Removing Plastic Engine / Coil Covers
Old Sep 3, 2009 | 11:37 AM
DAL01's Avatar
DAL01
Default Removing Plastic Engine / Coil Covers
this is not a how to question but a why question. (i am referring to the big plastic covers that say "LS3" on them)
do some of you guys remove them because you can't stand the look of all that plastic covering your engines and you would rather see the coil packs and valve covers? or maybe because it will allow heat to escape from around the coils keeping them cooler and help create a better spark?
i plan on getting some nice valve covers, MSD Coils and fuel rails when i add the new FAST 102 intake but until then i was wondering about above.
tks, dal
Old Sep 3, 2009 | 12:05 PM
Slwsvt's Avatar
Slwsvt
I removed mine because when I added a FAST, they did not fit properly. I believe some have trimmed them with a dremel to get them to fit with the FAST.
Old Sep 3, 2009 | 01:25 PM
marc8090's Avatar
marc8090
My understanding is that they are there mainly to quiet down injector and valvetrain noise. I have not tried running my car with them removed to confirm this though.
Old Sep 3, 2009 | 01:27 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I actually like the way they look?
Old Sep 3, 2009 | 04:42 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
I've had mine off for awhile now and been complaining about valve train noise. I guess I'll put them back on and see if that works. If so I'll be back to a happy camper unitl the next thing comes along to bother me.
__________________
GO GATORS!!!
2008 Vert
Owned since new in 2007
www.c6c7vette.com
Old Sep 3, 2009 | 05:11 PM
PowerLabs's Avatar
PowerLabs
From your signature: 08 Vert 480hp "Hot Cam" LS3
I'm going to go out on a limb here and guess that your removal of those two plastic pieces has a LOT LESS to do with valvetrain noise than your hot cam and associated stiffer valve springs does
Old Sep 3, 2009 | 05:28 PM
JayplaySS2's Avatar
JayplaySS2
tks, dal
Both reasons, though it is not going to help spark, and they do look gay, very gay
Old Sep 3, 2009 | 05:42 PM
dads toy's Avatar
dads toy
When I start doing engine mods I will remove mine. I like the look of the coil packs and a nice set of vavle covers.
Old Sep 3, 2009 | 05:55 PM
PowerLabs's Avatar
PowerLabs
NOTHING with the word "CORVETTE" on it looks gay
Old Sep 3, 2009 | 06:04 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Modern engines are nowhere near as "pretty" as the old muscle car bays used to be. Today's engine bays are so loaded with wires and hoses routed all over the place, it's just a mess. The engines are not on display so the covers give some sort of style to what's going on under there. I do love the look of coil relocation and powdercoated valve covers though. Unfortunately they're a little more expensive than leaving the stock, or even painted aftermarket, covers on. As for performance, heat, sound.....I don't know how much of an effect they have.
Old Sep 3, 2009 | 06:19 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
St. Jude Donor '17
Man that's always a dead give-a-way.
I just went out and cleaned the engine, Blowed dried it and put the covers back on. All pretty now.
Old Sep 4, 2009 | 07:31 AM
tmc95's Avatar
tmc95
Navigator
I removed mine since I do not want anything that would retain heat in even the slightest fashion in the engine area. As insignificant as they are I want heat escaping as efiiciently as possible.
Old Sep 4, 2009 | 08:29 AM
Motorhead-47's Avatar
Motorhead-47
Does the "toupee" on the intake manifold serve the same purpose? (noise reduction)
Old Sep 4, 2009 | 09:06 AM
Dan Wendling's Avatar
Dan Wendling
Default Old School Looks
You can make an engine bay look old school with a few extra $. This image is from Gotcha.
Covers are from:
http://www.abearmotorsports.com/
Gotcha has it right. Check this out as well:
http://forums.corvetteforum.com/1567007649-post36.html
Old Sep 4, 2009 | 12:49 PM
Kent1999's Avatar
Kent1999
I trimmed my fuel rail covers so that more of the hardware shows. I'd rather see nice red coil packs than a big ol' Tupperware lid on my engine. I mean if you don't want to see the hardware, why open the hood in the first place?
Old Sep 4, 2009 | 03:44 PM
DAL01's Avatar
DAL01
wow, that looks great!!! that is a fantastic idea!! well done combining the best of both worlds. looks great and lets the heat escape. well i know what i am going to be doing this weekend. i really like that (if you couldn't tell
tks, dal
Old Sep 4, 2009 | 04:26 PM
PeterM's Avatar
PeterM
To Removing Plastic Engine / Coil Covers
Old Sep 5, 2009 | 12:29 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Are you sure about that?
Old Mar 3, 2016 | 12:43 AM
SC-C6's Avatar
SC-C6
Default Good job!
Looks nice, what type of coils are you using?
SC
Old Mar 3, 2016 | 08:09 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Like it, nicely done.
