Broken Engine Mount
Old Dec 12, 2009 | 03:47 PM
SERENITY_NOW's Avatar
SERENITY_NOW
Originally Posted by carlrx7
i put in the PFADT engine mounts.
-carl
How tough is the swap? What did you have to do to put the Pfadts in? Thanks...
Old Dec 13, 2009 | 04:33 PM
timd38's Avatar
timd38
Pfadt has the instructions online. Looks like a great deal of work.
Old Dec 13, 2009 | 05:17 PM
gatti-man's Avatar
gatti-man
I'm more interested in the lg proposed mounts. I don't want tons of cabin vibration. Someone near atx get the pfadt mounts please
Old Dec 13, 2009 | 07:28 PM
timd38's Avatar
timd38
Don't think the install would be any different.
http://www.pfadtracing.com/blog/wp-c...-mount-kit.pdf
Look at these. Looks like a big job that I am to old to want to do myself.
Old Dec 14, 2009 | 01:40 PM
Bobby @ LG Motorsports's Avatar
0Bobby @ LG Motorsports
Former Vendor
These sell for $169 each. Give me a call at the shop if i can help.
Old Dec 16, 2009 | 03:12 PM
Isaiah48's Avatar
Isaiah48
I have the pfadts engine and transmission mounts and they definitley transfer more noise and vibration than I'd like, how are yours in this regards?
Old Dec 16, 2009 | 07:49 PM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Pfadt Mounts
Originally Posted by CMY SIX
tell us how they feel... vibration?
I posted a thread back in August that was a feedback on Pfadt motor and tranny mount install. A search should pull it up. There are apparently several advantages to the Pfadt mounts ranging from (slightly) additional clearance for exhaust mounting to increased throttle response on demand, to lessened drivetrain shake. Since the mounts are more "solid" than OEM, some vibration is transferred to the chassis, but if you like the hint of power at your disposal, it's not a bad thing at all. I love 'em.
Old Dec 16, 2009 | 07:53 PM
YLOFEVR's Avatar
YLOFEVR
Default Pfadt Mounts install
Not at all--the trickiest part of the install is removing the old motor mounts. Of necessity, it should be performed on a lift to give you more working room, but it's NOT a big deal.
Old Dec 16, 2009 | 08:07 PM
timd38's Avatar
timd38
I have a lift, how long did it take?
Old Dec 16, 2009 | 10:40 PM
Eric D's Avatar
Eric D
Originally Posted by HANNY
the passenger side is the one that will go first, it gets "stretched" whenever the engine tourques it, I believe the engine turns clockwise as you look at it from the front., paul
Paul,
Where does this "tourques" come from that you speak of?
Old Dec 16, 2009 | 10:52 PM
HANNY's Avatar
HANNY
Originally Posted by Eric D
Paul,
HA HA ,,,,from the "tourques" monster of course of course
Old Dec 17, 2009 | 04:19 AM
CPG1962's Avatar
CPG1962
Default Lord Corporation
Lord Corportion is a huge mfg of vibration and isolation mounts. Their line has breadth and depth; further they are most likely the largest private labeler of all these type mfgs.
Secondly is Sorbathane Corp.: This one is more intereesting. They have the engineeredmaterial in its name "sorbathane" to remove all but a slitther of shock and vibration as an engine mount but may be too soft. The problem being the mount would grow so large it would not be practical but I ceratinl;y woud not write them off - they may be able to design it.
Old Dec 17, 2009 | 05:54 AM
  #33
CPG1962's Avatar
CPG1962
Default looky Here!
http://www.lord.com/Home/ProductsSer...8/Default.aspx
Old Dec 17, 2009 | 11:02 AM
  #34
Eric D's Avatar
Eric D
The hydrodynamic mounts are susceptible to heat. If you have a modified engine with headers or other items that radiate more heat than the stock configuration mounts need to be shielded better. The biggest difference in the LS3-LS7 to the LS9 mount system is the mount heat shield size. The LS9 mount heat shield covers more of the mount.
Point being, if you mod your engine, keep in mind the mounts. Expect them to fail if you do not protect them from heat.
Old Dec 18, 2009 | 12:51 PM
  #35
CMY SIX's Avatar
CMY SIX
bottom line.... what did you decide POWERLABS let us know!
Old Dec 20, 2009 | 06:10 PM
  #36
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
No decsion yet (too busy drinking Margaritas on Hamilton Island's Qualia resort ), but when I get back to the US I'll probably order two new stock mounts.
Old Dec 20, 2009 | 08:11 PM
  #37
CMY SIX's Avatar
CMY SIX
have a nice trip! have fun! I'm going to go with the Pfadt's engine and tranny at the same time
To Broken Engine Mount
Old Dec 21, 2009 | 08:19 PM
  #38
YLOFEVR's Avatar
YLOFEVR
Default C6 motor mounts
Powerlabs--I've got a stock set with 12K miles listed, with pics, . in the F/S Forum if you're interested. Ray
Old Dec 21, 2009 | 11:32 PM
  #39
chazc6's Avatar
chazc6
St. Jude Donor '10
I have a stock set free with 11k miles on them if anyone wants them. I converted to C6Z engine craddle, pfad motor mounts and eliminated approx. 22 lbs.
Old Dec 22, 2009 | 01:53 AM
  #40
cencalc6's Avatar
cencalc6
