Big time trouble!
Old Sep 8, 2008 | 03:54 AM
glass slipper's Avatar
glass slipper
If it was something mechanical like a cracked piston, you would have heard knocking noises. If it's a broken ring, you might be just sucking oil into one cylinder. Pull the plugs and see if all of them have oil on them or just one. If it's all of them, it might be something simple like a PCV valve. It would be very unusual for a broken ring/cracked piston keeping the engine from starting. We'll hope it's something simple and easy to fix...unless you're just looking for an excuse to upgrade.
Old Sep 8, 2008 | 08:22 AM
walterm32's Avatar
walterm32
I'm not sure where in WV your at but how about Tonys Corvette Shop in Gaithersburg MD?
Old Sep 8, 2008 | 08:41 AM
saplumr's Avatar
saplumr
Boost isn't an issue because it's very seldom is it in boost, always in vacuum. I usually drive like gandmpa.
Old Sep 8, 2008 | 12:42 PM
TMRoc's Avatar
TMRoc
Man that sucks... Sorry to hear about your problem...
Old Sep 8, 2008 | 02:22 PM
pwoolford's Avatar
pwoolford
St. Jude Donor '08
This was my first thought. I don't know what your setup is but if it was smoking but still running and not making all sorts of bad sounds it may not be that bad. What supercharger do you have? Don't they have their own oil line? If so could it have leaked internally somehow? I'd start by pulling the plugs and doing a compression check. That should answer many questions.
Old Sep 8, 2008 | 05:29 PM
saplumr's Avatar
saplumr
I've got a ProCharger which is self contained. Engine no longer runs.
Old Sep 8, 2008 | 05:52 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I hope this is the worse before it gets better.
