So I need
You need a 3" outlet midpipe in order to run any exhaust meant for a C6 Z06. Or you can run regular C6 NPP exhaust if you want the bimodal action and have a 2.5" outlet midpipe.
My car ran Kooks 1 3/4" headers with a 3 X 2.5" catted midpipe (that is what all C6s use). When I decided to get rid of my C6 GHL exhaust and get some C6 Z06 exhaust instead I got a 3X3 catted midpipe and sold the 3X2.5" one here on the forums. The headers remain the same...
Still very curious to see how the switch over to 1 7/8" headers affects your car. Hopefully you'll be using the same dyno so we can have a better basis for comparison?
*You need a 3" outlet midpipe in order to run any exhaust meant for a C6 Z06. Or you can run regular C6 NPP exhaust if you want the bimodal action and have a 2.5" outlet midpipe.*My car ran Kooks 1 3/4" headers with a 3 X 2.5" catted midpipe (that is what all C6s use). When I decided to get rid of my C6 GHL exhaust and get some C6 Z06 exhaust instead I got a 3X3 catted midpipe and sold the 3X2.5" one here on the forums. The headers remain the same...*Still very curious to see how the switch over to 1 7/8" headers affects your car. Hopefully you'll be using the same dyno so we can have a better basis for comparison?
. around 580-600Yours maybe a little generous Mine for sure is shorting me!I thought I had the new headers ordered right being AR* maybe it's different so I 'll call Andy in the morning to be sure. So your running a stock Z cat back?
I had GHLs before; they droned too much... Got Corsa Sports; too heavy... Settled for the C6 Z06 system. That plus my catted 1 3/4" Kooks and the ported TB and intake manifold is all I had for that 598whp / 518wtq pull...
I'd find a different dyno too I guess, although be aware that any dyno can be made to read whatever you want it to read; with the "right" correction factors I have seen bolt on LS2 cars post 460HP at the wheels
That is why every time I take my car to the dyno I have two questions to the operator: "What does a stock C6 normally baseline on your dyno" and "What does a stock C6 Z06 normally baseline on your dyno?".
Cartek tells me a stock Z06 will baseline around 450WHP on the dyno used to tune my car... That's not too generous
Then again, I am running 10.5+ PSI at redline... That's a lot of boost for a car with headers!I'm looking forward to seeing some more ego-stroking numbers from your car, but you and I know its ridiculously fast being a force fed LS3, and ultimately that is all that matters... Dyno Numbers are just that... Numbers
