IS this a bad idea?
Old Jun 15, 2009 | 01:40 PM
Bkbulldog's Avatar
Bkbulldog
Default IS this a bad idea?
Can I do a decent size cam with stock exhaust? Idk if i want to go LT any more do to alot of shops not wanting to install and dont want to have emissions trouble later down the road. Or do I really need the LT?
How much is it to do a UDP , cam install including part prices.
Old Jun 15, 2009 | 03:09 PM
Bkbulldog's Avatar
Bkbulldog
Im also thinking of just doing 3.90 gears , N20 , and a tune and call it a day. Then mabe later on a cam.
Old Jun 15, 2009 | 03:53 PM
Ragtop 99's Avatar
Ragtop 99
Gears are a good place to start and no cam is going to match what NOS can do.
"Decent size" is the issue. You can do a cam designed around the stock manifolds and have a nice gain. While peak HP may go up only by 25 HP, a well designed cam will open your car to a 6600 - 6800 rpm shaift and the average gain over stock in the 6000 - 6800 range will be greater than 25 HP. Combined with the gears you'll be a lot faster.
Old Jun 15, 2009 | 06:41 PM
Bkbulldog's Avatar
Bkbulldog
Think I should just do the headers?
Old Jun 15, 2009 | 06:55 PM
fastz33's Avatar
fastz33
headers + cam + heads + gears + tune = wet dream
Old Jun 16, 2009 | 02:37 PM
Ragtop 99's Avatar
Ragtop 99
No. If you want the comfort of knowing you are EPA compliant, do the gears and a tune to start. Drive the car for a couple months and then decide how much more you want and what you are willing to spend.
Old Jun 16, 2009 | 03:21 PM
White_Lightning's Avatar
White_Lightning
seriously dude.. call LG.. have them do a set of long tubes and cats and be done with it..
Old Jun 16, 2009 | 07:32 PM
PRE-Z06's Avatar
PRE-Z06
install ls7 exhaust system...gotcha made 450rwhp w/ it and a small cam
To IS this a bad idea?
