Oil change
Old Jan 29, 2008 | 02:05 AM
mrtian97's Avatar
mrtian97
Default let the oil drain out from the filter hole, filled up a new filter with oil (VERY IMP
Originally Posted by PowerLabs
Just did that for my neighbour a week ago.
Bought an aluminum racing jack at pepboys and their lightweight aluminum jackstands.
Costco sells the jack too:
$89.99. It is SUPER strong (3000lbs), lifts up to 15 inches, puts away in a small box, is light, and, most importantly, fits underneath a Corvette
The anodized aluminum jackstands are $50 each. Again, super light, strong (3TONS each) and they will hold your car 16" off the ground; high enough for a header install:
WHat does fill up the new filter with oil mean? I thought you just install the new filter, close the
I jacked the front up by the front engine crossmember; it is easy and safe with that massive pad in front of the jack. I then put the crossmember on jackstands, removed the oil pan bolt, let it drain on a big pan, removed the filter, let the oil drain out from the filter hole, filled up a new filter with oil (VERY IMPORTANT so your car doesn't start up oil starved as it fills up the new filter with oil), put the plug back in, set the car down and refilled it with Castrol Syntec, a much better oil than Mobil 1.
On my personal vehicles it is Royal Purple only, or Castrol Syntec if I can't get RP. I don't intend on ever running Mobil 1 again; it is an OK oil for a daily driver but not something I would take a car to the track with.
WHat does fill up the new filter with oil mean? I thought you just install the new filter, close the drain plug, then fill up with the new oil
Old Jan 29, 2008 | 02:54 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Pour oil into your new filter so it is not dry when you screw it onto the engine.
Old Jan 29, 2008 | 10:30 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
As mentioned above, since the oil filter on the LSx motors mounts upside down, it is very easy to pour oil into them then screw them onto the engine. This will prevent a little bit of a dry start when you start the car after changing the oil. Probably a small impact, but I always do this on all my cars with this motor family.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
