LS3 cam selection.
Old Feb 21, 2009 | 06:51 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
C6Dvl's Cam only from ECS did astonishingly well. First Cam only to hit 10.6 in the 1/4. ECS was the first. I'll try and find the video, and the dyno chart.
Old Feb 21, 2009 | 06:56 PM
PAUZAO's Avatar
PAUZAO
The 10.6's was WITH the addition of TEA ported CNC LS3 heads. Cam only it went 10.8's.
Old Feb 21, 2009 | 07:16 PM
TheCartel's Avatar
TheCartel
Blower cam and Procharger!!
Old Feb 21, 2009 | 07:28 PM
edcmat-l1's Avatar
edcmat-l1
Originally Posted by STLBLUES
I have been following your thread and it has some good info. I wanted to start this thread because I do not have to worry about sniffers. You specified "sleeper type cams". I am leaning toward a nasty sounding street cam but at the same time one with good manners that makes power all over.
We've cammed several LS3s and L92 combos. Here's a couple LS3s. They were both header cars before. Both had gains around 60 rwhp just from the cam/springs/pushrods/ud pulley. The first graph is the milder of the two. It is surprisingly mild for the gains it made. It made nice gains everywhere. This car owner has since dynoed well over 470 two different times, on two other dynojets. I'll see if I can get him to chime in here.
Old Feb 22, 2009 | 12:03 PM
turbo2001's Avatar
turbo2001
Default ?
can anybody tell me what this cam set up will do for an ls2 win or lose tq!! thanks joe
Old Feb 22, 2009 | 03:53 PM
Ragtop 99's Avatar
Ragtop 99
That's a good looking graph for a daily driver. Gains all along the curve.
What idle speed are you using with it?
Old Feb 22, 2009 | 08:34 PM
edcmat-l1's Avatar
edcmat-l1
That first one idles at 700 rpm, IIRC.
Old Feb 22, 2009 | 09:30 PM
PAUZAO's Avatar
PAUZAO
Ed, I am going to have to BUG you for the specs on this cam. Funny that in the first graphic the cam is milder, in comparison to the later graph, but the TQ curve is a lot nicer and rises at an earlier RPM. It is better under the curve.
Old Feb 23, 2009 | 10:00 AM
Ragtop 99's Avatar
Ragtop 99
Or at least overlap at .05 and intake duration.
Actually milder cams often do that. Less overlap can improve low end torque because the mixture is a little less polluted. Some milder cams use earlier IVC which increases SCR and helps the low end. This cam peaks pretty high (looks like it might pull to 6800) so I tend to doubt the IVC is real early.
Old Feb 23, 2009 | 02:56 PM
edcmat-l1's Avatar
edcmat-l1
Ah, grasshoppa. You know the way of the camshaft fairly well. Don't over estimate your powa though. IVC is much earlier than one would think. [insert Chinaman smilie here] LOL
Old Feb 23, 2009 | 05:30 PM
Ragtop 99's Avatar
Ragtop 99
I wouldn't be too surprised.
I put a cam with an IVC = 35 that had great low end in my LS1. This was on stock exhaust manifolds too. It shift nicely at 6400, which did surprise me since going in I thought it would peak early and be dead by 6200.
Master, I shall mediate upon your words.
Old Mar 25, 2009 | 10:20 PM
LS1LT1's Avatar
LS1LT1
Originally Posted by Bruno0825
Stlblues Cartek 3x all the way I could not be more happy + 27 mpg at 80 mph with the ac on and 390 gears. LS1LT1 was in the car with me.
True.
http://forums.corvetteforum.com/c6-t...-509-rwhp.html
