I need a little help guys, and girls. I changed my battery and now my driver's window will not index. Sometimes it doesn't work at all. I tried running both windows up and down several times, but the driver's side still will not index. Any help would be appreciated.
Thanks.
There is a section in the owners manual that explains how to reset it. I think you have to have the car on or in accessory mode, close the windows, hold the switch up for three seconds, then down, than up again. Something like that. I think I am missing something.
I did this just yesterday for the passenger window. Started the car with both doors closed. Lowered the window all the way and continued to hold the button down for 5 secs. Then raised the window all the way and continued to hold the button for 5 secs. Then released the button and held is closed again for 5 more secs. Done.
Thanks guys, it worked as you discribed! Held it for 5 seconds up, then down for 5 seconds, and then up again for 5. Sometimes all you need is a little help from your friends!
It's actually a little easier than that if you'll look at post #4, right above yours.
The owner's manual is also your friend. I suggest you download a .pdf version onto your computer. It's nice to have a searchable copy on your PC.
