1/4 mile suspension?
Removing/disconnecting the front stabilizer bar and 90/10 shocks on the front are a couple of tricks but beware of compromises to handling. Also, lowering the rear more than the front will improve anti-squat geometry and provide better weight transfer.
I'm sure you'll get more/better responses in the drag racing section but these should get you going.
With your first burnout of the day you should see lots of smoke but your subsequent ones need only be long enough to just barely see smoke or you can feel your engine sound like it’s starting to bog which means the tires are getting sticky.
As for tire pressures, I’ve found that 23.5 psi is my so-called “sweet spot” (yours will probably be different) and being off by as little as one pound either way can turn what would have been a 1.5x 60ft into a 1.6x one and I’d also recommend checking your tire pressures before each run. Some people measure them only once when they first get to the track, but I’ve seen the values jump by 2-3 psi after a good long burnout so I’ve always gotten the best (and most consistent) 60ft times by measuring them at least once every pass.
The other thing that might help with respect to the tires is switching to Street ET Radials instead of bias ply. I bought a set of bias ply last spring thinking they would hook better since they looked more like slicks but that wasn’t the case. When I talked to the tech guy at Mickey Thompson afterwards, he confirmed that the radials generally hook better than the bias ply which I confirmed when I switched back to radials the next week and immediately started getting better times.
As for removing the front stabilizer bar, I tried that too but it made no difference in either either the consistency of my times or helping to lower them.
One final suggestion is to try staging your car very shallow. The general rule of thumb is that your car will run up to a tenth slower by staging deep and this also has an effect on your 60ft times (however by a smaller amount). When I stage the car I usually drive up until I see the pre-stage light come on and then immediately stop. I then proceed to inch the car forward in very small increments until I see the second light come on. It sometimes takes 6-7 little “bumps” to finally move forward enough but I usually end up with better times as a result, both in my 60ft and ETs.
Hope some of this helps,
Christopher
andrew
