Which Brake Fluid?
Old Mar 6, 2009 | 05:26 PM
ngo449's Avatar
ngo449
Default Which Brake Fluid?
Hi Guys & Gals,
Which brake fluid are you using for the 07, C6 w/ /Z51 package.? I went to the dealer & the guy doesn't know which brake fluid. I have use dot 4 for the last 2 years. It seems like I have to fill my brake fluid every 6 months (1/2 to 3/4 quart). Is this normal? Thank you for all of your advice.
Old Mar 6, 2009 | 06:26 PM
ALS 08's Avatar
ALS 08
Default DOT 4 for me.
DOT 3 is fine, DOT 4 has higher temp rating.
Do not use DOT 5, silicone.
What your describing sounds very strange. I normally never add brake fluid. The most was a shot glass worth after pads wear down. The master doesn't hold enough to drop by 1/2 a quart. I've only ever bought a quart when I flush the brake sytem completely when I change pads. Adding fluid regularly would make me look for a leak.
pic, not from a Vette.
Old Mar 6, 2009 | 06:38 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
The only way to lose brake fluid is a leak somewhere. As pads wear down, fluid level in master cylinder will fall slightly, but to see the amount of fluid vanish that you describe there must be a leak. Look and see if any of the wheel cylinders are wet in the outside.
Old Mar 6, 2009 | 07:11 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
IMMEDIATELY GET YOUR CAR TO A DEALER / TECH THAT KNOWS WTF THEY ARE DOING!
What you are describing sounds like a serious safety issue, you should not be losing any fluid.
I prefer Castrol SRF fluid, but not until you have the issue corrected.
Old Mar 7, 2009 | 11:20 AM
Wingrider's Avatar
Wingrider
Super Blue Dot 4.
Old Mar 7, 2009 | 11:07 PM
TEXHAWK0's Avatar
TEXHAWK0
Have you checked below the master cylinder for a leak. Mine started to leak at the base of the master cylinder. IF fluid leaks around the plunger seal, it will run out and down the booster drum. You should never have to add fluid unless you have a leak. Even the fluid drop due to pad wear is within the capacity of the master cylinder reservoir.
Old Mar 8, 2009 | 12:14 PM
Wayne O's Avatar
Wayne O
CF Senior Member
As mentioned, have your brake system checked by a competent dealership...not the dealer that doesn't know which brake fluid to use! You shouldn't be losing brake fluid.
I use Motul 600 brake fluid...if it performs well under the demanding conditions of a race track you can be assured it will perform well with street use.
Old Mar 8, 2009 | 02:54 PM
Fasrdnu's Avatar
Fasrdnu
Definately get it checked out. You want Dot 5 nothing less. This is a vette, not a pinto.
Old Mar 8, 2009 | 05:28 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
It really depends on what you're going to do. If you're just going to run on the street, Motul RBF600 or ATE Super Blue is great fluid. If you're going to track the car, I recommend the Castrol SRF.
I've cooked Motul at the track with agressive pads (one of my other cars). Feeling the pedal go to the floor at the end of the straightaway gets your attention. That's not to say I couldn't have cooked the Castrol SRF, but I added some front ducts and the SRF and never had any problems again. The Z06 brake ducts are cheap and you can pick them up from Gene Culley. The Castrol SRF isn't cheap, but it's great fluid and you won't need to change it as often (in my experience).
San
Old Mar 8, 2009 | 08:16 PM
AaronZ51's Avatar
AaronZ51
Malinois Dad
Veteran: Marine Corps
You can use DOT 4 and even possibly DOT 5.1 but DO NOT USE DOT 5 in your existing brake system. It is designed for a different brake system and you will have seal and other problems.
Old Mar 9, 2009 | 09:21 AM
nwc6's Avatar
nwc6
Here is a good read on brake fluid...http://www.ctbrakes.com/brakefluid.html
Old Mar 9, 2009 | 03:07 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Use Motul 600, it has the highest Dry & Wet boiling temps that you can buy
Old Mar 9, 2009 | 04:27 PM
johnodrake's Avatar
johnodrake
Moderator
Noooooo! DOT 5 is silicone based and not compatible with the Vette's ABS.
I use Motul RBF 600
Old Mar 9, 2009 | 10:16 PM
C6400hp's Avatar
C6400hp
[QUOTE=///DarkSide\\\;1569228855
Use Motul 600, it has the highest Dry & Wet boiling temps that you can buy [/QUOTE]
While Motul 600 is very good, it does not have higher wet boiling points than Castrol SRF. I always consider the wet numbers as the numbers to use. Also, the Castrol is much less susceptible to absorb water than RBF so it will stay "dry" much longer than RBF.
I found it cheaper to use the SRF and bleed it 1X or 2X per year than it was to do the 600 once a month or sometimes 2X per month. Plus it is just less hassle.
Old Mar 9, 2009 | 10:22 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Originally Posted by C6400hp
While Motul 600 is very good, it does not have higher wet boiling points than Castrol SRF. I always consider the wet numbers as the numbers to use. Also, the Castrol is much less susceptible to absorb water than RBF.
I found it cheaper to use the SRF and bleed it 2X per year than it was to do the 600 once a month or sometimes 2X per month. Plus it is just less hassle.
Yeah, Motul RBF600 is 593 dry, 421 wet. Castrol SRF is 590 dry and 518 wet. My experience mimics C6400hp in that you don't have to change the Castrol SRF as often. Time is money.
San
Old Mar 10, 2009 | 02:57 AM
c6 batmobile's Avatar
c6 batmobile
I also use the motul stuff. good brake fluid.
To Which Brake Fluid?
