what intake?
thanks,
ben
Meet Halltech's new Venom™ Intake for the 2005-2007 C6. 3 more RWHP than the Stinger™ is replaces, it now utilizes the Killer Bee™ Filter and bridge, but is designed to accept the stock Delphi 85mm MAF sensor for easy installation. This awesome induction system comes with our "Smoothbore" Hump Connector hose as found on the Z06, and will wake up the stock LS2 like no other intake sold.
Features
* Easy Installation
* Warranty Safe
* Utilizes the Stock Delphi MAF
* 15 RWHP/12 ft. lbs TQ
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
http://forums.corvetteforum.com/member.php?u=271289:
Callaway Air Intake
Increases airflow by 34 percent. Adds 12 bhp in stock LS2's.
The Honker C6 provides reduced airpath restriction, accesses cooler air from outside of the engine compartment, and locates the air entry at a higher-than-ambient pressure area (relative to vehicle speed) to generate increased horsepower.
• Smooth internal surface and CAD-designed contours engineered to maximize laminar flow.
• Rigid filter element base ingests cooler, denser inlet air from outside of engine compartment.
• Easy-to-install duct attaches to OEM mounting locations at top of radiator support.
• OEM-grade polymer remains unaffected by severe under-hood temperature excursions.
• Low-restriction K&N filter element is washable and reusable for reliable service.
• Supports additional engine and vehicle modifications.
• Works with all OEM engine management sensors.
• Premium quality hardware used throughout for extended durability.
Dyno testing verified the airflow test results, indicating an increase of 12 bhp on an otherwise stock LS2! At the dragstrip, simply bolting a Honker into a stock 2005 coupe dropped its 1/4-mile ET by three full tenths and increased top speed by 2 mph!
The Honker C6 System includes CAD-designed air inlet duct, low restriction, washable and reusable K&N air filter element, rigid filter element housing, comprehensive installation instructions, and all required hardware for easy installation.
A fellow Corvette owner installed a honker on his already stout LS2 and picked up 15rwhp at the wheel. Keep in mind this car had EVERYTHING modded already before the CAI.
Please let me know if you're interested.
-Luigi
http://forums.corvetteforum.com/show....php?t=1963296
- C5 Clutch Spring
- Stingers
- Multiple Shifters....Finally satisfied with MGW
- 160 Thermo
- Predator Tune
- LG Pros
- Predator "Header Tune"
- Lowered on stock Bolts
The car is going in hopefully next week for Ported Intake and TB, Harland Sharp 1.8 Rockers, and a full dyno tune. I'm hoping for 410+ to the wheels. I considered going with the Fast intake and still might....We'll see.
remove the TB SPACER. He never really explained the logic in removing it. When we did the ported fast he said no again to the spacer. Anyway
you have a worthy goal of 410. Those 1.8 rockers will help. Spin says they are worth 20hp. Good luck on the dyno. Leon
thanks,
ben
Another approach:
Callaway Honker.
C6/Z06 & LS3
C6 LS2
C5
Exploded view of C6 Honker system (they have K&N filters now, instead of the green filter shown)
My 1st mod also.
