When changing clutches....
Old Aug 23, 2009 | 10:11 PM
Spying Beast's Avatar
Spying Beast
Default When changing clutches....
what are the pros and cons of upgrading to the lightweight flywheel?
With 650 WHP S/C'd on and 05 Z51 what are the benefits/drawbacks?
Inquiring minds want to know....
Thanks fellas!
Old Aug 24, 2009 | 07:19 AM
Isaiah48's Avatar
Isaiah48
The light weight flywheel has a lot less inertia behind it due to less weight being spun so when you take off from a dead stop you feel the motor pull down harder than you would if you had a steel flywheel. With you having a S/C, it shouldn't be a big issue though. When I did mine, I also went to a full race Z06 tranny that also has a lot taller 1st gear in it than my old Z51 tranny did, that coupled with the big cam I have makes taking off a little tricky...
On the upside, you'll notice a big increase in how fast it revs and how fast the rpms drop between gears allowing you to shift a lot faster!
Old Aug 24, 2009 | 08:43 AM
6Speeder's Avatar
6Speeder
It also frees up some Horsepower that was being used to spin that heavy flywheel. But, at the dragstrip you need to rev up a little higher for the launch, to make up for the loss of stored rotational energy.
Old Aug 24, 2009 | 08:52 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Thanks fellas!
How do you plan on using your Corvette? This question should be asked before talk what flywheel to put in. If it is a daily driver, not normally used at the track then the stock flywheel might be the better choice. If you are a hard line tracking gear head, than the low inertia flywheel would be the way to go.
Old Aug 24, 2009 | 01:08 PM
Ragtop 99's Avatar
Ragtop 99
I put one in my Ls1. I noticed around town, the car felt more responsive as it revved a bit quicker, but I had to adjust my launch. I found that I would launch the car using a couple hundred more rpms than when I had a steel flywheel. Alternatively if I launched at lower rpm, I had to give it more throttle.
Old Aug 24, 2009 | 01:29 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I've always been a big fan of lighter flywheels. I've got a Cro-moly one now from Monster and it made a big difference in throttle response; the car basically feels like it lost a lot more weight than the 14 lbs or so from the flywheel would lead you to believe.
Since the revs jump up faster, rev matching is a lot easier too..
To When changing clutches....
