Double Clutching
Old Apr 25, 2008 | 05:00 PM
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
Originally Posted by Tom400CFI
I do. I learned to drive in a 1910 Hupmobile. No synchros. The good habit is now engrained in my driving.
Old Apr 25, 2008 | 05:04 PM
ZexZo6's Avatar
ZexZo6
What is the proper way to Double Shift and the proper way to Rev Match???
Doing this a lot, will it tear up your transmission???
Old Apr 25, 2008 | 06:36 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Originally Posted by peterpeter211
Not so. Imagine you are doing 80mph on the freeway and you are getting ready to take a very tight clover leaf off ramp. Assume the max speed you can maintain on the ramp is 25 - 30 mph. Best gear to exit the ramp is probably second because it puts you dead center in the power band so you can accelerate out of the turn.
Your options are either 1. slow down early before you get to the turn so you wont cause the rev limiter to engage when you go to second gear at 80 mph, or 2. attack the ramp at 80 mph in third or forth gear, maximize braking so that you carry as much energy into the start of the turn for as long as possible, which will bring tire adhesion up to close to 100%, and then double clutch into second at the neck of the ramp as your speed drops to 25-30. Your tires are operating at near 100% adhesion from the braking, and remain at 100% adhesion through the turn (as long as you stop braking and start accelerating to maintain 25-30) and adhesion unwinds from 100% as you accelerate out of the turn.
Double your money back guarantee that there is no quicker way around the corner. (which is why the pros use this technique). If you do it right, you can set up a neutral drift on the car and then you go through the turn without sterring inputs with the front wheels facing straight.
Oh yes, this is the fastest way to get yourself in trouble too. Exceed 100% for an instant, traction falls to near 0%,the wheels stop turnng and the car will start sliding on a tangent that will take you places you dont want to go as in off the road or another lane (and no - anti lock brakes wont prevent the wheels from stopping and sliding - anti lock brakes only work if the tire is operating within the limits of adhesion).
Your theory **sounds** good, let us know how it works out when you get off the hwy and onto the racetrack with drivers that actually know what they are doing.
If you are changing gears while at the limits of adhesion, I see a wall in your future.
Old Apr 26, 2008 | 12:07 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
Its all about control. When you match engine speed to rear wheel speed, you avoid any drag on traction that could cause a loss of adhesion and control in turns. Assume that you are driving a tire at 100% of its capable traction, and when you downshift, you use the rear tires to speed the engine up, the additional traction demand caused by the compression of the engine will exceed the capability of the tire to adhere to the road and then you are relying on the cars traction control to control your turn.
Match the speeds of the engine and tires, there is very little additional demand on the traction capability of the tire when you downshift, and you go fast. 100% traction equals maximum adhesion which equals maximu tire performance. There is no 101% of traction because once the tire loses adhesion, traction falls to nearly 0% very quickly and goodbye to performance.
The pros heal and toe the accelerator and brake so that they can drive hard into a turn, brake with the right foot to bring the traction demand toward the 100% mark, and while braking blip the throttle with the right foot, double clutch with the left foot to a lower gear, and accelerate out of the turn using engine torgue to maintain near 100% traction. This is the fastest way through any turn
I accomplish exactly that (it is called rev matching btw) with a blip of the throttle. Double clutching a car with synchronizers is a complete waste of time.
Also traction doesn't fall to 0%. If you ere in fact silly enough to downshift mid corner on the limit of adhesion the rear tires would slow down, not lock up, for a moment until the engine caught up. I've done it on purpose at autocrosses and active handling catches it every time. That is the only time you should be driving that close to the edge anyways.
Old Apr 26, 2008 | 12:45 AM
Dirty Howie's Avatar
Dirty Howie
I'm a lifetime Auto guy going to my first manual when my Z06 arrives soon.....
Who should I be listening to here ...... double clutch or not ??
I do tend to agree C640HP as I have some track experience with my C5 auto........brake straight and down shift (yes, downshifting to 2nd is necessary in an A4) before turn and accelerate all the way thru the turn thus keeping the rear from getting light.
Also......C640HP: that was a cold statement "I see a wall in your future" (I have seen the tire stacks )
DH
Old Apr 26, 2008 | 01:53 AM
Captain Crunch's Avatar
Captain Crunch
I found this cool video of a racer down shifting using a heel / toe technique.
http://www.youtube.com/watch?v=klMur6TPkrM
This is a cool video also
http://www.youtube.com/watch?v=JcxHi...eature=related
Old Apr 26, 2008 | 01:58 AM
Captain Crunch
This is even more insane!
http://www.youtube.com/watch?v=C5NOGYYvrXY
Old Apr 26, 2008 | 02:20 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I practice double-clutching sometimes but most often I just rev-match. The geometry of the pedals in the C6 makes it hard for me to properly heel/toe. I roll my right foot (brake/gas pedal) to blip the throttle. It took me a little while before I felt secure under extreme braking with just the edge of my foot on the brake pedal but it works pretty well.
Old Apr 26, 2008 | 03:52 AM
LS1LT1's Avatar
LS1LT1
"Whatever you do, just be sure not to granny shift and always double clutch like you should"
Old Apr 26, 2008 | 05:44 AM
ZexZo6's Avatar
ZexZo6
Sure thing DOM, it's also about the respect, lol
Old Apr 26, 2008 | 01:33 PM
LS1LT1's Avatar
LS1LT1
True because I do live my life a 1/4 mile at a time, nothing else matters...and in those 18 seconds or more I am free.
Old Apr 26, 2008 | 03:35 PM
ZexZo6's Avatar
ZexZo6
I actually did laught pretty good when I seen for the 18 seconds or more, lol
Part 3 had some pretty decent/legit cars in it, but it was the dumb cheesy sayings like that, that make it like the rest. When they were sliding around the mountain road really high up that girl was like, "Whenever I'm drifting nothing else matters, I'm free". Well just to let you know on a observation that I made, is all the kids around town here seem pretty free too whenever they run turning lane redlights or "Drift" onto a road. Nothing else seems to matter; not wiping out that mini van with 4 kids and their mom, not hitting all 6 pedestrians on the crosswalk, and not even killing their self by accident......NOTHING, lol
Old Apr 26, 2008 | 04:12 PM
  #33
LS1LT1's Avatar
LS1LT1
True.
The 4th Fast and Furious is coming out next year and it IS going to have most of the characters from the first movie in it.
Old Apr 26, 2008 | 05:35 PM
  #34
SeanMo's Avatar
SeanMo
St. Jude Donor '10-'11
Granny Shifting not double clutvhing when you should
http://youtube.com/watch?v=tDjo85NeiO0
sorry, this post reminded me of that
Old Apr 26, 2008 | 05:50 PM
  #35
Dirty Howie
This one was good. Thank you. I figure about 2 years till I can heal toe
DH
Old Apr 26, 2008 | 07:12 PM
  #36
ZexZo6's Avatar
ZexZo6
True.
I heard about that. If I lived in Southern California I could have my car in it. There was a place giving out invites, but you are at their beck and call and they have to think your car is Fast and Furious material.
Old Apr 26, 2008 | 09:01 PM
  #37
Keaka26's Avatar
Keaka26
I rev match and double clutch habitually...Just habit now...
