when to change oil?
Old Feb 21, 2008 | 03:08 PM
  #41
robvuk's Avatar
robvuk
Originally Posted by goatts
Exactly. With some folks it's their way or nothing. Oil change is like the Z51 discussions. Very subjective. Do your research and make a decision. There is no single right answer.
Of course everyone can change when they feel comfortable but doesn't counting rpm's make more sense than counting miles? Surely everyone can understand that driving 3000 miles at 70mph in 6th gear at a steady 1600 rpm is far less wear and tear than the same miles over a much longer time period with 6000 rpm blasts in every gear around the city, no?
Old Feb 21, 2008 | 03:41 PM
  #42
AU N EGL's Avatar
AU N EGL
Originally Posted by glass slipper
Only the ZR1s had them, the Grand Sport LT4s were just like the LT1s. What do you not understand about them??? Their right on top of the engine with easy access...easiest car I've ever changed the oil on. I'll admit the first time I changed the oil, I thought "what a stupid idea...oil is going to go everywhere when I unscrew it". But not a drop anywhere coming off or going on (with a full filter minus the center tube drained) and I can reach the drain plug from the driver side without jacking it up or going on ramps. Like I said...easiest car I've ever changed the oil on.
Just kidding about that. First time my buddy opened his hood. that oil filter was right there. and He said the same thing about changing his oil vs his C5.
Gee if some ppl go mega thousands of miles between oil changes, I have some slightly used oil, only 500 miles between changes, I will see you cheep.
Old Feb 21, 2008 | 04:23 PM
  #43
glass slipper's Avatar
glass slipper
I knew you were kidding, I should have put one of these after my question marks as it was meant more in jest. Sorry about that.
I'll pass on your 500 mile oil...I've read your posts and would guess your 500 miles results in a little more than "slightly" used. I got less than 1000 miles out of my last oil change before the light came on...it was a fun 1000 miles though.
Old Feb 21, 2008 | 05:49 PM
  #44
AU N EGL's Avatar
AU N EGL
Who ME??? I do not abuse my car what so ever. It NEVER goes below 3000 rpms on the road er track
Oh just pulled my heads to do my yearly inspection and check my springs.
Valve heads are cleaaannnnnnnn and shinny. Valve seat is perfect and springs are set for next year. 26,000 hard track miles. Damn I love the LS6s ( now if I could just sell one of my extra houses, some Other mods would occur. )
Last month I was at a local dealers shop. Heads were pulled off a C6 with less then 20,000 miles. Looked like chit inside. Guy never drove the car above 4000 rpms and it was all gummed up.
Drive you cars guys, change the oil and get it sampled. Then you know what is going on inside your engine.
Dont be a hero and set the NY taxi cab record between oil changes.
1000 mile oil Glass yup I know were your coming from.
Old Feb 21, 2008 | 06:38 PM
  #45
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Not exactly. There is much more to the story than just that.
3000 miles at 1600rpm is a lot more time for piston ring blowby to contaminate the oil with water and fuel and eliminate its lubricity, for one thing, and if those miles are performed on short commutes that never get the oil hot enough to volatize those contaminants, then you're in real trouble...
So, counting RPMs definitely better than counting miles, but you still need to look at the whole picture....
Old Feb 21, 2008 | 09:42 PM
  #46
robvuk's Avatar
robvuk
You need to rethink that. That IS the big picture. 3000 miles on a trip passes in a few days. Engine stays warm most of the time, keeping moisture out. Low rpms keep blowby to a minimum. No need to change oil yet. 3000 miles on short run commutes to the grocery and to work every day in traffic with occasional high rpm blasts, yes, more time, more contaminants, more moisture, more blowby. ALL ACCOUNTED FOR by counting all those rpm's. The DIC is your friend.
If you are not comfortable going all the way down to 10 or 20% oil life remaining, change it at 50%. But don't do it by miles. It doesn't make any sense.
Old Feb 21, 2008 | 10:11 PM
  #47
goatts's Avatar
goatts
Sure it makes sense. No need to complicate something simple. I've always used 5000 miles and my engines do fine. Just changed the vette oil again and I think the DIC was at 30%. Whatever method you use, you basically just need to change it often enough so that it still does it's job.
