Lightweight Battery?
Thinking about a Braille B2317R, but I have no first hand experience with their products and don't know if it is worth $165 and will last on the hot engine bay. Also no idea how you mount a battery that small..
Also there are some hassles/downsides to consider such as how quicky some of these small batteries can drain down, leaving a door open or playing the radio too long with motor off can kill one in a matter of minutes in some cases. An aftermarket sound system and any kind of laptop/cell phone charger/adaptor use could make it even worse of course. Though they also can be brought back to life somewhat quickly as well.
There are a lot of computers/electronics in these cars so there are things to consider.
San
I used a a group 35 Optima, smaller than the OE but with enough energy to make everything run. Just think if you have an underdive pully and you have a little battery, parked at a stop light with the air conditioning on. Most cars built today have to small a battery, so what do you think will happen to the electronics on your car if you go even smaller.
Up until I changed position at work, I had a whole team of automotive battery engineers working for me and we make over 100M car batteries a year, so I do have a clue. I may not know headers and brakes, but I know batteries.
So far it's worked out quite well despite the heat from the engine compartment (especially when I drag race the car) and I've only had to jumpstart it once after leaving it in the garage for about 5 straight days. My only other complaint is that the terminals are conical so what ends up happening is that the more you tighten the clamps the more they tend to want to move upward and completely off of the terminal. What I did to counteract that was put a little loctite on the clamps and terminals which helped alleviate the problem.
Let me know if you'd like some pictures of the install although they may not ultimately help you out since it's not where the factory battery used to be (since I went with the full LS7 dry sump system).
Christopher
Christopher
Christopher i think it has to do with being conical but also the brass to aluminum is really slippery, so i took a radiator hose clamp and cut it into sections less then a half moon then opened the clamp and put the two pieces around the post then the cable end and tighten has been fine ever since
Anyway he was telling me about his latest battery pack and that it was made up of a lot of 2 pound 12 volt segments that were powerful enough to start 3 diesel trucks at the same time. He pointed to his Dodge pickup, so I assume he wasn't refering to the 18-wheeler type.
I failed to ask how well they'd work in an average car. Opps!
Well, at least you know battery development is in high gear.
Otherwise I'd just ditch the lead-acid batteries and go with a LI-POLY under my hood
It would be 20 times lighter and store the same energy...
In fact that is so much weight that if I were to take the front battery off, and put a Braille in the trunk, my car would be lighter AND better balanced with the supercharger, than it was in stock form!
So now you understand the appeal
I was thinking of an Optima "YELLOW" because as I understand the YELLOW TOP is a deep cycle, & I usually run my fans, (and soon an electric water pump) between rounds...
I think the yellow top is better suited than the RED top to run the fans and water pump for app 5-10 min between rounds..
Going with the battery you are looking at WILL take a lot of weight off the car, but (I Think you drag race it) or if you road race it yes it will give the car a balance closer to 50/50
I don't know if the Optima is much heavier than the stock battery ?? But I know I'll be able to cool my car to 150 deg.. in 5-10 min for the next round of Drag Racing... and that means it will be consistent, ..
My old LT1 would slow down a full tenth when the engine temp went over 180... I'm not sure on the new LS motors as I haven't run it on 90 deg days yet...
Also as Tony B4 says even with my OEM battery I put the car on a battery Tender if its not going to be used for more than 3-4 days...
With a very small light battery like you are thinking of getting, will it be worth the weight savings for the small increase in performance..
With Tony B4 (I think he just runs to get the BEST ET he can get (& its Damn Good)
If its a daily driver you will be fine even without a trickle charger. The battery has enough juice to crank these motors daily and even every other day. If you dont drive the car for days or weeks at a time u definitely need a trickle charger.
Also as many have pointed out do not leave the door or radio on for more than 5mins or so. You will KILL the small battery in no time.
I love the weight savings I gained and also the cleanliness of that part of the bay. I have mine mounted in the stock location laying flat. I had a 1" x 8" or so piece of aluminum that I drilled 2 holes in. Used long bolts with lock washers and tightened it down. I do autocross, mtn driving, and every other style of driving and it has never once moved. I even have the lower holding point still in there that bolts to the bottom of the tray.
Would I recommend a small battery- yes
Just make sure you follow the cautions and u are all good.
It weighs 26lbs, 450 cca @ zero degrees, 575 cca @32 degrees, capacity 38 amp hours, reserve capacity of 66 minutes
I made a custom hold down bracket but I used a bolt and large washer before that
