Service Active Handling - Consumer Action
Ideally someone needs to engineer a active handling defeat module that feeds the bcm/ecu fake sensor data. Maybe so that the car always thinks the steering wheel is dead centre and it replicates the wheel speed sensor of one wheel to all wheels. So at very least when you break traction the TC will intervene a little
I don't think I have what you discovered on the 05-08 but still waiting for CF guys to make a comment on my concern.
P.S.
Kudos for taking this issue on and spreading the word.
This thread has me seriously considering selling it and moving on. I've had this car up to 186 mph, with the intention of hopefully one day getting it to 200 on a runway or something. I also want to tackle twisty roads. Any sort of weird behavior at that speed is death.
I'm straight up terrified to drive this car now.
I have a 2010 so without the SWPS connected I'm pretty sure PTM is useless, not that it has ever seemed to work anyway.
Don't sell the car. I'll have it fixed in an hour if you fly me up, lol. Messaged you back on potential fixes.
GM: Please step the f*** up and fix it before more people get hurt, or someone dies.
If you can see the bottom of the column and you see a hanging sensor, the dealer is wrong. Its not the sensor, its the damn steering column.
P.S.
Finally tonight I took out the panels to look underneath, lo and behold, the sensor is basically spinning free further down the shaft from where it appears it should be, and even further down the shaft is a plastic cap of some sort that definitely has come loose from further up the shaft. Presumably the sensor is supposed to be further seated up the shaft and that plastic cap holds it in place from sliding down the shaft?
I can envision with a telescoping wheel/column, that plastic cap gets raked off, probably with the sensor, especially if it has been sitting unused for a while. I took some photos and a video of what I'm seeing, happy to share if it helps diagnose.
I guess I need to get that sensor back up where it belongs, but then I think I'm left with the dilemma of whether it's aligned properly according to the computer and I have no idea what to do about that.
Thanks again for the offer further up the thread, would love to get this fixed before good weather, certainly want to be safe and would love to tell the dealer to take their quote and stick it.
My question is, do I leave my column in one place? Or do I periodically move it back and forth to keep it from binding?
You can also disconnect the telescoping motor if you dont want to ever use it again lol
But the only thing that actually seemed to work was to let the telescoping steering wheel ( and the moving seat) quit working.
Fortunately, the seat and the steering wheel stopped in a good place.
I used to scoff at those who posted this, but have since changed my tune.
I only have 260,000 miles, so maybe it will be different in the future.
GM Genuine Parts Steering Angle Sensor Retainer
GM Part # 26070027ACDelco Part # 26070027
Will this work? Or am looking at apples vs oranges?
Send me a picture of what it looks like now. I can help, potentially.
