C6 1/4 Mile Performance Challenge
Old Feb 25, 2019 | 02:10 PM
  #7381
BSPC608's Avatar
BSPC608
Originally Posted by PRE-Z06
Category: Stock Grand Sport with drag radials
1. Your entire profile completed & read Instructions
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2010
5. Type of Trans MZ6
6. Type of Suspension Koni shocks/ZR1 front sway bar
7. Stock Performance options NPP
8. Tires utilized Hoosier 315/35r17
9. Modifications: None
10. 400rwhp
11. 20 psi in drag radials on C5Z front wheels, 40 psi in non run flat fronts and 1/4 tank of gasoline
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Texas Motorplex
___ Date of the pass & weather conditions 2/16/19 cold damp -300 DA
___ 60'.............1.768
___ 330'...........4.998
___ 660'...........7.688
___ 660’ mph....90.92
___ 1000'.......... 9.984
___ 1320'..........11.917
___ 1320’ mph….116.41
https://youtu.be/Gyhg6A0ol9o
Hey Chris nice time in the new car. What happened to your C5?
Old Feb 26, 2019 | 10:44 PM
  #7382
PRE-Z06's Avatar
PRE-Z06
Thanks, it's pending sale. Was able to improve on the times at the V-club rental as seen below...
Old Feb 26, 2019 | 10:53 PM
  #7383
PRE-Z06's Avatar
PRE-Z06
10. 400rwhp
___ Date of the pass & weather conditions 2/13/19 ~0' DA
___ 60'.............1.613
___ 330'...........4.816
___ 660'...........7.493
___ 660’ mph....91.43
___ 1000'.......... 9.772
___ 1320'..........11.706
___ 1320’ mph….118.96
Old Feb 26, 2019 | 11:16 PM
  #7384
PRE-Z06's Avatar
PRE-Z06
4. Year Corvette: 2010
5. Type of Trans: MZ6
6. Type of Suspension: Koni shocks/ZR1 front sway bar
7. Stock Performance options: NPP
8. Tires utilized: 325/30R19 Goodyear Runflats at 25psi
___ Date of the pass & weather conditions 2/13/19 -600' DA
___ 60'.............1.892
___ 330'...........5.191
___ 660'...........7.905
___ 660’ mph....90.28
___ 1000'.......... 10.203
___ 1320'..........12.159
___ 1320’ mph….117.63
Old Mar 11, 2019 | 02:01 AM
  #7385
Commandercorvette's Avatar
Commandercorvette
12.5@115 In a C6 vette That I bought used for 12k with 120,000 miles .... IM happy . Vehicle is an 08 ls3 automatic bone stock
Old Jun 17, 2019 | 11:23 PM
  #7386
Commandercorvette
my C6 is down to 12.2 @117 after headers and tune on stock run flats . Will posttime slip up when I canfind it .
Old Aug 6, 2019 | 09:40 PM
  #7387
RR68's Avatar
RR68
Category: Showroom Stock LS2(2005 -2007)
1. Your entire profile completed & read Instructions:
4. Year Corvette 2006
5. Type of Trans A6
6. Type of Suspension Stock
7. Stock Performance options (as in optional gears with the automatic, & etc.) None
8. Tires utilized Goodyear Eagle F1 Stock
9. Modifications if any None
10. Dyno numbers if you have them N/A
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 40 psi front, 32psi rear, in sport mode, leaving at 1000 rpm in drive, traction control off
___ Name of the Track Cecil County Dragway
___ Date of the pass & weather conditions September 8, 2017, 94% humidity, 81 degrees, DA 2151
___ 60'.............2.229
___ 330'...........5.942
___ 660'...........8.856
___ 660’ mph....85.26
___ 1000'.........11.317
___ 1320'.........13.369
___ 1320’ mph…109.32
Old Aug 8, 2019 | 10:37 PM
  #7388
RR68's Avatar
RR68
Category: External Engine Modifications LS2 (Bolt-Ons)
1. Your entire profile completed & read Instructions:yes
5. Type of Trans A6
6. Type of Suspension Stock with RKT diff mounts
8. Tires utilized Goodyear Eagle F1 Stock front 40 psi Mickey Thompson ET Street SS Drag Radials 275/40/17 24psi
9. Modifications if any Vararam, PTB, Tune,160 t stat, 2800 conv, 3.42, Z06 Diff,
1 7/8 long tubes, no cats, fast 102
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc 40 psi front, 24psi rear, in sport mode, leaving at 1200 rpm in drive, traction control off
___ Date of the pass & weather conditions October 10,2018 91%humidity, 73.4*, DA 2032
___ 60'.............1.701
___ 330'...........4.852
___ 660'...........7.452
___ 660’ mph....94.67
___ 1000'.........9.687
___ 1320'......…11.572
___ 1320’ mph…119.71
Last edited by RR68; Aug 8, 2019 at 10:38 PM. Reason: Picture loaded in the wrong spot
Old Sep 14, 2019 | 02:59 PM
  #7389
XLR8-R's Avatar
XLR8-R
Category:C6 LS3 with bolt ons
4. Year Corvette 2008 Convertible
5. Type of Trans Manual
6. Type of Suspension Magnetic ride
8. Tires utilized Run flats
9. Modifications if any Headers, tune, cold air induction,
10. Dyno numbers if you have them 419 rwhp
___ Name of the Track San Antonio Raceway
___ Date of the pass & weather conditions 09/13/2019
___ 60'.............1.99
___ 330'........... 5.27
___ 660'........... 7.95
___ 660’ mph.... 92.36
___ 1000'.........
___ 1320'.........12.1107
___ 1320’ mph…118.95
Last edited by XLR8-R; Sep 14, 2019 at 04:24 PM. Reason: Unnecessary text, add info
Old Nov 2, 2019 | 09:25 PM
  #7390
sprayed1998's Avatar
sprayed1998
LS2 NA Internal Mod (Cam Only)
2005 A4
Stock Base Suspension
2.73 Gear
28/10/17 Hoosier Slicks
232/234 600/600 112, LT's, No Cats. Bullets, Vararam, 25% UD Pulley, Circle D 4c Stall
446/406
No Swaybar, No Passenger Seat, 18psi, Launch From Idle
60' (did not log this run, but pretty consistent low 1.6's on all other passes)
330' - 4.551
1/8 - 7.041
1/8 MPH - 97.7
1000' - 9.185
1/4 - 11.012
1/4 MPH 123.22
Old Dec 5, 2019 | 08:13 PM
  #7391
Commandercorvette
Default Throwing my hat in for LS3 NA bolt ons with stock short block
Car went 10.92 @ 127 mph
stage 3 cam ,
converter tune headers and DR
Old Mar 26, 2020 | 02:51 AM
  #7392
YU_LOST's Avatar
YU_LOST
I don’t have a timeslip(no local track) but I’ve made a few passes with my draggy. 2011 Grand Sport A6, Tune only, still on factory runflats.
Old Apr 12, 2020 | 01:51 PM
  #7393
Omega Doom's Avatar
Omega Doom
im in on the 1/8 list
2008 A6 base
CAI
ARH headers and bullet cats
muffler delete
AMP tuned
MT 305/35/18
60ft- 1.90
1/8- 7.81
MPH- 92.99
going back after the corona dust settles with a smaller set of DRs and then installing a stall converter
Old May 11, 2020 | 03:27 PM
  #7394
truggiero19's Avatar
truggiero19
Category: LS3 (GS) Internal Engine Mods
1. Your entire profile completed & read Instructions: Yes
4. Year Corvette 2012
5. Type of Trans M6
6. Type of Suspension: Stock Mag Ride, ZR1 rear bar, no front bar
8. Tires utilized MT ET Street R 315/35/17
9. Modifications:231/238 .640/.615 114 cam, Ported stock castings, TSP manifold, Halltech 108, NW 102, ARH 2" Headers, Billy Boat Bullets, Electric Water pump, Vacuum pump, skinnies, e85
10. Dyno numbers if you have them 506rwhp
___ Name of the Track Houston Raceway Park
___ Date of the pass & weather conditions 5/09/20 500DA
___ 60'.............1.541
___ 330'...........4.419
___ 660'...........6.801
___ 660’ mph....103.24
___ 1000'.......... 8.859
___ 1320'..........10.597
___ 1320’ mph….130.12
Old Jul 8, 2020 | 03:55 PM
  #7395
BLGS's Avatar
BLGS
Re your video post from 2019 at Texas Motorplex;
Were you using "Lauch Control"?
Sounded like it.
Old Aug 24, 2020 | 11:04 AM
  #7396
1slowgs's Avatar
1slowgs
Default internal modifications Grandsport
Internal modifications Grandsport
2013 Grandsport, m6, cai, cam, hdr, tune. On factory runflat tires
Old Aug 24, 2020 | 11:37 AM
  #7397
BLGS's Avatar
BLGS
Can you share details of the cam?
Who did the install, who did the tune?
To C6 1/4 Mile Performance Challenge
Old Oct 24, 2020 | 03:18 PM
  #7398
ElijahC6's Avatar
ElijahC6
Cruising
Default Ls2 power adder
2006 LS2 A6 with ESC 1500 and supporting mods
9.70@138mph
Old Oct 25, 2020 | 12:53 PM
  #7399
asd_srt's Avatar
asd_srt
Is there an actual updated list? The one on the first page hasn't been updated in 4 years. Just trying to see where I stand without looking through 370 pages of time slips.
5. Type of Trans A6
6. Type of Suspension: Stock with all sway bars still on
8. Tires utilized M&H Drag radial 275/40r17
9. Modifications: Sbe ls3, trickflow gen x 255 heads (unported) 69cc chambers, Cam motion custom grind cam, circle D converter, stock 6l80, stock 2.56 gears, kooks 1 7"8 headers, no mufflers, 10.249@134 was 93 octane. The other 3 passes were 53% ethanol. Only weight reduction was the passenger seat removed, and front skinnies. Raceweight is over 3400lbs (4lt leather stuff and big brakes are heavy), plus it has an amp and JL 10" sub.
10. Dyno numbers if you have them 487/464rwhp in 3rd gear
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc tires 20psi cold 2000rpm launch burnout held around 90mph to heat the tires
___ Name of the Track Fayetteville Motor speedway
___ Date of the pass & weather conditions 15FEB2018 -1000ish DA
___ 60'.............1.43
___ 330'...........4.19
___ 660'...........6.53
___ 660’ mph....106.31
___ 1000'.......... NA
___ 1320'..........10.23
___ 1320’ mph….135
Old Nov 14, 2020 | 12:13 PM
  #7400
Omega Doom's Avatar
Omega Doom
stage 3 cam ,
wait is this with or without the stage 3 cam? also which converter and DRs are using if i may ask?
