C6 Stabilizer Bars
Old May 31, 2008 | 04:59 PM
danl72's Avatar
danl72
Originally Posted by Pozzo
Sorry. Go to C6 General Discussion. At top of page click on " Sticky: C6 FAQ (Frequently Asked Questions) (Multi-page thread 1 2 3 ... Last Page)" Scroll down to the section titled "MODS". The Z51 sway bar installation is in there.
OK, thanks.
Old May 31, 2008 | 05:33 PM
mcwire's Avatar
mcwire
Originally Posted by sthornburg
Does anyone know the part numbers for the front and back Z51 sway bars. I called my local dealer to order and they could not find the part numbers. I want to upgrade my C6 bars.
Go to www.jeffhardy.com, click on any Z51, get the VIN# for that Vette, and give it to your dealer. They can use that VIN#, to get the sway bar info, from their computer. -- That's what I did, and it worked for me. -- Good luck. -- --
Old Jun 1, 2008 | 01:04 AM
danl72's Avatar
danl72
Well I ordered the Z51 sway bars from Gene. Anyone have any recommendations on what bushings I should use. Thanks.
Old Jun 1, 2008 | 07:23 AM
lsbrodsky's Avatar
lsbrodsky
If you search, there are a whole bunch of threads that recommend the Pfadt polyurethane bushings, so that is what I put on mine. I didn't even bother with the GM rubber.
Old Jun 1, 2008 | 12:31 PM
CraigE's Avatar
CraigE
The Pfadt Bushings really enhance the Z51 swaybars. Get Em.
Old Jun 1, 2008 | 05:16 PM
danl72's Avatar
danl72
Thanks I will.
Old Jun 1, 2008 | 06:46 PM
Jedsvet's Avatar
Jedsvet
who sells Pfadt Bushings at a good price?
Old Jun 1, 2008 | 08:21 PM
Leprkon's Avatar
Leprkon
This is where I bought mine.. I would also recommend you replace the end-links. It's not cheap ($140 to 200), but the cast links you get from GM are usually the first thing on the car to break.
http://www.southerncarparts.com/corv...ing-p-311.html
http://www.southerncarparts.com/pfad...ink-p-310.html
or
http://www.rpidesigns.com/shop/item.asp?itemid=948
the replacement is easy once you get the wheels off the ground. You will need to have a borrow a decent torque wrench. In the end, you have a MUCH better car for the effort.
