot braking 3400rpm then flooring it, 18psi out back
___ Name of the Track: Sacramento Raceway Park
___ Date of the pass & weather conditions: 12/26/15 DA ~900
___ 60'............. 1.376
___ 330'........... 4.238
___ 660'........... 6.627
___ 660’ mph.... 103.14
___ 1000'......... 8.685
___ 1320'......... 10.423
___ 1320’ mph...128.51
Did you weigh the car after the weight reductions?
What made you remove the rear sway bar?
Your 60 foot is the key to great times. Congrats again.
5. Type of Trans: M6
6. Type of Suspension: stock
8. Tires utilized: Hoosier 275/40/17 DR2 and stock fronts
9. Modifications if any: Vararam intake, fast 102, LG Superpro headers, catless open xpipe, Cam, UDP, PTB
10. Dyno numbers if you have them: 471.9/448
11. As much info you may want to add about the run, launch techniques: 5500 rpm launch
___ Date of the pass & weather conditions: 12/26/15 DA -900
___ 60'............. 1.479
___ 330'........... 4.379
___ 660'........... 6.797
___ 660’ mph.... 103.36
___ 1000'......... 8.849
___ 1320'......... 10.572
___ 1320’ mph...131.33
You think David would let you use his GTO spares after you set the bolt on record in his car.
My only reasoning for removing the rear sway bar was weight.
I offered up my seat to chris too lol. Too bad the track was having issues before he could make a pass on the skinnies.
Every time I watch you run it makes me wonder why I bought a Z06 instead of a base A6 C6. :-p
You going out to the New Year's drags?
What clutch are you using? Is this a z51 car? What rear gear?
Wish I could be there for the New Year bash and meet up with you guys. It looks like stellar air all week. Just not enough time in my schedule this week.
