Open Discussion on Wheels
San
So, I knew HP Tuners could do this but a number of people told me know to do this a year ago. That said, what's the ideal 18" set up for max street/strip traction w/o rubbing? I have 17x9.5 and 17x11 on my Camaro. Can you do the same with 18's on a C6 Z51 coupe? Does Nitto or MT make a 18" DR? Damn I'm fired up now!!
The best way to plan these things out is to use a Tire Size Calculator to compare the tires your car was designed to run with the tires you want to run.
I've gone through this before, so let me tell you my conclusions:
Stock, our C6s run:
245 40 18
285 35 19
We will begin with the Rears, because if you want new tires, chances are that is where they are failing you
:I wanted to run an 18" diameter rim: it is lighter, the additional sidewall will improve straight line traction, tires will be cheaper, and there are a lot more tires available on that size.
285 40 18 will be 0.45% Smaller
295 35 18 will be 1.62% Smaller
305 35 18 will be 1.68% Bigger
315 35 18 will be .64% Bigger
Those are the only sizes I can recommend. I have seen 325 series tires run before, and a 325 35 18 would be just 0.38% Smaler, but you may have some fitment issues.
Now the fronts:
You can stick with stock sizes (245 40 18), or:
255 40 18 1.25% Smaller
265 35 18 1.6% Larger
275 35 18 0.5% Bigger <= This is the stock C6 Z06 tire size.
Looking at that data, I decided to go with a 305 35 18R, 265 35 18F. Nitto makes a drag radial in that size for the back, the NT555R, and they also make the NT555RII which is the same Drag Radial rubber and tread pattern, but with a stiff sidewall for road acing. That was my choice. For the fronts I will be running Toyo Proxes R888. You can run Toyos back and front too; that was my original plan but I got a good deal on the Nittos so I am trying them out first.
Now that leaves us with just having to figure out WHAT 18" rim to run on the back in order to fit those tires...
I couldn't find one that fit well and didn't cost a fortune or weighted a ton, so I am having my stock ones widened to 18 x 11...
Here are a few threads you may find useful:
Nitto NT555 vs Toyo Proxes R888?
18" Wheels all around: Widened stockers, or ACE wheels?
Thoughts on tire sizes: 265/35R18 and 305/35R18?
Stock, our C6s run:
245 40 18
285 35 19
Now the fronts:
FWIW, I run standard C5 wheels (not C5z wheels) with my 275/40/17 and 305/30/18 Nitto 555RII's for years with no problems on the track.
They are a little narrow compared to recommended at 8.5 and 9.5, though they fit perfectly on the car and I've had NO ill effects on the track (they handle like rails...I love R rated tires).
I do have to take off the larger drilled rotors up front, which I do anyway for track purposes, as C5 solid rotors are so cheap.
Matter of fact my 275/40/17 M/T drag radials are on 17x8.5 standard C5 front wheels, and they fit perfectly too, right at the edge of the fender (and obviously provide great traction, and at < 25" per tire (measured last weekend) they provide a nice gearing advantage. C5Z front sizes work well for the rear application also.
Just a data point based on my experience. YRMV.
Formula 1 tire:
I am told F1 cars handle pretty well...
...You have to be careful making blanket statements like that... Very tall sidewalls, particularly soft ones on street tires, will definitely hurt handling as sidewall flex makes turn in slower and causes steering to feel vague, but this is not the case here: the world challenge Corvettes run 18 inch rims, not "Dubs", and there is ZERO performance advantage whatsoever to skinny tires on big whels; you need some sidewall for the tires to work, and sidewall stiffness can compensate for sidewall height resulting in a lighter wheel/tire combo that is ultimately faster
The bottom line is very simple:
You want your wheels to be big enough to accomodate the brakes required to stop the car under whatever driving conditions it will be put through, and NO LARGER. Making the wheels any larger than necessary will only slow the car down. Look at any race car and you will see that. From the F1 car pictured above, to rally cars, to lemans cars, etc etc... Unecessarily large rims have no place in a sports car.
I'm sure those Formula 1 tires won't give you very good straight line traction either, as your blanket statement said. Usually there's a trade-off, if they are good straight line traction tires they probably won't handle that great because they have to have sidewall flex to hook. Just like all-season's...they're equally craptastic in all seasons because they have to try to accomodate all seasons...lol
I like the steering response stiff, smaller sidewalls give, but to a point. I would never go any bigger than the OEM 18/19 combo. Heck, it took me 3 sets of tires to find the tire I liked years ago with my Firehawk. There are only two sets of street tires I will buy now, PS2's and BFG KD's (NOT KDW).
I love my wheels. I really do.
Problem is my car makes a bunch of power and 20" wheels are almost worthless. No 20" tire is going to hook with my car. I thought I would just enjoy knowing I have a bunch of power but I mean come on. I'm not going to discuss racing of anykind here juse use your imagination. So, do I sell my wheels and tires in favor of running some nice 18s all year round? Or, do I just widen my old factory fronts and run slicks in predator mode? Most times I'm going to track the car I'll have time to swap wheels and all that but how many of you started life thinking you were going to do this then just said the hell with it and left the ET Streets on all year? Like I said I REALLY love my look but my car will be lethal on ETs. Right now I'm picking my butt till the top of fourth. I guess before I put money into widening I'd like to hear some thoughts. Wheels are pretty mint now, I got the sensors all fixed up, so I think I could get some decent change for them. I dunno.
I'm having the same problems with wheels and tire combos as you are.
My 19/20 look good/handle good, but I can light them up with my A6
tru 3 gear, and I'm in the process of assembling a Katech 427 so my traction is going to get worse.
The idea to just buy some 19 in matching wheels with DR has crossed my mind, but again the weight factor comes up.
keep me up to date on what you end up doing.
I'm leaning towards the 18/18 welded wheel setup (Guy's).
Phil
Nothing but the very best for my car
18 inch wheels and tires all around:
C5R Corvette:
C6R Corvette:
And you can rest assured they would be even smaller if they could fit big enough brakes to stop a 3000pound car going 200MPH underneath them.
But what do they know, right?
I'll sacrifice street traction for killer looks all day everyday!
