oil weight
Old Jan 5, 2008 | 02:55 AM
Aluminum V-8's Avatar
Aluminum V-8
Cruising
Default oil weight
What is the thought to using Mobil 1 10W30 as opposed to 5W30? They say not to because of the tight tolerances, but I don't really feel confortable with 5 weight oil in my LS-7. Am I nuts?
Old Jan 5, 2008 | 06:21 AM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
I believe that GM got it right when the designed the engine and chose the 5w oil to go in it.
Old Jan 5, 2008 | 06:41 AM
Miaugi's Avatar
Miaugi
...in fact I'm now using 0W30 Amsoil in my LS2.
Old Jan 5, 2008 | 07:09 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Can you explain a little more about why you're not comfortable with it? The 5W viscosity certainly allows a smooth flow at start up and given the resevoir set up on the LS7 it seems like a good idea.
Old Jan 5, 2008 | 07:28 AM
User 81424's Avatar
User 81424
Trust GM, I did with my LS-6 and ran it hard in Germany.
Old Jan 5, 2008 | 08:12 AM
VET4LES's Avatar
VET4LES
I use 5w 30 Mobil 1 because I believe GM knows a lot more about this than I do.
Old Jan 5, 2008 | 08:45 AM
rws.1's Avatar
rws.1
Yes...
5W30 flows better at start-up because it has a lower intrinsic viscosity .
BUT it has viscosity index improvers(VII) that make it thicken to a 30 weight oil (exactly like at 10W30 does) at operating temperatures.
This means at operating temperature ther is no difference in performance BUT at start-up 5W30 gets oil to all areas of your engine faster than 10W30 does.. so it provides better lubrication on start-up and the same lubrication while operating...
Old Jan 5, 2008 | 10:26 AM
dbradley's Avatar
dbradley
The test mules ran around the AZ desert with 0-30 for MANY miles with NO problems in the HEAT.
Old Jan 5, 2008 | 10:36 AM
tfkrato's Avatar
tfkrato
Old Jan 5, 2008 | 02:46 PM
timd38's Avatar
timd38
Am I nuts?
Yes.
Old Jan 5, 2008 | 03:44 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Read here:
http://www.bobistheoilguy.com
Old Jan 5, 2008 | 03:50 PM
AU N EGL's Avatar
AU N EGL
The 5 wt oil is to help fuel mileage. No problems with 10 wt oil, especially in very hot weather.
Old Jan 5, 2008 | 07:53 PM
666vette's Avatar
666vette
I am also using Amsoil 0W30 with no problems.
Old Jan 5, 2008 | 08:25 PM
BAADC6's Avatar
BAADC6
Anybody tried the "Luk oil" synthetic additive with the 5w30??
Old Jan 5, 2008 | 08:58 PM
calemasters's Avatar
calemasters
Do not go by how you feel. Go by what the engineers know.
Old Jan 6, 2008 | 12:51 AM
alanmm1's Avatar
alanmm1
Default I agree
I am not experimenting with my engine. I will use what GM recommends
Old Jan 6, 2008 | 05:33 AM
TEXASRANGER's Avatar
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
I called one of my local dlr's, capital chevy in Austin, and the service adv. stated that they put 10-30 in a lot during the summer so I tried it. NO MORE. The oil sensor went to 70 percent life left when I first started it and in less than 3K miles was showing only 20 percent oil life left. It seemed to reduce my power a little but that might have been that I was not happy with the new oil after I changed it.
To oil weight
Old Jan 6, 2008 | 08:12 AM
DEV-06C6's Avatar
DEV-06C6
After my H/C package at DTE they put 10W-30 in. I asked why and Phil responded it's better protection at the increased redline. Phil's in his 30s I'd guess so he's not from my era when you had summer oil and winter oil. I'm sticking with his recommendation since he's the warranty.
Old Jan 6, 2008 | 08:28 AM
rws.1's Avatar
rws.1
DEV-06C6
There has been a lot of debate of oil for those with H/C packages.
That debate has centered on which API service classification of oil to use versus which weight.
The issue is an anti-wear additive called zinc di-thio phospate which is a fantastic anti-wear compound BUT impacts catalyst life on Japanese built car technology. Japanese manufacturers were having high warrarny failure rate of emmissions systems. When API went to the SM classification about a year ago, they conceded to EPA's requested removal of ZDTP.
So the newest oils are service classification SM (Mobil 1 included). They do not contain ZDTP. A lot of engine builders/performance shops are now recommending the usage of older technlogy ZDTP oils. Those can be found in commerical oil grades that are designed for mixed fleet operations like trucking companies that want one oil to cover the salesman's car and the big rig...
Products like Shell Rotella T synthetic and Mobil Delo still are not SM and thus still contain ZDTP. So to protect your warranty ask Phil for his recommendation of API service classification along with oil weight.
Old Jan 6, 2008 | 09:05 AM
TEXASRANGER
HOOK-EM HORNS
St. Jude Donor '08
For this reason I only run rotella in my 69, 74,78 and 80 vette's. New Cam failure is very common when the wrong oil is used.
