First track pass w/ nitrous....
Old Mar 7, 2010 | 10:24 AM
dsp300c's Avatar
dsp300c
Originally Posted by wooden
congrates I have a set of the hoosiers in the shop ready to try this summer. how much air pressure in the hoosiers just looking for a good starting point.
Mine were set at 15lbs cold.
Old Mar 7, 2010 | 10:35 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
great vid!
Man do yourself a favor and get c6 Z06 rear flares for your car...I'll go take a picture of mine, I'm even running my buddy's 315-35-17's off his c6Z, they stick out, and even so I never get anything on the quarters. I hated dealing with that tape!!
http://forums.corvetteforum.com/c6-c...d-install.html
Old Mar 7, 2010 | 10:38 AM
dsp300c's Avatar
dsp300c
Originally Posted by Joe_G
great vid!
haha. you don't like my oldschool look? only way i could fit the 28s was to hike up the rear. i don't have any $$$ for a rear body yet. i did the tape b/c my buddy did it. this was my first time. i usually spray tire shine on the quarters so the rubber won't stick.
Old Mar 7, 2010 | 10:41 AM
wooden's Avatar
wooden
thanks.
Old Mar 7, 2010 | 10:43 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I don't mind the look, I just hate the hassle of it! The Z06 rear fender flares are about $20 if I recall correctly from Gene Culley.
It's the best $20 you'll spend on your car. I'll go take a picture of my wheel wells and quarters, my wheel wells are a MESS from 390 runs, but my rear quarter is perfect.
Old Mar 7, 2010 | 10:54 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Here you go.
Nasty wheel wells
clean quarters! Best cheap mod out there. Quite a clean up time saver.
dsp300c's Avatar
dsp300c
fender flares...oh...i misread it...thought you meant the whole quarter panel...
Old Mar 7, 2010 | 11:04 AM
dennis50nj's Avatar
dennis50nj
Andrew please change your avatar to 9 second club
Old Mar 7, 2010 | 11:17 AM
baezi z06's Avatar
baezi z06
Congrads.....
great run..... great setup.... great driver....
Baezi
Old Mar 7, 2010 | 11:21 AM
jmudreamvette's Avatar
jmudreamvette
Wow, Congrats to you!: 60' times are great! nice vid also
Old Mar 7, 2010 | 11:34 AM
c6 batmobile's Avatar
c6 batmobile
Nice Run. It looked like you pulled a wheel on the launch almost the front end was bouncing a little like you did.
You said you jacked up the rear to get those tires under there what exactly do you mean by that? Did you bring the bolts up?
Old Mar 7, 2010 | 11:35 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default .8 SEC for the nitrous
Congrats Andrew, For the one and only run it was totally awesome. I would guess your MPH is around 142MPH. What were you reving when you crossed the finish line?. I know CHAZ crossed at 134 @ 7100RPM but he wasn't running 28" tires so the taller tire works well with the 4.10 Gears.
You have a lot to look foreward to although the launch was almost perfect
with a ever so slight bog w a 2800 RPM launch
Old Mar 7, 2010 | 11:41 AM
  #33
admrlzr1's Avatar
admrlzr1
Awesome run! I was in the camaro in the other lane and couldnt believe it when you blew by me...i have to say i wasnt expecting that! Very strong car that will definately suprise lots of people!
Old Mar 7, 2010 | 11:53 AM
  #34
dsp300c's Avatar
dsp300c
Thanks guys for all the compliments.
I wrenched the bolts to where I couldn't see much of the thread. That raised the rear of my car so I could fit the tires. When I put regular wheels back on I'll lower the car back down. Real easy. Take like10 min.
Old Mar 7, 2010 | 11:56 AM
  #35
dsp300c's Avatar
dsp300c
Hahaha. Thanks. I was surprised too.
Old Mar 7, 2010 | 11:59 AM
  #36
dsp300c's Avatar
dsp300c
I was about 142-144. I was damn near rev limiter which is 7100 at the trap. My mind was all boggled bc of the first pass and was just looking for my shiftlight to go off so I could shift. Hahaha. 26s work great for me on motor and 28s on nitrous work great. Wish it was about 28.5 or 29 for nitrous.
Old Mar 7, 2010 | 12:34 PM
  #37
c6 batmobile
Good info. I was looking at taller tires and never even thought of doing that. Keep up the good work.
To First track pass w/ nitrous....
Old Mar 7, 2010 | 12:50 PM
  #38
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Video has been added.
That was a 2500-2800 launch. I think I can get it down to a low 1.4 or a high 1.3 60' hopefully if I bring in the nitrous on a little earlier and a little harder. That was my only pass of the night and my first pass on nitrous. Hahahaha.
Incredible. If I bog a launch down to 2800 I get a 1.8 every time.
Those Trickflow heads are the bomb. We have similar mods and you are 8 mph faster than me on motor. I think I'm going to put on a Gran Sport kit but each time I see your posts I think about those heads....
When are you adding the juice? What RPM?
What RPM do you launch on motor?
Old Mar 7, 2010 | 01:12 PM
  #39
LSCHLEM's Avatar
LSCHLEM
Hey Joe, It just might mean that A 100 shot of nitrous would get me into the 10's. I too am thinking about those trick flows but now it may be FI
with the new ZR1 type unit out. DSP's 10.58 was at about 526 RWHP and
now with a nitrous shot he's probably at 600 RWHP/ 550RWTQ. Not bad at all. Leon
Old Mar 7, 2010 | 01:16 PM
  #40
dsp300c's Avatar
dsp300c
I love the tfs heads. I am all about power and simple looks. Motor launch I believe is 2800-3000. I think the rps clutch and 4.10s help me alot. Don't remember when the juice started hitting. I'll have to go look at my progressive. I changed it 3 times before I ran. Haha. I believe it was 3600 or 3800 when nitrous started to ramp in.
