Upper Control Arm Studs
Old Nov 8, 2008 | 07:41 AM
timd38's Avatar
timd38
Default Upper Control Arm Studs
Does anyone know what size studs you would use if you replaced your front upper control arm bolts with studs?
Thanks!
Old Nov 8, 2008 | 11:15 AM
glass slipper's Avatar
glass slipper
I don't know the size but I'm guessing you're doing the "shim" mod to the upper control arm to make changing from street to race alignment easier. In any case, make sure the stud/nut you use is the same or greater strength as the bolt you're replacing to prevent catastrophic failure..it could have disasterous results.
Old Nov 8, 2008 | 11:21 AM
timd38's Avatar
timd38
Actually, to change and adjust the shock, it is easier to remove the upper control arm to get them out but I am concerned about damaging the threads that are welded to the frame.
Old Nov 8, 2008 | 10:08 PM
timd38's Avatar
timd38
anyone?
To Upper Control Arm Studs
