Bird stuck in radiator...help
Old Mar 29, 2010 | 07:11 PM
RY5236's Avatar
RY5236
Default Bird stuck in radiator...help
Crazy thing happened to me yesterday. Was out driving on the Baltimore beltway when out of nowhere a bird flew into the front on my car. I heard a thud, but did not see any pieces on the road behind me after I passed the impact area whic lead me to believe the bird was somewhere on or in my car. As soon as I could I pulled over for a closer look. The bird went thru the lower grill and is now lodged on the radiator. I could not find any access from the bottom of the car and after removing the airbox the top requires more experience than I have to get to the rad. Help plz!!!
Old Mar 29, 2010 | 07:47 PM
knick's Avatar
knick
if you lay on your back you can see where you can reach up from the bottom and pull the birdy out,it should be pretty easy to reach .
Old Mar 29, 2010 | 09:24 PM
cranky's Avatar
cranky
if he went thru the grille, he is stuck in the a/c condenser. turn on your a/c and see if it gets cold. if not, he poked a hole in it, and you will have to replace it..................... good luck.
Old Mar 30, 2010 | 08:44 AM
RY5236's Avatar
RY5236
actually, the bird is laying on top of the ac condensor against the radiator.....i'll try again to reach up there again tonight when i get home. thanks for the assistance!!
Old Mar 30, 2010 | 08:58 AM
subseawellhead's Avatar
subseawellhead
pics to help us decide
Old Mar 30, 2010 | 10:28 AM
E=MC62's Avatar
E=MC62
St. Jude Donor '10
Do you have a cat?
Old Mar 30, 2010 | 10:42 AM
Robls6's Avatar
Robls6
Originally Posted by E=MC62
Do you have a cat?
Old Mar 30, 2010 | 11:41 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the bird got in, you should be able to use a coat hanger to reach it and flick it out. Is it alive or dead?????
Old Mar 30, 2010 | 11:59 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
I'm voting on dead. Cant resist the pun... anyone for grilled bird?
Old Mar 30, 2010 | 01:32 PM
EDinPA's Avatar
EDinPA
like a bird abortion.
Old Mar 30, 2010 | 03:05 PM
VETFEVER's Avatar
VETFEVER
Gotta do it from the bottom - pretty tight to do unless the car is raised a few inches (placed up on jacks).
Old Mar 30, 2010 | 04:17 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Dont feel bad. About a year ago I got a bird into the opening of the VR.
The car backfired and went into reduced power. Found it up against the VR Filter. I should put some type of coarse screen on the inlet. It did
freak me out for A bit.
Old Mar 31, 2010 | 02:46 AM
PRE-Z06's Avatar
PRE-Z06
Wow, if that doesn't prove that it works I don't know what does...though I did suck this girls dress off once as I revved up the engine when she walked past the front of the car in a parking lot!
Old Apr 1, 2010 | 04:02 AM
HuskerBullet's Avatar
HuskerBullet
Kill it before it gets any bigger.
To Bird stuck in radiator...help
