Which is harder on your engine?
However, if you want to drive up to the "show & shine" with 1000 hp to brag about, then go for it!
Pursuit of happiness!!
The highest horsepower I have ever seen from any stock displacement non Z06 heads/cam car was mid to low 500s and 480WTQ.
For a basic bolt-on blower you are looking at making 530 - 600WHP and 480 - 550WTQ. From there the sky is the limit; more boost and a meth kit and you are looking at close to 700WHP. Add a cam and its low to mid 700s, and so on...
The price of a H/C setup done professionally was more than me buying a blower and installing it myself.
Dyno numbers can be, and often ARE, artificially inflated for nothing more than said shop advertisement or even just ego
It's not my intention to start a pissing contest with you, but you are giving out inaccurate information. Rather than argue, why don't you stop by the FI/N20 section where the high RWHP gang congregates and observe a little!
I don't know about a cam stressing your motor. I've not seen many people using big enough springs to really strain it per se. Most of the stuff run on C5/C6 are hydraulic rollers, and spring pressure are not that high (160 is on the seat, 400 ish open usually). Of course, a good timing chain is a no brainer and should always be installed when doing a cam.
Start using big springs in the 600+ lb and then you'll have to keep an eye on it, but those kind of pressures are usually and solid roller cams.
On a daily driver, I'd just go blower and call it a day, unless you're a hardcore Naturaly asprirated guy...
In either case that's like asking what YOU favorite color should be lol
This gentleman knows of what he speaks!
I'd advise you to go with a supercharger and make around 600 RWHP with no other mods. Let us know which route you take!
It's not my intention to start a pissing contest with you, but you are giving out inaccurate information. Rather than argue, why don't you stop by the FI/N20 section where the high RWHP. Yada yada
I do not wish to urinate with or near you, nor with any other man for that matter
I think his thread has been hijacked enough; if you wish to further your urination feel free to pm me. I am no stranger to big cubes OR direct-port nitrous systems (since I have both
). To the original OP: a dynamometer is a TOOL with which to measure performance changes from modification to modification. Just a friendly reminder that it, like many OTHER tools, can be manipulated
Good luck with whatever you decide.
Consider both.........a mild blower cam will provide desired torque prior to the SC "kicking in" and sounds mean as hell to
My cam provided an increase in power from 1200-5400 RPM's (or somehwere there about). My blower kicks in about 4.5 psi (RPM may vary). You will have traction issues and suggest changing your std rubber to Invo's or similar - it will ceratinly make a little difference.
The proper, conservative tuning and added fuel flow will protect your engine. You may also want to look into an upgrade on your valve components.
You want to go fast, but what does that mean to YOU. The car as stock can travel three times the allowable speed limit in most areas of the country, but doing so will cost you fines, higher insurance, and maybe your (or someone elses) life.
If you want to go fast at the dragstrip, there are specific things that you can do to optimize your performance for that specific type of event. Then it becomes a balance between horsepower, traction and reaction time.
If you want to go fast on an autocross course, the car prep is significantly different than for drag racing. Tires and suspension and wheel alignment are more important than engine mods.
If you want to go fast on a road course and participate in HPDE's and/or wheel to wheel racing, safety equipment, brakes, cooling, tires, suspension and seat time will make your times improve much more than added FI or heads and cam. A good set of headers and a good tune will serve you well for a long time before your times are being held back by a lack of horsepower.
Unfortunately, focusing on driver mods and safety equipment aren't nearly as "Sexy" as building a 700 hp motor.
I don't want to "pee on your parade" I'm just offering a few things for you to think about (based on what YOU stated were your goals) before you drop $10,000 in engine mods.
1. If bad things are going to happen, they are going to happen MUCH faster the more HP you have.
2. Heat is a pretty serious issue at HPDEs. S/Cs add heat. If you car is stock now, it will be easier to monitor it's reaction to HPDE. Get used to what is "normal" before changing it.
3. It will give you perspective to decide what you want from the car in terms of mods. It should help decide N/A, S/C or stock.
Don't get me wrong. You can absolutly run a S/C'ed car at a racetrack. All I am saying is: Don't put the cart before the horse. Even the BEST drivers on the street benefit from the experience of being on the track.
This man speaks the truth. Every word is spot on.
If you want to go fast on an autocross course, Not Really
If you want to go fast on a road course and participate in HPDE's and/or wheel to wheel racing, Not Really
Thanks for the info & advice.
You should lurk around on the autocross / road race forum. There is a large group of Texas drivers, Texas events and Texas tracks where classes and HPDE's are held.
Regardless of what you decide, driving a Corvette at or near it's limits is a BLAST!!
I never tried running the blower with run flats; I had Michelin Pilot Sport PS2s in stock sizes (245F 285R); they are not race tires, but for a street tire, they are phenomenal. The first couple of days I drove the car after blower, it was raining VERY hard, and yes, obviously, any kind of heavy throttle in 1st 2nd and 3rd gear would spin the tires. You do it a few times, realize how much gas you can give it before that happens, and just shift the car early... I daily drive the car all winter long like that; it is safe and gets great gas mileage
Wheelspin is as bad in winter as it is in the rain: when the roads get down to 30 degrees or so I can roll into the throttle in 3rd gear and have the tires light right up at 80MPH
. That is not NEARLY as cool as it may sound, btw.On a warmer day though (70F+) I can roll into the gas in 2nd gear and put it all the way to the floor as long as the road is dry and reasonably good. If you've only been in a stock C6, "Fast" doesn't even describe it. 3rd hooks up 100% of the time. 1st gear is tricky; you just have to get used to pushing the gas pedal down gradually.
99% of the time when I am driving my car, it is already moving... As long as I am going over 30-40MPH or so I can use all the power the supercharged engine makes... That's why I think the traction problem is blown out of proportion. A standing start in 1st gear on worn run flat tires would certainly make you think otherwise though.
Honestly my only regret about supercharging is that I waited this long to do it. It is not for everyone, but it definitely works for me
